nismothunder
Everything posted by nismothunder
  1. In the words of a black dude, Bitchs be trippin'
    1. nunya
      nunya
      tie your shoes then?
    2. WyKi
  2. In the words of a black dude,
  3. In the words of a black dude,
  4. Who you I would get so many honks and waves when peeing on the side of the road. I even waved with out hands.
    1. Tungsten
      Tungsten
      been there done that
  5. Nope, what they dont filter is too small to harm the motor, plus that is why you have that thing called a oil filter. Now if it is something like one of those F1 motors that dont use piston rings and run at 22,000rpm it might be diffrent. But I believe most of those run a similer filter. Thinking of it, I dont believe those big nitro methane snorting 4 second drag cars even run a air filter. But they are literally rebuilt after ever race. Well tore down and inspected at least.
  6. I hose and soap if off, let it dry, spray what I think is right amount of oil on (until it looks like new) and then reinstall. I've never, ever had a problem with it. Now I only spray the outer edge and not both. But I highly dought oil on the mass is bad for it. Considering that this tale has been going on for years and theres no facts to back it up other then people complaining because there in that 90 percent that would die with out warning hazards placed every item.
  7. 430 am wake up, 5am get on road, 640am get to destanation. 10am climb in big diesel truck. 3pm leave, 5pm get home and die.
    1. nismothunder
      nismothunder
      For the next 2 weeks.
    2. theexbrit
      theexbrit
      That's a heck of a day, I'll never complain about my job again!
    3. nismothunder
      nismothunder
      Day, 147.6 miles driving, plus 3miles city in the big diesel truck. I off roaded itthe rest of the day.
  8. Every Fram air filter I've ever bought has been made in Canada. Most of there oil filters too now that I think of it. But I only buy K&N air filters now, I mean they never wear out and they have a 1,000,000 mile warenty agaisnt wear and defects.
  9. Fuller why you grind when I shift you?
  10. Vortec 350 huh. Maybe I'll have to put some TPI heads on mine to keep up. In other news I didnt do anything to it lately but Kyles been bugging me so I thought I'd share what I've been doing. Torn between finding black carpet or bedlining the inside (think black/dark grey instead of the darkgrey/light grey it is now). Plus I'm not sure if I should get a second bucket for the front only or if I should have rear ones as well. But for that I may have to cut the cage to install it. I want diffrent tires, the claws have been a let down big time compaired to past M/T's I've had. Plus the time to acutally finish it wouldnt hurt since I start school monday.
  11. Half & Half ice tea/lemanade is great.
    1. tmoore4512
      tmoore4512
      Who wants Arnold Palmer?! Arnie Palmer time!!
    2. nismothunder
  12. The best bet to check for bad a u-joint is blocking the wheels and leaving it in neutral. That way you get the real story to if you need U-joints. Since shutting it off and leaving it in gear can load the shaft and make the U-joints seem fine. You dont even to block if your on a level piece of ground because the joints will show slop before you will move the car.
  13. Or just about anything fuel related. It could be the pressure regulator or the pump dieing.
  14. Drain the fluid and see if theres any metal/clutch shavings in it. Its rare for problems but the LSD is weaker then open diffs.
  15. Played 8 tracker racer with my dad in a 47 year old chevy.
  16. Hell with chrome, I wouldnt mind getting that blond home.
  17. Ignition moduel? On my camaro thats a common problem but I dont remember if the fuel pump would kick on. I do know the windows would still work. Not really a Jeep fan so I'm not any real help. Does it Click or does it do nothing at all. Come to think of it my old Crown Vic had the same problem as you discribe but it was a wire leading to the ignition moduel. I know that ones pumps never turned on. Just for laughs try to jump it if you can with a screw driver.
  18. There have been people who've done it for $400... But there found a junk yard doner and pulled everything themselves. I figured you could use a little something...
  19. Cable coming loose? Even if the alty locked up it should still run off the battory with out interupting the radio. It could be that the 2 things arent related but happen at the same time.
  20. Why am I still tired?
