devonianwalk Posted May 2, 2011 Share Posted May 2, 2011 ... So I closed both hoods and went sit on my butt in my house. James Likes this. Link to comment Share on other sites More sharing options...
sewebster Posted May 2, 2011 Share Posted May 2, 2011 Removed the plenum and poked around at my valve lifters. I think they might have some air in them. Removed AAC valve and poked around in it, seems to be ok. Put it back together. Glued a piece of window screen over the missing grille thing at the back of my hood to stop leaves from building up in my heater. Link to comment Share on other sites More sharing options...
Kyle94 Posted May 2, 2011 Share Posted May 2, 2011 put my tire carrier on... fixed to metal door slider guide, fixed the loose wobbly mirror, dried out the drivers side carpet, drove around with the sunroof out and windows down with music blaring, attempted to put in my new door hinge pins... (gave up), picked up the wheel key from the previous owner to take them damn 20's OFF! Link to comment Share on other sites More sharing options...
MY1PATH Posted May 2, 2011 Share Posted May 2, 2011 put some finishing touches on my rear bumper... Loading tests will happen next weekend, and hopefully Powder Coating as well. Link to comment Share on other sites More sharing options...
adamzan Posted May 2, 2011 Share Posted May 2, 2011 Removed the plenum and poked around at my valve lifters. I think they might have some air in them. Removed AAC valve and poked around in it, seems to be ok. Put it back together. Glued a piece of window screen over the missing grille thing at the back of my hood to stop leaves from building up in my heater. I have spares of those Link to comment Share on other sites More sharing options...
sewebster Posted May 2, 2011 Share Posted May 2, 2011 I have spares of those The lifters? They are actually all brand new. I'm not really sure what the deal is with them. They are all "hard" and not super spongy, but when a valve is open (and hence the spring is pushing the rocker down hard on the lifter, it collapses, then when I rotate the engine around some more, it comes back up to full height and is still hard. Could be high pressure gas inside? I just replaced my oil pump, which I believe was sucking air before, so maybe it pumped air into them. Hopefully it will bleed out as I drive. They aren't particularly loud right now (lifters totally soft sound pretty obvious I think) but I can hear some tapping if I open the hood. I think my next step, if it comes to that, would be to disassemble them and reassemble under oil to make sure no air can get in... Or maybe them collapsing under the force of the valve spring is normal, but I can't see how... oil is incompressible... Link to comment Share on other sites More sharing options...
adamzan Posted May 2, 2011 Share Posted May 2, 2011 Sorry not lifters, the cowl covers lol. Link to comment Share on other sites More sharing options...
k9sar Posted May 2, 2011 Share Posted May 2, 2011 stick-welded the frame and didn't set myself on fire Link to comment Share on other sites More sharing options...
sewebster Posted May 2, 2011 Share Posted May 2, 2011 Sorry not lifters, the cowl covers lol. Haha, gave you a lot of info there! Yeah, I wouldn't mind finding a spare right cowl cover. Are they the same on all WD21s? Of course the mesh is a good idea anyway, because leaves get past the stock covers pretty easily it seems. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 2, 2011 Share Posted May 2, 2011 (edited) drove mine to work where it will sit until 5:00 next Tuesday, I am on call this week. Will be driving the F-550 back and forth for the week. Edited May 2, 2011 by ahardb0dy Link to comment Share on other sites More sharing options...
nunya Posted May 2, 2011 Share Posted May 2, 2011 put my tire carrier on... correctly? I have spares of those the cowl covers lol. sone of a bich, me to! multipule spares actually (the later ones have a 'mesh design' built into them, I had 1 but ran it over ) stick-welded the frame and didn't set myself on fire yet... theres proably still hot embers somewhere... I threw away all the empty DD coffee cups on my floor and taking up my cupholders Link to comment Share on other sites More sharing options...
Kyle94 Posted May 3, 2011 Share Posted May 3, 2011 drove it like a crazy person. and now it seems to run better. Link to comment Share on other sites More sharing options...
Reshma Posted May 3, 2011 Share Posted May 3, 2011 it was dragging it self...then i put 20 bucks of hess in her and she drove amazing ;D Link to comment Share on other sites More sharing options...
Precise1 Posted May 3, 2011 Share Posted May 3, 2011 Drove it to the hospital today, twice. The gun store was closed though... B Link to comment Share on other sites More sharing options...
vagabond Posted May 4, 2011 Share Posted May 4, 2011 (edited) installed front pads on the 88, had rotors turned. Went to pick A part and found a center console out of a 94 mama likes the cup holders and the higher height, will install in the next few days Filled the tank on the 94 $84.44 Edited May 4, 2011 by vagabond Link to comment Share on other sites More sharing options...
teixeira Posted May 4, 2011 Share Posted May 4, 2011 Had the oil, air and diesel filters changed and oil, too Link to comment Share on other sites More sharing options...
nismothunder Posted May 4, 2011 Share Posted May 4, 2011 Started it and idled around the yard, then told my dog too take it for a ride, she jumps in then gives me a look about the lack of a passager seat. Link to comment Share on other sites More sharing options...
Kingman Posted May 4, 2011 Share Posted May 4, 2011 I warshed it. Now she puuurrrdy. Link to comment Share on other sites More sharing options...
farmerfra Posted May 4, 2011 Share Posted May 4, 2011 constructed and installed my custom cold air intake. Tommorrow is the Soft 8 rims with 3.75 back spacing so the 31's don't rub. Link to comment Share on other sites More sharing options...
NissanNismoZ Posted May 5, 2011 Share Posted May 5, 2011 Fixed my fuel smell and CEL..come to find out i forgot to tighten the clamps on them..heh. Link to comment Share on other sites More sharing options...
Reshma Posted May 5, 2011 Share Posted May 5, 2011 Fixed my fuel smell and CEL..come to find out i forgot to tighten the clamps on them..heh. how did you fix your fuel smell exactly? Link to comment Share on other sites More sharing options...
NissanNismoZ Posted May 5, 2011 Share Posted May 5, 2011 how did you fix your fuel smell exactly? http://www.nissanpathfinders.net/forum/index.php?showtopic=30071&view=findpost&p=572596 There you go! I think someone already made a reference to that, but in case you didnt see it, there it is. Hope this helps, if you have anymore questions, feel free to ask Link to comment Share on other sites More sharing options...
silverton Posted May 5, 2011 Share Posted May 5, 2011 I added a second tow hook to the front. But that was yesterday. Perhaps we should make a "What did you do to your Pathfinder yesterday?" thread. Among the yesterday things I did I also removed the fender flares and cranked the t-bars. It looks like a real truck! Also, I did this in the yesterdays. Link to comment Share on other sites More sharing options...
nunya Posted May 5, 2011 Share Posted May 5, 2011 changed his oil, with 5-yes 5 quarts of oil... no need for everyone to start flashing their FSM downloads that say it takes less, mine takes 5 Link to comment Share on other sites More sharing options...
Precise1 Posted May 5, 2011 Share Posted May 5, 2011 I drove it 10 miles. My round trip commute... (Nunya has a short dip stick!!) B Link to comment Share on other sites More sharing options...
