Kingman
Everything posted by Kingman
  1. Mine blows a little blue when I rev it up to like 5k+. Other than that, nothing. A common problem on the 3.0L Mitsubishi engines in the Chrysler minivans. I see them pull away from a stop and it's a total bat screen.
  2. http://www.nissanpathfinders.net/forum/index.php?showtopic=9325&hl=
  3. My neighbor 5 houses down from me heard your shouting... He shouted back and said "bad ass!!! But quit your freakin yelling!"
  4. Is it a manual? If so just push the stupid thing and compression start it.
  5. You can damage your engine setting the timing too far off. Did you try advancing it to 15 degrees? Any particular reason you're running anything more than 87 octane fuel? The VG30Is are designed to run at 12 degrees using 87 octane fuel. Anything more and you're wasting you're money and possibly lowering performance and economy. You can advance the timing to 15 degrees and get better power.
  6. Well when you're 2 degrees off, yeah... And run 87 octane. I wonder if you're timing belt slipped a tooth...
  7. Terrano NZ towed a Pathfinder he bought with his Pathfinder quite a long ways. I think he only overheated a few times but made it through just fine.
  8. http://www.nissanpathfinders.net/forum/index.php?showtopic=18310 As seen above.
  9. Our trucks are fat and underpowered. 4lo compensates with gearing. 4hi just makes the enigne work harder.
  10. Switching to an automatic wouldn't be worth it, in my opinion. Mostly because they're expensive, and you have to hook up all the sensors, wiring, linkage, and control units.
  11. Yeah, mine took me through hell and back...
  12. The hole that passes through the frame? About 3/4 of an inch.
  13. So you have a one wheel drive Pathy... Lock the rear end up to get as much out of a 2WD drivetrain as you can...
  14. Morpheus you need to update your sig pic
  15. With the exception of a few '90 2 doors with MPFI.
  16. Only go by what the tire says. Different manufacturers prefer different tire pressures with their designs and specs. I run mine at 35 PSI cold on my Toyo ATs, I didn't bother to look at what the rating was. They wear perfectly fine and even.
  17. Just move to Washington or Cali or somewhere...rust free beauties down here!
  18. Hmmmm, that's what my last ex said, and the one before that...and I think the one before that! Looking at it though, I think in agreement with MY1PATH, it will look better on a black SUV.
