88pathoffroad Posted March 7, 2006 Author Share Posted March 7, 2006 Post fixed. You're welcome. Link to comment Share on other sites More sharing options...
zack1978 Posted April 3, 2006 Share Posted April 3, 2006 What does a new MAF for a 1995 cost at Nissan? Zack Link to comment Share on other sites More sharing options...
94extreme Posted April 3, 2006 Share Posted April 3, 2006 call your dealer?! Link to comment Share on other sites More sharing options...
k9sar Posted April 4, 2006 Share Posted April 4, 2006 MSRP is $488.19 Link to comment Share on other sites More sharing options...
93blkpathr Posted April 6, 2006 Share Posted April 6, 2006 MSRP is $488.19 What a bargain :oops: $$ Link to comment Share on other sites More sharing options...
hookemdevils22 Posted August 6, 2006 Share Posted August 6, 2006 Be careful when cleaning out your MAF. I cleaned out mine using CRC's MAF Cleaner, and my truck immediately started running like sh*t. It wouldn't accelerate, and would surge then nearly die at idle. Same exact thing happened to my buddy and his 4.0L Ranger. We changed the sensors and everything's running fine now. Link to comment Share on other sites More sharing options...
WRL69 Posted October 22, 2006 Share Posted October 22, 2006 Hello guys, easy exercise. I read this post yesterday and just today did it. I attach a MAF pic of my 93' SEV6 A/T (100 kmil). It was clean. Regards, Link to comment Share on other sites More sharing options...
adamzan Posted February 14, 2008 Share Posted February 14, 2008 Just skimming through this and didn't see posted what I thought made removing the bottom screw A LOT easier. Unhook the maf and open the air filter box, you can use a regular screwdriver that way and get way better leverage. Feel free to me if this has already been posted. Link to comment Share on other sites More sharing options...
Nissyota88 Posted April 17, 2008 Share Posted April 17, 2008 mine was dirty Link to comment Share on other sites More sharing options...
Nissyota88 Posted April 18, 2008 Share Posted April 18, 2008 88.. i have been told its bad to clean your mafs with carb cleaner... after i did it Link to comment Share on other sites More sharing options...
Ramon Posted October 10, 2008 Share Posted October 10, 2008 How often you recommend me to clean it ? Link to comment Share on other sites More sharing options...
MY1PATH Posted October 11, 2008 Share Posted October 11, 2008 good question. I soppose it would depend on driving conditons (dusty) and your filter. last I cleaned mine it only left a few very thin black marks on the cotton swab and I don't think I'd been done b4. My guess would be every few years wouldn't hurt. anyone? Link to comment Share on other sites More sharing options...
Precise1 Posted October 12, 2008 Share Posted October 12, 2008 Considering how clean they were in my 2 pathys (and that I doubt anyone had ever done it before), I'd say several years interval, but that would of course change if you drive in harsh conditions. B Link to comment Share on other sites More sharing options...
Nismojunky Posted October 28, 2008 Share Posted October 28, 2008 88 that is the cleanest engine ive ever seen mines covered in about 1/4 of mud every where Link to comment Share on other sites More sharing options...
bitemedoughboy.com Posted October 28, 2008 Share Posted October 28, 2008 88.. i have been told its bad to clean your mafs with carb cleaner... after i did it check youre auto parts stores, there is a cleaner made specifically for AFM's it leaves no residue and dry's uber fast. Link to comment Share on other sites More sharing options...
westslope Posted February 23, 2009 Share Posted February 23, 2009 Just cleaned the MAF because I thought the engine was idling a little high, just under 1,000 rpm. Thought I could reduce the idling speed by cleaning the MAF. The alcohol-tipped Q-tip sopped up a little bit of dirt but not much. RPMs did not change noticeably. (They drop if I turn on the air-conditioning or turn up the ventilation fan.) I should check the gap on the plugs.... Great thread 88. Thanks. Bernard's pictures were particularly useful. Link to comment Share on other sites More sharing options...
Pinip Posted March 26, 2009 Share Posted March 26, 2009 (edited) I'm screwed... Thanks to you for your valuable information...relating to the cleaning of the MAF... So i ran down to the garage with my big screw driver vise-grip and flash light...unfortunately, it seems like someone, previous owner or another screwdriver mechanic... has tried it before me, by the looks of the screws... i cannot remove them unless i get into some...'tidy 'manicure'' of the screws... it looks like it has never been undone ...Patience is a vertu... guess i should get a big roll of it at the mall Edited March 26, 2009 by Pinip Link to comment Share on other sites More sharing options...
BobbyD Posted August 7, 2009 Share Posted August 7, 2009 88' Thanks for the info. on cleaning and changing the AMS(air mass sensor)But every year I have mine cleaned because my Pathy starts having an erratic idle.(between 800rpm-1500rpm)and the exhaust stinks like sh_t! I notice when I mess with the pigtail towards the back end of the AMS, it regulates the idle.(pigtail=wires going into black square that snaps on. What can I do? Is this an MAS problem? Link to comment Share on other sites More sharing options...
westslope Posted August 17, 2009 Share Posted August 17, 2009 Just cleaned the MAF because I thought the engine was idling a little high, just under 1,000 rpm. Thought I could reduce the idling speed by cleaning the MAF. The alcohol-tipped Q-tip sopped up a little bit of dirt but not much. RPMs did not change noticeably. (They drop if I turn on the air-conditioning or turn up the ventilation fan.) I should check the gap on the plugs.... Great thread 88. Thanks. Bernard's pictures were particularly useful. Was catching up on some reading and came across this thread again. FYI: The idle issue was likely caused by a failed 02 sensor. It and the catalytic converter were kaput; the pathie failed Air Care (British Columbia Lower Mainland emissions testing) earlier this year. Once the 02 sensor and catalytic converter were replaced, the idle rpms dropped down to circa 750. 1 Link to comment Share on other sites More sharing options...
beavis0076 Posted September 23, 2009 Share Posted September 23, 2009 just did this and workrd great! Link to comment Share on other sites More sharing options...
JamesRich Posted January 18, 2010 Share Posted January 18, 2010 (edited) I think this would help more on a throttle body motor because the sensor is so close to the throttle body and the crap that comes in thought the PCV. On a port injected truck the sensor is far from the engine so it doesn't get dirty. I will try it as soon as I get a chance. James Edited January 18, 2010 by JamesRich 1 Link to comment Share on other sites More sharing options...
zelix Posted June 5, 2010 Share Posted June 5, 2010 cleaned my MAF today, looked clean, but i noticed much smoother acceleration and idle thanks! Link to comment Share on other sites More sharing options...
Eyehategod310 Posted August 2, 2010 Share Posted August 2, 2010 Just skimming through this and didn't see posted what I thought made removing the bottom screw A LOT easier. Unhook the maf and open the air filter box, you can use a regular screwdriver that way and get way better leverage. X2 Link to comment Share on other sites More sharing options...
nissaneric Posted August 14, 2010 Share Posted August 14, 2010 I have heard people use electrical contact cleaner with pretty good results. makes sense, dries pretty much instantly and leaves no residue. seems like a winner to me Link to comment Share on other sites More sharing options...
ModiFinder Posted November 21, 2010 Share Posted November 21, 2010 I just did my first fix to my Pathfinder thanks to NPORA! I have a 97 SE and I just cleaned the MAF with the help of the instructions here. This is what it looks like when I took it off. I thought it looked pretty clean. But then I turned it around and they black. I found that the best way to clean them was by putting the qtip on softly and then gently turning the qtip. Thanks again for the awesome instructions Link to comment Share on other sites More sharing options...
