TRAIL DAMAGE
FLApathy
My first real damage...2 shattered KC Daylighters, both fogs cracked to hell and full of water and my exhaust system, sawz-all'ed off on the trail right behind the muffler :thumbsdown:
  • 2 months later...
  • Replies 98
  • Created
  • Last Reply
Top Posters In This Topic
you just cant stay outta this thread can you Dan!?
:D
Damnit....she was right.
Another long weekend at Rausch...another long list.
Shredded Tire
Busted Hi-Lift (it'll go up, but it won't come down...blast!)
Re-volumized Gas Tank...my 21.4 gallon gas tank only takes 16.4 gallons after I ran out of gas....funny, I distinctly remember putting 19.2 in before I left!
Broken Off, yes OFF, T-case Skidplate
Re-contoured front and center skidplates
Bent both rear lower control arms
bent/dented both front lower A-Arms
Fried the front Carrier bearing
Blew a strut mount
Smashed up my rear bumper
Smashed up my rear quarter panel
Smashed up my driver front fender
popped out my corner light
expanded the cracks on my Hellas
Passenger side slider got knocked backwards and the mounts are bent
AND my cruise control no longer works!
Damnit....she was right!
When are you wheeling again? Looking forward to your next additions...
I managed a bit of trail damage this summer -- dented my rear pass quarter panel & broke the tail light, slammed into a mud embankment. Was able to pop out the dent, and currently have tarp tape on the light.
The last couple years I mutilated my front BP Skidplate, it was no longer skidplate shaped. It has now been replaced.
Nicely done Dan!! I was going down a 20 mile washboard stretch at about 25 and noticed somebody kept following me (there are alot of oil rigs and turnoffs so it was weird this guy followed me for so long) anyway I finally got to my turnoff he flashed his lights and i stopped, then he got out and proceeded to hand me my side marker light. NOt really carnage but I have not been wheeling in a while and this is big new to me.
Shredded Tire
Blew a strut mount
I think Dan let Max drive???
I went off road once trying to get into a trout pond in the bush and bent the hell out of my bush bar. I learned two things that day...my tires are too small and always cross the ditch at an angle. :shrug:
Not a big list for me....yet :D
Right hand guard (couple of dents)
Cracked corner light
Lost rear mudflap (removed other one :aok: )
ECU+ego (relocated NOW)
Radiator (*shakes head @ self*)
Right rear dust cap (every damn time I go out WTF?)
Tread (a few chunks missing out of some lugs)
Smashed plastic in rear bumper towing Dan out (new bumper made)
Paint job (now looks like I've been dragged through the bush backwards)
Should be a skull shaped dent in the roof (at pace hit a crest that I didn't see coming, we both went up but the Pathfinder came down a little quicker. :lol:
Camp NL: 3 days of wheeling
Broke: One Pezzy
Sprained thumb, caught on the steering wheel when I hit a rock hard in a mudhole, and had some massive bump-steer. Happened so fast, I don't know what happened, I don't usually have my thumbs in the steering wheel for this exact reason, at the same time, I managed to smash the plastic off the bottom of the steering wheel.
went for my birthday on Saturday tore a cv boots blew out all my ball joints boots (grease EVERYWHERE) tranny whine is a little worse now from double clutching, leaky power steering, bent idler arm=i let go out the wheel my truck does a u turn on its own haha
well... I finally decided to tackle the problem of both of my front tires not holding air. I had a suspicion about the passenger side since I had jammed a branch into the bead during my last Paragon run. Sure enough, I pulled it off, pressureized it and threw some soapy water on it. Blowing bubbles from the bead right where I had extracted the lumber. I let the air out, threw the tire under the truck and used it's weight to pop the bead. I cleaned it out, cleaned it with a little coleman fuel and reinflated it to 40psi. No more leak. The drivers side was leaking around nearly 3/4 of the rim. I'm guessing I rubbed the tire hard against something but it was probably in a mud pit so I don't know exactly where it was. Same thing as the passenger side... popped it off, cleaned the dirt and debris out of the bead and reseated it. Again, inflated to 40psi and she held too. Rides completely different now. I got used to the 12psi in each tire.
  • 2 months later...
Dan, next time you better bring a spare truck with you... since you can damage just about anything :lol:
I should have this weekend!! In fact, I went out and bought a car today!
Broken:
(1) Warn Manual Locking Hub
(2) Left Front Wheel Bearing
(3) Left Front Outer CV Joint
(4) Passengers Slider (Off, yes, O-F-F off!)
Bruised:
(1) Ego
(2) Passengers Rocker Panel (In Three places)
(3) Drivers Side Front Door
(4) Drivers Side Rear Door
(5) Drivers Side Rear Quarter Panel
(6) Fuel Door
Smashed:
(1) Passengers Front Fender
(2) Passengers Rear Quarter Panel (Lower piece under stock rear bumper)
(3) Metal Reinforcement beam within Stock Rear Bumper
Bent:
(1) Severely Bent Right lower Rear Control Arm
