Kingman Posted April 27, 2012 Share Posted April 27, 2012 Drove it around off open headers Link to comment Share on other sites More sharing options...
msavides Posted April 27, 2012 Share Posted April 27, 2012 (edited) Today: change oil, replace PCV valve, Clean mud off MAF sensor, Fix exhaust leak on header crossover pipe, and fill tank with gas Tomorrow: Hopefully pass smog. Over the Next few months : Break in new clutch Edited April 27, 2012 by msavides Link to comment Share on other sites More sharing options...
devonianwalk Posted April 28, 2012 Share Posted April 28, 2012 Mud on the MAF? Sheesh ... Time for a new air filter! Link to comment Share on other sites More sharing options...
nunya Posted April 28, 2012 Share Posted April 28, 2012 Accomplished a little more rust removal and prep for paint (almost to the point I'll be shooting colors) have a temporary vacuum gauge hung/connected, replaced my 'tailpipe', just need a tip for that and I'll have a complete exhaust system again. I actually accomplished something Link to comment Share on other sites More sharing options...
Meandmy92Pathy Posted April 28, 2012 Share Posted April 28, 2012 Got in her to go to the store and got a slow starter to nothing......she's been starting slow for the last week.....I guess tomorrow I willl have to begin the PITA of pulling it so I can go get a new one to install....NOT looking forward to that!!!!! Link to comment Share on other sites More sharing options...
msavides Posted April 28, 2012 Share Posted April 28, 2012 Mud on the MAF? Sheesh ... Time for a new air filter! Actually I just pull it out and wash it off in the sink and wring it out to dry it. I have an HKS super hybrid Air Filter. I think i need to put a rubber gasket around it though, that is how the muddy water got to the MAF. I should not have been in that deep of water to begin with. IT PASSED SMOG TODAY! here are the numbers Link to comment Share on other sites More sharing options...
rwd5021 Posted April 28, 2012 Share Posted April 28, 2012 Put new shocks on the 92 and then tested it out in my yard a bit, feels much better now. Link to comment Share on other sites More sharing options...
BuckRyp Posted April 29, 2012 Share Posted April 29, 2012 Yeah i thought i had it running good last night so today i get in to go test it out on the trails and FAIL! running like crap AGAIN! changed the spark plugs, maf, tps, and cap and rotor all just in the last month. so i was messing with it most of the day and i think it is getting way to much gas, when i ran it it was ruff so i pulled the air filter and box and then looked at the intake while it was running crappy and gas was poring into the intake. think i need to analyze my fuel system. no codes on the cpu. Link to comment Share on other sites More sharing options...
vagabond Posted April 29, 2012 Share Posted April 29, 2012 look close at your injectors 1 might be leaking, I had to replace the pass side on my 88 it was leaking pretty bad and running like crap Link to comment Share on other sites More sharing options...
BuckRyp Posted April 29, 2012 Share Posted April 29, 2012 Thanks ill chec that tomorrow and let you know what i see. and i think it was the pass side i was looking at when i saw how much gas was being spraid into the intake. it sounds like its drowning when its running and you can smell its rich Link to comment Share on other sites More sharing options...
Kingman Posted April 29, 2012 Share Posted April 29, 2012 If the injectors are fine test the CHTS and sub harness, probably need to replace those if you haven't already. Link to comment Share on other sites More sharing options...
devonianwalk Posted April 29, 2012 Share Posted April 29, 2012 Changed the oil (used a Bosch filter!) and removed the fender flares again. They are not going back on until they are painted or rubberized ... Link to comment Share on other sites More sharing options...
lint Posted April 30, 2012 Share Posted April 30, 2012 Used my sawzall to remove the seized rear swaybar end link on the passenger side. Soon I'll have to attack the driver's side. Link to comment Share on other sites More sharing options...
Trogdor636 Posted April 30, 2012 Share Posted April 30, 2012 Started taking out the front carpet so I can weld up the hole that is slowly evolving over my leaky (at one time, exhaust shop its currently not leaking?!? Maybe it rusted its own repair!) y pipe to mid pipe connection. Anybody know what gauge sheet metal gauge Pathy floors are? Link to comment Share on other sites More sharing options...
Kyle94 Posted April 30, 2012 Share Posted April 30, 2012 yesterday i finished my Taurus efan swap that i started on saturday! (wired a toggle switch yesterday and secured wires) so now i have a way to shut off the fan for water crossings and such. also replaced one of my cracked and rusty marker lights, now i just need to find one more. and today i started tearing apart my new found grill guard (the type that wraps around the corners) until i found rivets. trying to figure out how im going to take those out... this thing needs paint!! Link to comment Share on other sites More sharing options...
Trogdor636 Posted May 1, 2012 Share Posted May 1, 2012 today i started tearing apart my new found grill guard (the type that wraps around the corners) until i found rivets. trying to figure out how im going to take those out... this thing needs paint!! Drill them out. Link to comment Share on other sites More sharing options...
BuckRyp Posted May 1, 2012 Share Posted May 1, 2012 is it posible to clean egr valve? also is it hard to change fuel injectors? Link to comment Share on other sites More sharing options...
Kyle94 Posted May 1, 2012 Share Posted May 1, 2012 i think i need a better drill bit then.... lol. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 1, 2012 Share Posted May 1, 2012 aimed one of the wiper nozzles, filled the reservoir, have to pull the rear pump to see why it is not working. It was a big day !! Link to comment Share on other sites More sharing options...
therepairgod Posted May 1, 2012 Share Posted May 1, 2012 finally got my starter replaced after a nasty mudhole claimed it. under an hour, it helps to have air tools and every adapter known to mechanics, but not that hard all in all. now to replace the strut rod bushings... Link to comment Share on other sites More sharing options...
1994SEV6 Posted May 1, 2012 Share Posted May 1, 2012 I receive a box of parts ordered from Rockauto in the mail today. I only had about 20 mins, so I thought I could replace my fuel filter with time to spare. <--- LOL NOPE Took the fuse out, started up my truck. Let it die. Cranked it 3 more times to be safe. Loosened the clamps on the hoses. It took several sprays of PB and pulling as hard as I possibly could to get those hoses off. I got the IN hose off. Guess what? Dirty gasoline goes everywhere. NICE. I finally get the fuel filter all out. Here are the results Says Made in Japan Original, stock fuel filter? Most likely. (135k miles) But here's the real shocker After the filter shot gas everywhere, I quickly put it in the first thing I could find. I let it drain into a PB cap and... Link to comment Share on other sites More sharing options...
Towncivilian Posted May 1, 2012 Share Posted May 1, 2012 That's why I change my fuel filter yearly or so. Fuel filters are cheap, and I'd rather minimize any possible restriction to avoid the fuel pump working harder than it should. That reminds me - it's been a year and one day now since I last changed the fuel filter... better change it soon! I think I'll cut the current NAPA Gold 3023 (Wix 33023) open to see how it looks and measure the amount of filtering media. Link to comment Share on other sites More sharing options...
nunya Posted May 1, 2012 Share Posted May 1, 2012 I change my fuel filter every other oil change. My starter fried, not happenin today. Can't get a fresh one till tomorrow. He gets to hide at work for a night. Link to comment Share on other sites More sharing options...
Precise1 Posted May 1, 2012 Share Posted May 1, 2012 Nunya, you should tell people that you only change your oil once a year or it is false advertising... Changing a fuel filter every year is like changing your plugs every 10,000 miles but if you like throwing $ away, it is yours to throw... Today I broke the roof rack on the R50... B Link to comment Share on other sites More sharing options...
nismothunder Posted May 1, 2012 Share Posted May 1, 2012 Went too the gas station in it, I got my first ticket ever, for loud exhaust. Also got bitched at for it being too high (bumper to ground, mn is 28inchs) lack of fender flares, expired tabs, unreadable plates, lack of amber colared turn signals and lack of bumpers. Link to comment Share on other sites More sharing options...
