TRAIL DAMAGE
FLApathy
Hmm.
8 tie rod ends
4 centerlinks
3 idler arms
4 upper balljoints
2 lower balljoints
1 steering gearbox
2 stock UCA's
1 set of auto hubs
1 set of manual hubs
5 CV boots
2 alternators
1 fan shroud
1 passenger's side taillight
1 driver's side taillight
1 bent body mount support
1 dented DS lower rocker panel
1 dent in the PS upper rear next to the hatch
1 dent on the DS rear fender
1 dented stock front skidplate
Two punctured BFG tires
Scratches, of course
If I think of more, I'll post 'em here.
  • Replies 98
  • Created
  • Last Reply
Top Posters In This Topic
I think the people with short lists aren't trying hard enough
Since May 2005:
2 starters
3 alternators
2 sets of tires
2 rear axle shafts and associated bearings and bits
1 cv shaft
Centerlink
Tie rod ends
fan clutch
A/C system
Front Bumper
crushed fender
barb wire 'rash'
front signal lights
drivers parking light
busted snorkel
Auto Hubs
A ton of drivers side body damage
Usual dents and 'pinstriping'
There's still wood in the paint on the passenger side in an interesting pinstripe
2 sets of shocks
1 stock LSD
Removed all 4 mudflaps (still unreplaced)
Bent spare tire rack
Busted stud on spare tire rack
I will do two short lists of the most things I have damaged in one shot.
1st event was a fairly quick stop after hitting a stump.
Hit the stump (avoiding one thing to hit another) smack bang on the pitman arm at about 30~40 kph.
Broken....
Steering box. ($400 second hand)
Bent....
Tie rod. (Both)
Idler arm
Chassis.
Other damage....
Drag link.
NOTE: The the only reason I included this event was because of the cost to replace the steering box. If the steering box was not broken it would have been a normal outing.
2nd event was a bad landing over a jump.
Broken....
Driving lights (Both)
R/H head light
Coner light. (Both)
Steering column. (collasped)
Spot welds.
Bent....
R and L front guards.
R/H tie rod.
Radiator support panel.
Other damage from this one event....
Drag link.
Broken battery clamp. (Battery moves into the power steering pully.)
Power steering pully rips apart battery spewing acid everywhere.
Acid chewed through my belt tensioner. (was resin now is steel).
Acid chewed through my drive belt.
Acid ate away my flexy conduit. (wires ran through it)
Acid ate away my paint on the inner guard, steering box, engine mount, power steering pully, rocker covers, hood, after market UCA and chassis.
I think it was easier just to have two event lists otherwise we'd be here all day.
Wuh oh....
Just got home from a hard, long weekend up at Paragon, and I've got a "few" items to add to my list.
Drivers Headlight
Windshield
Drivers side front fender (tree)
Rear bumper (rocks, so I was told)
Driving light
Fog light (MIA)
Missing a couple Thule trim pieces.
Oh, and the freakin sickest scratch ever!
Oh, and my BlackPanther skids broke a rock....
BlackPanther 1 - Rock 0 -bounce-
If you're wondering where your posts went - no, I didnt PM you, I just nuked em... too much chit chat - please keep on topic... P...
Looking forward to your pics Vengeful... B)
Pezzy,
How did you bend the entire subframe? :clap:
I wish I knew.
Wheeling - but when - I have no idea. I can only assume in one of those moments of GIVER... I noticed after that weekend my steering wheel was pointing right, but my truck was pulling left. Badness.
Chut uppa you face!
Fender Lip where tire caught and bent it.
Cracked Hella 500 Lens
Turn signal housing mounting tab broken off
Chipped and Cracked headlight housing
Cracked windshied
Dented fender
Bumper Mess...
Big ass scratch that runs halfway across the liftgate, through the tailight, down the side of the truck and ends in the wheelwell
(fixed broken link)
Edited by Pezzy
Alright lets get my list together from offroading upnorth in a nice big snowstorm... lol
-Skid plate fell off (lost it somehwere, not sure where... by the time i returned on the trail it was recovered in snow)
-Mudflaps got ripped off... (heavy wet snow + rusted fender mountings)
-Front fender bent...
-Back bumper fell off lmao... friend really sucks at spotting.... :crazy:
-Power steering hoses
-Passenger side rocker panel was ripped apart almost (rock under the snow and one rusty rocker panel=lots of pain to my truck)
-lost a floormat some how...haha
-Broke the trimming on both headlights
-1 tie rod
-Exhaust gaskets
This trip was hectic... first offroading trip Ive ever had and it cost me a fortune lol
Im not returning offroading untill I get my body shop man to overhaul my truck in spring... to much rust for offroading...as you can see.
Thanks
Jason
Well...just found more.
Turns out that BOTH front mount bolts for my passenger side Slider broke off, and the mount on the slider is slightly bent.
I'm gonna drop the sliders sometime this week and drill out the old bolts, then use grade 10 replacements. Apparently grade 8 arent strong enough. :shrug:
First trip to Paragon and I can add to the list.
- bent driver side step rail brackets
- dented driver side rocker (in front of step rail, and in front of rear tire)
- possibly new scratches, but unable to determine which are new
time for some sliders!
Various scratches and small dents
1 engine mount (i think the 1st on the list)
1 Chipped windsheild- turned into a huge crack
1 cracked rear passenger cargo glass
1 Back Bumper
1 exaust tip
1 shock
2 tie rod ends
2 lower ball joints
1 32" kumho venture MT
  • 3 months later...
ah yes, I guess I can add to my list, a mutilated fender (still cant open the pass door) and a broken shock mount. Thanks goes to some kickass wheeling @ the Nor'Easter!
And a whole lot of Arizona Pinstripes. :D
I hear ya. I bet they're alot like the NM pinstripes I got at Kilbourne Hole. White-thorn mesquite bushes are unforgiving.
