Rebelord Posted March 5, 2015 Share Posted March 5, 2015 Pcv stuck open seems very plausible. Considering it's cheap and easy to do on the 3.3. Id swap it out. Sent from my Moto X Link to comment Share on other sites More sharing options...
Nissanland Posted March 5, 2015 Share Posted March 5, 2015 The 2004 had new shoes installed. 265/65R17 Cooper RTX. Yes, they do fit!! same size I run on my 95. They are basically 32 in tires. I run wrangler duratracs. How are those cooper's. Almost went with them myself. Link to comment Share on other sites More sharing options...
k9sar Posted March 5, 2015 Share Posted March 5, 2015 added more oil so my bad lifter would shut-up. Link to comment Share on other sites More sharing options...
ShawnTRD Posted March 5, 2015 Share Posted March 5, 2015 added more oil so my bad lifter would shut-up. Because your losing oil? Link to comment Share on other sites More sharing options...
k9sar Posted March 5, 2015 Share Posted March 5, 2015 yep. I have a leak and when the level gets down a bit, my bad lifter starts to make a helluva racket Link to comment Share on other sites More sharing options...
CDN_S4 Posted March 6, 2015 Share Posted March 6, 2015 Drained front diff fluid. Was black sludge. Nice fresh slime green fluid went back in. Rear was not quite as easy. In fact, rear was a no go. Both drain / fill plugs were so softened up by rust that they both stripped completely. No dice. This tells me they have probably not been undone in 15 years. And neither has the fluid been changed. Any ideas how I might get them out??! Link to comment Share on other sites More sharing options...
5523Pathfinder Posted March 6, 2015 Share Posted March 6, 2015 Ordered new headlights, upgraded harness and new right front corner lens. I can't wait to see better at night! Link to comment Share on other sites More sharing options...
Bubbley11 Posted March 6, 2015 Share Posted March 6, 2015 Put a new air filter in it after I found my old one was clogged big time. Link to comment Share on other sites More sharing options...
Nefarious Posted March 6, 2015 Share Posted March 6, 2015 Drained front diff fluid. Was black sludge. Nice fresh slime green fluid went back in. Rear was not quite as easy. In fact, rear was a no go. Both drain / fill plugs were so softened up by rust that they both stripped completely. No dice. This tells me they have probably not been undone in 15 years. And neither has the fluid been changed. Any ideas how I might get them out??! if it's totally stripped out, I would weld a short bolt to the drain plug with a couple of spot welds. The heat will break the seal and the bolt will allow you to turn it out with a breaker bar. The drain plugs are usually protruding from the housing by 1/8 to 1/4 inch, so it's easy to avoid getting any weld bead on the housing. It's a last resort, but if you totally stripped out the drain plug then it's a surefire way to do it. Link to comment Share on other sites More sharing options...
CDN_S4 Posted March 6, 2015 Share Posted March 6, 2015 if it's totally stripped out, I would weld a short bolt to the drain plug with a couple of spot welds. The heat will break the seal and the bolt will allow you to turn it out with a breaker bar. The drain plugs are usually protruding from the housing by 1/8 to 1/4 inch, so it's easy to avoid getting any weld bead on the housing. It's a last resort, but if you totally stripped out the drain plug then it's a surefire way to do it. Yeah I read up on that over on Nico. That's what I'll have to do. Been searching for replacement plugs and that isn't as easy as I had thought. My local Napa can't even order them. I'll try my local Nissan dealer but was wondering if anyone knows an online source. I could find some nissan ones but I can't know the size for sure as I don't know that part number. Thanks Link to comment Share on other sites More sharing options...
Nefarious Posted March 6, 2015 Share Posted March 6, 2015 You can look up factory part numbers at courtesyparts.com. They have all the parts diagrams listed and the corresponding oem part numbers for you to order from your local nissan dealer. Link to comment Share on other sites More sharing options...
RedPath88 Posted March 6, 2015 Share Posted March 6, 2015 I'll try my local Nissan dealer but was wondering if anyone knows an online source. I could find some nissan ones but I can't know the size for sure as I don't know that part number. Thanks Send a PM to Alkorahil, our friendly neighborhood Nissan (dealer) parts guy! You might include your VIN to speed things along as he may ask for it anyway. Link to comment Share on other sites More sharing options...
CO_pathfinder Posted March 6, 2015 Share Posted March 6, 2015 Going to flush my diffs and transfer case today. Also, hopefully will bleed my brakes. Oil change too, yippee Link to comment Share on other sites More sharing options...
kdj Posted March 6, 2015 Share Posted March 6, 2015 Hope your drain plugs are better than CND's! And your bleeder screws are better than the last ones I tackled. 1 Link to comment Share on other sites More sharing options...
Chiefpathy Posted March 7, 2015 Share Posted March 7, 2015 Replaced the strut rod bushings and driver's side door hinge pins and bushings. Replacing the strut rod bushings was pretty easy, the door hinge pins and bushings on the other hand were a PITA! I was successful at both though. Last weekend I also tackled the passenger side exhaust manifold broken studs. Big job, but it went pretty smooth, and no more tick, tick, tick! Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 7, 2015 Share Posted March 7, 2015 Replaced my EGR valve, finally. The old one wasn't broken, but the threaded bung was stripped. This made putting the new/used one on fun, as some of the threads were still embedded in the flare nut bit that screwed on, and were pretty well fused in. I ended up cutting the flare nut about 1/4" shorter with the angle grinder because I was out of good ideas. It worked! Link to comment Share on other sites More sharing options...
CO_pathfinder Posted March 8, 2015 Share Posted March 8, 2015 Got a call at midnight from a friend, said he got his Toyota MR2 stuck.... boy he wasn't kidding. Took a wrong turn on a dirt road and ended up sliding down a hill into a 6 inch deep muddy mess. Thank god for our Pathfinders having 4Lo... drug him through a mile of that @!*%, took forever because he kept sketching out and slamming on his brakes, and I was struggling to maintain traction as it was lol 1 Link to comment Share on other sites More sharing options...
Terranovation Posted March 8, 2015 Share Posted March 8, 2015 Did the oil change and new filter, cost $103 for 10 litres of oil and the filter! $48 for the trans fluid! So I didn't buy the trans fluid. Going to have to wait for next week. Link to comment Share on other sites More sharing options...
xterra Posted March 8, 2015 Share Posted March 8, 2015 Dropped the AC blower motor because I couldn't take the "whirring" noise anymore. It still amazes me how much noise a pine needle can make... 2 Link to comment Share on other sites More sharing options...
Jrodmxt Posted March 9, 2015 Share Posted March 9, 2015 1995 Pathy LE/SE : Front wheel bearings. (Inner and outer) repack. New sway bar linkage and bushings. New front and rear shock absorbers. Upper and lower ball joints and filled all grease fittings. Oil change. K&N filter cleaned. Needless to say after 1,151,000 miles my pathy was in dire need of these things. And it rides and drives like it did when I first bought it back in 1999 with 89,000 miles on it. It's been the best thing I've ever owned. Never left me stuck in mud or snow. Never left me stranded. Been to 36 states and always reliable. It's a love affair. It truly is. 1 Link to comment Share on other sites More sharing options...
k9sar Posted March 9, 2015 Share Posted March 9, 2015 pissed on it... just because Link to comment Share on other sites More sharing options...
Jrodmxt Posted March 9, 2015 Share Posted March 9, 2015 pissed on it... just because That's mean. Link to comment Share on other sites More sharing options...
RedPath88 Posted March 9, 2015 Share Posted March 9, 2015 plugged it in Link to comment Share on other sites More sharing options...
CO_pathfinder Posted March 9, 2015 Share Posted March 9, 2015 Its not a laptop! Link to comment Share on other sites More sharing options...
RedPath88 Posted March 9, 2015 Share Posted March 9, 2015 Maybe not, but it does have a power plug Link to comment Share on other sites More sharing options...
