CO_pathfinder
Everything posted by CO_pathfinder
  1. Anybody have any idea what the size of the wheel bearing lock washer screws are? I had to drill all 4 of them out when replacing my ball joints - some shop at some point stripped them all and just left them there
  2. Ended up unbolting the centerlink at the pitman and hammering it down for an extra inch of clearance; made life 100 times easier and only took 15 seconds after I did so. Thanks for the input guys
  3. Anybody have tips for yanking the starter over the centerlink? mines stuck on it and im trying not to unbolt the pitman
  4. Most things can't be replaced/repaired by Joe now because of tech advancement. Its a good thing, I promise. Don't know if the starter is OE or not but its caked in oil so I would venture to guess the answer is yes. Ill give it a hammer smack and see what happens.
  5. Clarification on my issue starting - I get the "single-click no-crank" issue, which on a manual can be caused by the starter, the starter solenoid, or the starter relay (and only these things, right?) It started with a very slow crank in a parking lot, followed by half-cranks until the starter stopped responding in another parking lot.
  6. Went back in, and upon second inspection noticed something.. the BWD replacement injectors (along with the Hitachi OEM exact duplicates) DONT come with the 3rd of 3 O-rings. There is the ring that seals intake from injector, injector from top of fuel rail, but there wasn't a replacement O-ring for the bottom of the fuel rail leading to the intake port. Not sure if it was because of this missing O-ring or if the injector actually was bad, but the truck ran like a top after doing so. However, the rich condition caused two other things to happen: IACV is now clogged and truck doesn't like load at idle as a result - just need to degunk it. Hard cranking starts when the injector was wonky ended up killing the starter... yippee... Haven't ever even considered looking at replacing this part, so it looks like I'm going to the FSM and to the forum archives. On that last note, is the starter a job I can expect to do myself in a few weeknights after work? Or, should I pony up the $$ and make it a shop's problem. Looking for advice from those with experience.
  7. Considering that it didn't do this before I replaced my injectors last weekend, I'm leaning towards it being a faulty injector. Hopefully the parts store will honor some sort of warranty policy should that be the case. I'll find out this weekend
  8. Pulled plug, fouled like crazy. Replaced the plug and within 20 miles it was fouled again, missing the whole time. No codes, new plug wire didn't change anything.. noticed that when I pulled the 2nd fouled plug, it was clean on one side and blackened on the other... Maybe the new injector is bad in some way?
  9. Replaced injectors , screwed up a couple of the vac lines, truck ran like... my truck. Put vac lines where they belonged, truck ran the best it ever has for me.. for one day. Current status: Hard starting and a constant miss on cylinder 3. Its spark related, as pulling the wire doesn't change the miss but does mean rich smelling exhaust (which at least means my new injector isn't buggered) Expected solution: PULL CODES FIRST, then pull the plug, regap the plug, clean the plug hole, try a different wire, clean/replace distributor. If that doesn't fix it, I might choose to kill it with fire. As always, input is always appreciated - btw, truck recently rolled past 100,000 for the first time.
  10. The first grinding noise gets faster as i speed up while turning.
  11. Some new noises coming from my Pathfinder but I can't tell what they are because they only occur while I'm driving. First noise is a slight grinding/metal on metal rubbing sound when I turn the wheels to the left, usually between 10-30 mph. Wheel bearing/hub? Second noise is a very similar noise, almost like a bad bearing, that only occurs in 3rd gear at around 3k rpm (haven't noted the speed).. How do I check my wheel bearings in my own driveway?
  12. Avoid the BFGs anyways, as people have been reporting a bunch of sidewall blowouts recently at highway speeds
  13. I spent the money on gaskets for my manual hubs instead
  14. On the topic of wipers, I usually just spend the amount of money that I would on two, on just the driver side, so that I can see extra good.
  15. Dropped a tin of Altoids while I was driving yesterday and they spilled everywhere. When I reached under the driver floor mat to grab a couple, I almost burned my hand the carpet was so hot. Checked underneath when I got home and lo-and-behold, the y-pipe gaskets were blown through on the top side. Replaced them (took forever), and then went a step further and wrapped my exhaust header/collector all the way back to the cat. Should deal with heat a little bit better, and the weirdness of my exhaust sound is gone now. Hopefully will get some better gas mileage, as the leak was before the O2 sensor, and maybe this will help with my rich fuel mixture. Also, changed the oil with Mobil 1 and a PureOne filter. Fun news: a friend of mine hooked me up as a surprise for helping him move with a new subwoofer/amp setup to replace the one that was stolen 2 years ago. He found a discontinued JBL W12GTi MkII 12" at a warehouse supplier (4000W power handling at 3ohm), and got me a 3000W amp with 1500W RMS handling.... Installed it at 3ohms and it frothed my gas so badly that my truck started to have issues running. So I rewired it at 12ohm, and holy cow am I impressed. Bad news: found 4 separated screws in my tire, including 1 in my sidewall. No serious issues, just annoyed by the fact that I now have to wait to drive my truck until the tire store can get a replacement in stock. Next steps: Buy new Sway-Away torsion bars and install, along with my Rancho coils, then get an actual alignment, and not one of these cheap-ass "free alignment with $100 purchase" deals.
  16. On the topic of money in our Pathfinders, whenever I drive over washboard, I can hear coins jiggling everywhere
  17. What quantity defines "too many?" They are a form of expression. I think I just need a new cable --- mine seems pretty stretched out
  18. Is it just my truck or does everybody elses ebrake suck always. I apologize for my use of poor grammar there. Here's my truck to make up for it.
  19. Lol already got that fan-whine always so a little drone wouldn't be bad.. too bad its leakin at the y. And its a BRAND NEW Y PIPE.
  20. I've given up on this shop completely. I asked for several specific things to be done when they did the exhaust header back, and every single thing I asked for was ignored and later addressed by saying "I can't make that work without also spending xxxx on xxxx." It was too much of a hassle to get them to do anything so I'm just going to do it myself... It would be great if they hadn't side piped it under the trailing arm bracket because now the first rock I drive over is going to rip the whole thing off
  21. Resbum, thats a heck of a lot of work. You should be proud Cut gaskets for my warn hubs, and felt my feet get hot because my new exhaust has a leak Deciding whether I want to deal with it myself or if I want to take it back to the PITA shop that did it..
  22. Anybody know where I can get/ how i can make some gaskets/seals for my manual hubs... the ones on the truck i pulled them from were toast, and I don't feel like adding more grease every 200 miles as it slowly leaks out on the highway
