Kingman
Everything posted by Kingman
  1. Welcome! Whoa, never seen one like that before!
  2. You can get a 4x4 lever from a D21 (Hardbody) and use that since they sit higher off the frame already
  3. Pffft who needs mufflers...they're overrated.
  4. CV axles click when they're going bad. Strange it only does it in 4LO though.
  5. So 104 miles on 1/4 of a tank of gas.
  6. 1986.5-1987 - 3 speed transmission without overdrive 1988-1995+ - 4 speed transmission with overdrive Manual optional on all years I still don't get why they're referred to as autotragic and what not, they are a good strong transmission, used in many different vehicles and in Pathfinders for at least 12 years. It's only the coolers that ruin them.
  7. That's just the name of the tranny. I don't think it's marked anywhere, I've never looked hard enough at one to see it if it was though
  8. Any RE401A transmission from a 90-95 will work. This transmission was used throughout most of the R50 years as well, however the wiring is different.
  9. Completely bypass the stock unit with at least a 15,000lb aftermarket cooler. If the stock one clogs (and it likely will eventually, and you CANNOT clean it) it renders the aftermarket cooler 100% useless. In that case, you spend X amount of money to destroy your transmission. Last summer I towed jet skis around no problem. I know it's not much, but for a weenie engine it did fine.
  10. I think it's pointless to flush it out unless there is a problem with the system
  11. Ah man, I thought I was the only one who figured this out...damnit! Now ya went and spoiled it! JK man, nice video! I remember doing it on a bottle jack that didn't have a top end retainer on it, and the rod part went flying out 2 feet up in the air.
  12. No that's not normal. It should stay around the 1/4 to 1/3 mark at all times. Is the thermostat stuck? Backwards? To check for flow, turn on your heater to hot. If it's blowing cold air you have a collapsed hose or your thermostat isn't opening or is backwards. Timing: dunno.
  13. Timing belt isn't on 100%, clogged catalytic converter, o2 sensor, clogged vacuum lines...
  14. SILENCE! I KILL YOU! It must be pick on Kingman night
  15. Nice write up! I need to do this on my passenger side door, it's starting to get bad. Driver's door still doesn't have any play in it though
  16. It's been said before that you don't need a BL to fit 33s if you want to trim the fenders. Some people don't want to trim their fenders, so their option is a 3+3.
  17. Use the line to your brake booster.
  18. There's a 300 and a 280 in the Upull it on 76th street.
  19. That's what mine did. Ran great when it's cold, but when it warmed up the sensor would freak and dump a crap load of gas into it. I used a half a tank of tank of gas in 13 miles. The sensor is in the valley of the block. It was an $800 repair at a local shop. I didn't have time to do it myself, or I would have. I think the sensor its self listed for $56.
  20. Huhm. The only code it throws is the MAF sensor huh. I wonder if it's your ECU Coolant Temp Sensor...
  21. Search the garage a little. I think it's in there somewhere, I can picture the thread in my mind. I'll search around for it as well.
  22. I think if it was the torque converter it would be slipping in all gears. It doesn't know which gear the transmission is in, so it shouldn't make any difference. The place that rebuild your tranny, are they known for using high quality parts or cheap ones to keep the cost down? Like B said, check the condition and level of the fluid...
  23. Lol, I bet if it was a Jeep y'all would be happy little school girls.
