221
Everything posted by adamzan
Can you share a pic of the connections at the battery? I want to see what the mechanic did. Sounds like they caused more harm than good.
Yea that sounds like a failed transmission cooler line, should be fairly easy to fix. Maybe on turns the fluid is so low that it introduces air into it somewhere. They are like a differential with a vent, so not a complete airtight seal. Any dexron 3 compatible fluid will work, but the Nissan Matic D is the best fluid for these transmissions.
Moog parts used to be great 15 years ago but the quality has taken a serious nosedive. Ever since they had that massive factory/warehouse fire.
Is the fluid red or brown, does it have a rancid smell to it?
Replaced alternator belt on the 2004 Xterra today. It flew off in the parking lot at work, but 2 little cords held on and I got home on that. Not fun in this cold, my hands were sticking to the pulleys and tools!
Wheres all the seasoned npora guys at. SC stuff
adamzan replied to alexg89's topic in 96-2004 R50 Pathfinders
Would it be possible to re pin the ecu connector or something like that? A bit more work but idk. -
I know that feeling. I have to keep a battery maintainer on it now otherwise it will just die.
Mine sits a lot assuming yours does as well? I had similar symptoms and just attribute it to the flywheel having rust on it. It will shudder on take off also.
I know I had my old 1994 way over advanced at 20 or 25 because the distributor was messed up. I didn't know any better at the time but damn did it ever have a lot more power lol.
I would also switch the automatic hubs to manual ones if you're going to lift it and wheel it. The automatic ones are good for daily drivers but on the trail they can unlock when backing up/rocking the truck and you'll lose drive to the front wheels at the worst possible time, lol.
It will increase the CV angle but the best part about the wd21 is the hubs are unlocked when not using 4wd so they are not spinning 100% of the time like newer vehicles do. I have had the same lift as that on my rig for going on 14 years and still have the same CV shafts. You can also get differential drop down bushings to lower the front diff to compensate.
IIRC it is a fine thread pitch, like 1.5 or 1.75 and no one around here had one at the time (it is also a nylock nut). I ended up getting it at Nissan but I didn't have to pay shipping, just picked it up from the dealer.
Nice looking truck. Mine is also a black 95 SE. Bought it from a lady who moved to Toronto from North Van in 2007, so it only saw a couple of Ontario winters. The issue with whole fan thing is that the stock fans work great for everything but these rigs are pushing 28 years old at the youngest, all the foam and crap around the radiator and condenser to keep the airflow going across is long since rotted away. Also if you have the bottom half of your fan shroud missing that doesn't help either, most body lifted ones are missing it. So I guess you can go e-fan if you want or try to rebuild the stock setup.
I've overheard the same thing in Ontario for a few years but nothing has come around yet. It's funny because the most derelict cars/trucks I've ever seen have all come from the QC side lol.
What are the symptoms?
The marks on the pulley only go up to 20 degrees. How did you confirm it was at 35? Check the service manual for the procedure, starts on page 32. You have to disconnect the TPS and do some rev up malarkey first. https://www.nicoclub.com/service-manual?fsm=Pathfinder%2F1997%2Fec.pdf Hope this helps.
Seems to be discontinued at Nissan. You might have some luck calling dealers to see if any of the warehouses have old stock leftover. Otherwise you'll have to go to a wrecking yard.
I would not do that in these transmissions. They have enough problems with people using GL5 and a thin fluid like that in an older design transmission would lead to higher wear more quickly. Personally I use redline MT90 and it has kept mine alive for the 10 years I have owned it (had auto pathy's before then). This is just my opinion of course.
Glove box won't open. Any suggestions?
adamzan replied to BlueKrogan's topic in 90-95 WD21 Pathfinders
It got up a bit higher than that: -
Configuration for Sleeping in the Rear - up to 9' of space!
adamzan replied to mike1305's topic in 90-95 WD21 Pathfinders
It really is great. Back when my 95 was my daily I did this all the time for camping. Also get some screen and magnets, you can leave the windows cracked this way and not wake up to a nasty humid mess. -
I have flushed mine before and it helped a bit, my truck the previous owner had dumped stop leak in it. That crap is known for plugging heater cores. You have to flush it in the opposite direction of coolant flow as the sediment in there will be settled in the core. If I had to do it again I'd take it to a shop that has one of those power flusher things that hooks up to the air compressor. They work really well.
Where is the fuel pressure regulator on a '93?
adamzan replied to Flysilly's topic in 90-95 WD21 Pathfinders
The only beck arnley part I had a bad experience with was the wd21 cooling temp sender. I went through 3 of them from rock auto before I went to nissan and bought an oem one. -
Damn that looks great. Wish I had kept my old VG33ER, would have been a great candidate for my wd21...
That happened to mine as well, not sure why but mine got stuck on hot instead which sucks in the summer lmao. These trucks it's normal for the temp gauge to only go up a 1/4 of the way. Take a temp reader at the upper rad host, if it's around 170-180F fully warmed up your thermostat is fine. -
Yep, gotta do the same on my xterra tomorrow. The damn doors freeze shut after every drive.
