221
Everything posted by adamzan
hose it down with some kind of lock lube and de icer. Common occurrence here in Canada lol
I hear ya. It took me several weekends to get all of mine done!
If you do it one link at a time you could certainly leave it on the ground.
How would anyone ever know if you welded it, doesn't QC only inspect if it's coming in from out of province? Ontario you only need an inspection when it's out of province or changes ownership.
The front shocks definitely are, the rear might be a different length but will bolt up.
When I had to do mine, I took the sunroof glass and new seal to a glass shop, they charged me like $20 cash to install it, still good 5 years later!
Try living where I live, where it routinely gets to -30. The 170F stat in my 95 just would never cut it so I put a 180 in it. Just enough difference to actually de-ice the windows.
It should have the instructions for that on one of the sun visors. Mine does. It's nice to take out in the summer time!
It's really weird because you'd think that would cause higher than normal temps... My parents r50 when the water pump went it would overheat (but not completely boil over) at speed because the impeller was slipping. You say the sensor tested good as well, is the wiring ok? No crazy resistance from the connector to wherever it ends in the harness? Sometimes moving old wires around makes problems lol. Have you thought about installing an after market temp gauge for testing?
170F is pretty low temp wise, Nissan seems to run the VQ hot, like 95C hot. I didn't see it mentioned anywhere, but was this an oem thermostat or an aftermarket? I have seen aftermarket ones test fine but be just out of the OE spec enough during operation to cause these problems. The Nissan thermostats can handle varying the flow better vs the aftermarket ones that seem to just open full blast at the rated temp. My Xterra (VG33ER not 4.0) will barely get up to the factory rated 170F temp in the winter here when driving. I have to cover half the rad if not more with cardboard to get good heat.
Yeah, the ssl cert for the site is expired. I'll PM Redpath about it.
Mine did this and it was too much toe in. Have the alignment re checked, it would be amplified x100 in 4wd.
If it does a 360 it's likely the plastic bits inside the door have broken, it was kind of common, take the door panel off and look.
Where is the fuel pressure regulator on a '93?
adamzan replied to Flysilly's topic in 90-95 WD21 Pathfinders
I'm pretty sure they are the same for the VG30 and 33. You can also check nissan part numbers at courtesyparts.com. -
Pulled mine into the garage for the winter. I've committed myself to a DIY restore of the thing. So that will start with replacing the crunched in drivers rear quarter behind the tire. Had another member here slice the part off of their parts rig so hopefully that goes okay. I will post pictures of course.
Glove box won't open. Any suggestions?
adamzan replied to BlueKrogan's topic in 90-95 WD21 Pathfinders
Since you're in Ontario, I have a spare glove box from my parts truck that you can have, if you end up breaking yours. From my 94 round dash. -
It is the door lock timer box itself. Mine did it as well. Only in the cold weather, it was due to the solder joints cracking on the board. I re flowed the solder on them and never had another problem. IIRC it is behind the panel in the drivers side cargo area. Just have someone actuate the locks and you'll hear it.
- 1 reply
- 1
ISO Information from an owners manual
adamzan replied to gamellott's topic in 90-95 WD21 Pathfinders
I know some of them didn't come with the bulb for the engine light or the label for it, but apparently if you take the cluster out and fill in any missing bulbs, one of them is actually the engine light. Dumb, I know. -
While it sounds like it is the issue they have, it certainly isn't a common failure point on the 2001+ RE4R01A. There are loads of first gen xterras around with 250K+ on the original transmission. When my 1995 lost reverse it would work fine in the cold when the fluid was thick. But I believe it is more a varnish issue than broken parts, simply because adding a can of seafoam trans tune would literally "Fix" it for months at a time. OP I would try flushing the fluid out and testing the line pressure. If it's low, you know where to go from there.
The xterra hoses are pretty different, I have an xterra and a pathfinder. Pathfinder uses banjo bolts while the xterra has a flared fitting, like a large brake line to the steering box. A lot easier to just use the adapter (which really is just a new balancer your pulley set bolts to), than futz around with making custom ps and ac lines. Plus I didn't have to discharge my aircon. I just want what drops in the easiest and won't be too much hassle for anyone in the future who has to order parts or work on it.
Did you use an oem distributor or an aftermarket? The aftermarket ones are dodgy at best, I had to warranty mine 3 times before I got a good one. The 2nd one lasted 10km...
