CO_pathfinder Posted July 21, 2015 Share Posted July 21, 2015 I like to keep things a little more tidy. If I can't get the horn to work through the steering wheel, I'd have to go with something like this in my console: If you want to keep it even more tidy, you can do what I did and wire your horn to an interlock switch. I just made a little vinyl decal to stick over the word interlock, and since its a switch native to our trucks, you dont have to do any cutting to make it fit in any of the holes.. I can give you the wiring diagram for it if you choose to go that route Link to comment Share on other sites More sharing options...
stovanovich Posted July 22, 2015 Share Posted July 22, 2015 Needed to replace Idler Bearing and AC Belt so ripped all the other ones off and got it done. My AC pump actually runs as on-board air so I'd put it off for long enough Link to comment Share on other sites More sharing options...
mechanicalbaron Posted July 22, 2015 Share Posted July 22, 2015 Replaced my clutch master cylinder, changed the oil with Mobil one synthetic, ordered a CB (vintage Cobra 21x) and filled up the gas tank. Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Kingman Posted July 22, 2015 Share Posted July 22, 2015 Loosened the center link bolts on my '88 on my '88 one cotter pin slot. Seems to steer easier at idle. Ordered some Hawk pads for the '04. Spendy bastards. Link to comment Share on other sites More sharing options...
jolut Posted July 22, 2015 Share Posted July 22, 2015 MIG welded on a bearing race for my strut rod on right side Link to comment Share on other sites More sharing options...
CNAM Posted July 22, 2015 Share Posted July 22, 2015 Took a pic of it Link to comment Share on other sites More sharing options...
Terranovation Posted July 23, 2015 Share Posted July 23, 2015 Heard a rustling noise near my trans shifter, I managed to lift the plastic up a bit on one side of the center console at the base and pulled out an old yellow invoice form of some sort. There was Japanese writing on it. I think it must be from original Nissan factory. I have kept it and put in glove box. 2 Link to comment Share on other sites More sharing options...
nightfire785 Posted July 23, 2015 Share Posted July 23, 2015 Just finished replacing the brake calipers and the lower balljoints. Sent from my SM-G900T using Tapatalk Link to comment Share on other sites More sharing options...
CO_pathfinder Posted July 23, 2015 Share Posted July 23, 2015 Terrano thats friggin awesome! Link to comment Share on other sites More sharing options...
CO_pathfinder Posted July 24, 2015 Share Posted July 24, 2015 Rewired my red footwell lights, which allow people to see stuff that they drop at night without affecting nighttime vision. Installed and wired puddle lights.. actually, they are small driving lights that fit just inside the triangular body mount just aft of the front door hinge line. very bright, and the whole thing is relayed/fused/switched by a factory fog light switch i pulled from a jy.. 1:30 am finish time because nissan uses 3 black wires on the fog light switch so I had to play around with it. currently dead see y'all around Link to comment Share on other sites More sharing options...
stovanovich Posted July 25, 2015 Share Posted July 25, 2015 Got her aligned then home to adjust parking brake & give her a clean up Link to comment Share on other sites More sharing options...
xterra Posted July 26, 2015 Share Posted July 26, 2015 Got the horn and turn-signal-cancel functions working on my new steering wheel! I needed to sacrifice the back off the old wheel, but it had to be done. Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted July 26, 2015 Share Posted July 26, 2015 Replaced some retaining clips, meant to give it a good chassis greasing. Ran out of daylight. Link to comment Share on other sites More sharing options...
CDN_S4 Posted July 26, 2015 Share Posted July 26, 2015 Removed the remnants of the spare tire lift mechanism. Vacuumed it out. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
hawairish Posted July 27, 2015 Share Posted July 27, 2015 I don't think there's a day in the past week or so where I didn't do something to the truck, but this day was particularly fruitful: I finally finished my driveline project. My donor front axle with Lokka and 4.636 went in last weekend, and rear diff with rebuilt LSD (175 ft-lbs) and matching gears in today to replace my open diff...took it for a spin, and the gears alone make a world of difference. While at it, swapped in some brake shoes with less wear from my donor H233B axle, added a diff breather line (it just had the little nubby breather), replaced some wheel studs, and put a coat of paint on the brake drums. Last weekend added another inch of lift up front (now 3" spacers + OME) and swapped in my 3" SFD spacers. Also started re-assembling my R50 tire carrier tonight to get ready for mock-up (and drilling?) tomorrow. Had it and my sliders powder coated gun-metal the other week. Link to comment Share on other sites More sharing options...
CO_pathfinder Posted July 28, 2015 Share Posted July 28, 2015 Peeked at my muffler because I noticed a hissing sound louder than normal. The exit pipe has completely separated from the muffler back plate, resulting in a big fat crack through which half of my exhaust is escaping. Huzzah! Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted July 29, 2015 Share Posted July 29, 2015 Beat my bumper back into shape, and did a little cleaning. Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 29, 2015 Share Posted July 29, 2015 Backed it out of the shop to work on a friend's rig and heard the sound of the exhaust rattling against the tow bar. I don't think it was hitting before I took the bar off... something's not right under there. Link to comment Share on other sites More sharing options...
CO_pathfinder Posted July 30, 2015 Share Posted July 30, 2015 Waxed it 3 times. The shineeeeeeee Link to comment Share on other sites More sharing options...
mechanicalbaron Posted July 30, 2015 Share Posted July 30, 2015 Waxed it 3 times. The shineeeeeeeeCome over and wax mine? Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
ShawnTRD Posted July 30, 2015 Share Posted July 30, 2015 Had the fuel pump replaced with a Denso brand from Rockauto. Now I know how much gas I have again. Link to comment Share on other sites More sharing options...
Kingman Posted July 30, 2015 Share Posted July 30, 2015 Did the front brakes this morning at the shop before work. The steering wheel shimmy is still there while driving but it's not magnified 10x when I hit the brakes now. I'm thinking my next step is going to be to remove the flanges and drive it to make sure the CV axles at such an angle from the lift isn't causing it. Link to comment Share on other sites More sharing options...
CO_pathfinder Posted July 30, 2015 Share Posted July 30, 2015 Come over and wax mine? Sent from my SCH-I535 using Tapatalk If you pay for the gas/ airline ticket I'm more than willing to Link to comment Share on other sites More sharing options...
Kingman Posted July 31, 2015 Share Posted July 31, 2015 Tidbit: Acura MDX brake pads are identical to the R50's. Same PN and all. Link to comment Share on other sites More sharing options...
aussie4wheeler Posted July 31, 2015 Share Posted July 31, 2015 (edited) New wix trans filter last night, new wix air filter last night, new rear window reg and motor, hand wash, triple coat of wax, new amsoil change, wix filter.... Oh and a car accident an hour ago... fskc! Edited July 31, 2015 by aussie4wheeler 1 Link to comment Share on other sites More sharing options...
