Sjackson2
Everything posted by Sjackson2
Hawairish and TowndawgR50 are teaming up!
Sjackson2 replied to hawairish's topic in 96-2004 R50 Pathfinders
Wow that steering linkage looks really nice!! What is the plate in the next two photos?- 155 replies
- sfd
- trailing arms
(and 3 more)
Tagged with:
Check the gas cap too. Does the tank whoosh loudly when you remove the cap after the vehicle has been running?
I think he means a missing link...and the post above covers that
Aluminum will be better than nothing. Basically...your just preventing the lca’s from pulling apart so it should be strong enough
Diode dynamics sl1 or morimoto 2stroke are the only led bulbs that belong in reflector housings
Fuel Pump Relay for Kill Switchb
Sjackson2 replied to joshualaw205's topic in 96-2004 R50 Pathfinders
If it’s a vg33....it’s e54 in this diagram -
Here you go -
Slave Clutch Cylinder brand make a difference?
Sjackson2 replied to PamPoovey's topic in 96-2004 R50 Pathfinders
Napa slaves are good. I’ve used them on several vehicles including my turbo rx7 with a copper puck race clutch -
I’m very happy with my lca brace. Made it out of anlgle iron. Best spent ten dollar part I’ve ever put on a vehicle
Because the post is old. Photos disappear after awhile
Ah....thanks for clearing that up
My understanding of the shock mounts of pre and post facelift is that they’re basically just reversed and you can just press and swap the bushings
Bump stops won’t really even be an issue once you get the longer coils. The 9447 only run about 70 bucks shipped so get on it!! Lol
I get some rattle out of the small powered sub I mounted in the back....but the Sony speakers and a pillar tweeters I mounted in the factory spots sound great in my Q
02_Pathy's build/shenanigans thread
Sjackson2 replied to 02_Pathy's topic in 96-2004 R50 Pathfinders
I had to do the exact same thing with some swivels and tape to change my passenger side front o2 sensor -
What bulbs are in those fogs?
I had good luck with some cheap aftermarket downstream o2 sensors from rockauto. No Nismo exhaust for the r50. Flowmaster 40 series mufflers are very popular for them.
Knock out the cats and get some o2 spacers to avoid the clogged cats getting sucked back into the engine till you have the money to replace them
zakzackzachary's 2000 R50 new to PNW from AK
Sjackson2 replied to zakzackzachary's topic in 96-2004 R50 Pathfinders
Ah gotcha. Great place to see the outdoors -
Raingoat you live in AZ too....or just visiting? -
Ya just remove one and see where the difference is. Did you use cheaper aftermarket sensors? These still throw codes a lot of the time
96 VG33 intake manifold oil deposits
Sjackson2 replied to tpounds's topic in 96-2004 R50 Pathfinders
Ah you’re right. Didn’t notice it was a vg -
I really like the stock fog lights. Are those leds?
I’ve seen people do it both ways....by cutting into the air box and siliconing the pipe in....and I’ve seen people delete the box and use an aftermarket aluminum elbow and just connect it to the maf. Either option should be just fine
