JamesRich Posted September 7, 2011 Share Posted September 7, 2011 Tried to install my motor into the pathfinder and could not get it to line up right. I really need my load leveler. At least the engine is out of the apartment and sitting inside the truck. I wish you luck with your install, I know you put a lot of work into where you are at so far. I hope the rest goes smooth for you. If I was local I'd go give you a hand. James Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 7, 2011 Share Posted September 7, 2011 Finished re-installing the stock air filter/box, cleaned the windows. Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 7, 2011 Share Posted September 7, 2011 Put green duct tape around where the rubber for the t-case shifter should be... should last until I get around to snagging an old tractor tube. The Nissan dealerships don't even have the rubber piece in their books. Link to comment Share on other sites More sharing options...
Precise1 Posted September 7, 2011 Share Posted September 7, 2011 I used it as a beer coaster. I need to order some nuts... B Link to comment Share on other sites More sharing options...
OlBlue Posted September 7, 2011 Share Posted September 7, 2011 Finally made some time and put the engine back in "Ol Blue". Managed to get the dowels lined up and tranny bolted to engine. Link to comment Share on other sites More sharing options...
ANDY Posted September 7, 2011 Share Posted September 7, 2011 went to my fav junk yard in town and he said he crushed the only nissan/truck /pathfinder there with the 3.0 so i had to go to the other jy and got the maf connector plug for 10 bucks. im going to try to re pin it and put new leads tommorrow well i hope if not clean it up and splice in hope it fixes my pathy Link to comment Share on other sites More sharing options...
lint Posted September 7, 2011 Share Posted September 7, 2011 Sprayed down the rusty exhaust bolts with penetrating oil in the hopes of replacing the exhaust tomorrow. And while I was under there, gave 'er an oil change. Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 7, 2011 Share Posted September 7, 2011 went to my fav junk yard in town and he said he crushed the only nissan/truck /pathfinder there with the 3.0 so i had to go to the other jy and got the maf connector plug for 10 bucks. im going to try to re pin it and put new leads tommorrow well i hope if not clean it up and splice in hope it fixes my pathy Was your connector all corroded? I noticed on my sentra when I pulled the MAF sensor off to clean it the plug and the socket on the MAF sensor were all covered in green corrosion. Scraped it off best I could car seems to run ok, but I noticed the rubber boot over the plug was all torn. Link to comment Share on other sites More sharing options...
silverton Posted September 7, 2011 Share Posted September 7, 2011 Put green duct tape around where the rubber for the t-case shifter should be... should last until I get around to snagging an old tractor tube. The Nissan dealerships don't even have the rubber piece in their books. They do still carry this piece, trust me! Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 7, 2011 Share Posted September 7, 2011 They do still carry this piece, trust me! pricey too Link to comment Share on other sites More sharing options...
lint Posted September 8, 2011 Share Posted September 8, 2011 Didn't get called in for work today so I replaced the exhaust & tail pipe. Those little hangars were a royal pain to remove! This job took far too long to do because the replacement part was just one piece and I had to jack up the rear of the truck & then remove the gas tank skid plate for clearance during installation. Oh, did I mention the hangars?? Got it done though! Result: nice & quiet. I didn't upgrade to a performance exhaust or anything fancy, cause I don't want to spend the dosh, and my Lambretta Motorscooter is loud enough to make me appreciate a quiet running vehicle! Link to comment Share on other sites More sharing options...
ANDY Posted September 8, 2011 Share Posted September 8, 2011 Was your connector all corroded? I noticed on my sentra when I pulled the MAF sensor off to clean it the plug and the socket on the MAF sensor were all covered in green corrosion. Scraped it off best I could car seems to run ok, but I noticed the rubber boot over the plug was all torn. yes its all corroded and when i was tryin to figure why the motor would idle wierd or die i touched the maf wiring and it would act up but i think the pins might be loose but ill try to tinker with it this weekend . and my boot is ripped im going to just E tape it Link to comment Share on other sites More sharing options...
k9sar Posted September 8, 2011 Share Posted September 8, 2011 put a stuffed pig in the back since my wife wouldn't let me keep it in the house. Link to comment Share on other sites More sharing options...
Reshma Posted September 8, 2011 Share Posted September 8, 2011 Check engine sensor came on. Opened the hood. Looked around, closed it. Shut her off. Came back this morning drove to school and the light turned off. IdK what to say about her. Link to comment Share on other sites More sharing options...
sewebster Posted September 8, 2011 Share Posted September 8, 2011 Check engine sensor came on. Opened the hood. Looked around, closed it. Shut her off. Came back this morning drove to school and the light turned off. IdK what to say about her. Check the codes? Link to comment Share on other sites More sharing options...
Reshma Posted September 9, 2011 Share Posted September 9, 2011 Check the codes? Something i need to do...if only i knew how. someone told me a long time ago. I dont remember where or who. XD I assume i can buy something to check codes from AutoZone. Link to comment Share on other sites More sharing options...
Towncivilian Posted September 9, 2011 Share Posted September 9, 2011 Something i need to do...if only i knew how. someone told me a long time ago. I dont remember where or who. XD I assume i can buy something to check codes from AutoZone. Check here. I don't think AutoZone sells ODB1 scan tools, and most (if not all) don't have a tool to scan ODB1 systems. Link to comment Share on other sites More sharing options...
Reshma Posted September 9, 2011 Share Posted September 9, 2011 Check here. I don't think AutoZone sells ODB1 scan tools, and most (if not all) don't have a tool to scan ODB1 systems. Im going to sit down tomorrow or sometime this weekend and read that then attempt to attack my problem without killing my beloved pathfinder. Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 9, 2011 Share Posted September 9, 2011 (edited) I read the codes from mine the other day, dead easy, and pulled a code 55 which I was very happy about (means all clear). I read what towncivilian linked to, printed it out, put it in the glove box just in case. I did end up removing the seat, just to make things easier (and because I discovered lots of french fries lurking around the computer). Didn't even take that long, and I can't figure out most digital watches. Edited September 9, 2011 by Slartibartfast Link to comment Share on other sites More sharing options...
adamzan Posted September 9, 2011 Share Posted September 9, 2011 pricey too Not really. Paid 34 dollars for mine. That was full retail cost from my local dealer. Link to comment Share on other sites More sharing options...
edicer2 Posted September 9, 2011 Share Posted September 9, 2011 got my new fender painted and also got a 3rd brake light painted i am going to add to my 92 se Link to comment Share on other sites More sharing options...
Alkorahil Posted September 9, 2011 Share Posted September 9, 2011 got my new fender painted and also got a 3rd brake light painted i am going to add to my 92 se sharp! I really need to do mine too, just too lazy..... Link to comment Share on other sites More sharing options...
Reshma Posted September 10, 2011 Share Posted September 10, 2011 light came on. went off. oh what did i to my pathfinder. Filled her up with regular unleaded. 30 bucks to bring her to the top. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted September 10, 2011 Share Posted September 10, 2011 Tried to mate the transmission with the engine block by using longer bolts and large nuts as spacers to pull the two together. I think I ended up misaligning the input shaft with the pilot bushing. The flex plate looks like it's bent/flexing. I didn't think it was this hard to do. Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 10, 2011 Share Posted September 10, 2011 Finally got the patches for the frame cut! Much grinding/welding to come... Link to comment Share on other sites More sharing options...
