918pathy Posted February 8, 2012 Share Posted February 8, 2012 Changed my PCV Link to comment Share on other sites More sharing options...
918pathy Posted February 8, 2012 Share Posted February 8, 2012 Today had 4 new Falken rocky Mountain tires installed, 31/10.50's Let me know what you think of them, when you get some miles on them. Link to comment Share on other sites More sharing options...
Kingman Posted February 8, 2012 Share Posted February 8, 2012 LOL enjoying yourself Garrett? Link to comment Share on other sites More sharing options...
ahardb0dy Posted February 8, 2012 Share Posted February 8, 2012 Let me know what you think of them, when you get some miles on them. ok, will do Link to comment Share on other sites More sharing options...
MY1PATH Posted February 9, 2012 Share Posted February 9, 2012 (edited) LOL enjoying yourself Garret? I need a break, where are those rattle cans I forgot to buy? I feel like being artistic with someones manifold cover. this afternoon I went to the JY to pull a few things I missed for my MPFI conversion and got kicked out at closing time before I was done... I hate being on grave shift sleep schedule. Edited February 9, 2012 by MY1PATH Link to comment Share on other sites More sharing options...
E_ROCK Posted February 9, 2012 Share Posted February 9, 2012 Put 2004 tail lights in my early model 1999. The wiring harnesses were the same too so I had both sides done in about 5 mins start to finish. Link to comment Share on other sites More sharing options...
Reshma Posted February 9, 2012 Share Posted February 9, 2012 Removed the center piece on the dash to fix the falling in stereo system. Found a total Hack Job. Before Opened it up to find this... Cleaned it up as best I could because I was freezing After After cursing and screaming because I forgot about the cig lighter. Link to comment Share on other sites More sharing options...
1994SEV6 Posted February 10, 2012 Share Posted February 10, 2012 Removed the center piece on the dash to fix the falling in stereo system. Found a total Hack Job. why are they ALWAYS like that?!?! I don't even understand how someone can just randomly tape wires off and shove them somewhere like that. You would think it would actually be easier to do it properly based on the level of failure. Mine is the same way. What a headache. Link to comment Share on other sites More sharing options...
Towncivilian Posted February 10, 2012 Share Posted February 10, 2012 I wouldn't tolerate a hack job on any wiring. I went overkill with my stereo wiring. I soldered the wires, covered with electrical tape, then used zip ties to prevent the tape from potentially unrolling in the heat (I had no heatshrink available). Link to comment Share on other sites More sharing options...
1994SEV6 Posted February 10, 2012 Share Posted February 10, 2012 I wouldn't tolerate a hack job on any wiring. I went overkill with my stereo wiring. I soldered the wires, covered with electrical tape, then used zip ties to prevent the tape from potentially unrolling in the heat (I had no heatshrink available). That's a really nice job. and a great idea. I need to re-do my harness anyway Link to comment Share on other sites More sharing options...
devonianwalk Posted February 10, 2012 Share Posted February 10, 2012 Really? Link to comment Share on other sites More sharing options...
Towncivilian Posted February 10, 2012 Share Posted February 10, 2012 Replaced my front wiper blades with Bosch Steeltech blades. Link to comment Share on other sites More sharing options...
adamzan Posted February 10, 2012 Share Posted February 10, 2012 That really pisses me off when people cut the harness and don't use an adapter, especially for the antenna. The kit with both is like 15 bucks at best buy!!! Link to comment Share on other sites More sharing options...
Meandmy92Pathy Posted February 10, 2012 Share Posted February 10, 2012 painted the grill rattle can flat black... ...bout to head out for National Guard drill for the weekend... ...when I return on Sunday, the front fenders are getting under body spray on the inside and the tension rod and assorted parts that go with it will go on.......then all four tires will be back on the ground!!!!! Link to comment Share on other sites More sharing options...
edicer2 Posted February 10, 2012 Share Posted February 10, 2012 (edited) Washed it up and took some pics with the lift and new 32" tires...i ended up washing it and its still cold out and now my damn drive door wont close i just close it and lock it andi can still open it. Edited February 10, 2012 by edicer2 Link to comment Share on other sites More sharing options...
Reshma Posted February 10, 2012 Share Posted February 10, 2012 (edited) why are they ALWAYS like that?!?! I don't even understand how someone can just randomly tape wires off and shove them somewhere like that. You would think it would actually be easier to do it properly based on the level of failure. Mine is the same way. What a headache. Really? That really pisses me off when people cut the harness and don't use an adapter, especially for the antenna. The kit with both is like 15 bucks at best buy!!! you should see under the dash on the drivers side. I'll take a picture or two later. Edit: Because I'm only recently exposing myself to all this wiring in the truck. Some one answer me..I know that random black wire that ran to noting is supposed to go somewhere. I was wondering if someone could explain to me as to where it was supposed to go. I assume its the negative because if i touch metal with it i see sparks. I wouldn't tolerate a hack job on any wiring. I went overkill with my stereo wiring. I soldered the wires, covered with electrical tape, then used zip ties to prevent the tape from potentially unrolling in the heat (I had no heatshrink available). My dad wanted to send to truck to a workshop to wire the rear factory speakers I found I still had. I was like, "NOOOO! I saw the stereo wiring. No one touches the wiring in that truck other than me. Let the shop fix my fuel pump." LoL I would have went OCD like u did but i couldnt feel my fingers after opening it up the first time. I was cold as fsck. Edited February 10, 2012 by PathfinderIII Link to comment Share on other sites More sharing options...
tmoore4512 Posted February 10, 2012 Share Posted February 10, 2012 Finished installing the Xterra rack... Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 11, 2012 Share Posted February 11, 2012 Nice Rack! Swapped out my wiper blades... not only do they work, they don't sound like they're full of ducks. 1 Link to comment Share on other sites More sharing options...
adamzan Posted February 11, 2012 Share Posted February 11, 2012 Put my new neutral safety switch/range sensor in. Now I have reverse lights/cruise control/overdrive and the ability to start the truck the normal way. Also got it emission tested, passed with flying colours. Tomorrow I'll put the center console back in and start on the rear brakes, weather permitting. Link to comment Share on other sites More sharing options...
devonianwalk Posted February 11, 2012 Share Posted February 11, 2012 I too have to join the ranks in the "NPORA change your wiper blades" day. I too chose the Bosch blades (first time using Bosch). I put them on my Miata as well. Link to comment Share on other sites More sharing options...
teixeira Posted February 11, 2012 Share Posted February 11, 2012 I joined the club too, Bosch blades in place today. Link to comment Share on other sites More sharing options...
JamesRich Posted February 11, 2012 Share Posted February 11, 2012 Finished installing the Xterra rack... Your not supposed to put it on with the xterra emblem on it! Take that back off and paint it! Lol! Everything went ok? James Link to comment Share on other sites More sharing options...
1994SEV6 Posted February 11, 2012 Share Posted February 11, 2012 (edited) Put my new neutral safety switch/range sensor in. Now I have reverse lights/cruise control/overdrive and the ability to start the truck the normal way. Also got it emission tested, passed with flying colours. Tomorrow I'll put the center console back in and start on the rear brakes, weather permitting. OHHHHHHHHHHHH is this why I don't have reverse lights? I just soldered my park-neutral switch together for my trans swap. I haven't had reverse lights since. I always thought it was a wire in my auto trans shifter that I didn't reconnect. meh...it seems as if my center console is never going back in. oh by the way, how hard is it to replace a front fender/quarter panel? I tried to teach my friend how to drive stick and he promptly kissed someone's hand rail for their front stairs. Edited February 11, 2012 by 1994SEV6 Link to comment Share on other sites More sharing options...
Trogdor636 Posted February 11, 2012 Share Posted February 11, 2012 OHHHHHHHHHHHH is this why I don't have reverse lights? If you wired everything right, you can take out your back up light switch and manually push the button. Your back up lights should come on. If you put it back in and it doesn't work, the piece inside the tranny is worn. The switch is sort of a pain to get to, I cut a slot in a cheap 19MM socket so it looks like a O2 sensor socket. That way you don't Jack up the wire. Link to comment Share on other sites More sharing options...
ahardb0dy Posted February 11, 2012 Share Posted February 11, 2012 Your not supposed to put it on with the xterra emblem on it! Take that back off and paint it! Lol! Everything went ok? James another non sunroof xterra rack conversion? One day I'll get mine on, minus the xterra sticker, LOL Link to comment Share on other sites More sharing options...
