Sjackson2
Everything posted by Sjackson2
  1. The maxima remotes will work on r50s
  2. I wouldn’t risk frying the ecu on gasket maker
  3. Any more questions feel free to ask. I just recently did all the intake gaskets and pcv and everything in mine
  4. I’d leave the lower plenum alone unless you plan on changing manifold gaskets. And here’s a link for the gasket https://www.partsgeek.com/catalog/1996/nissan/pathfinder/fuel_injection/idle_valve_gasket.html and like sartorial said....clean the egr and the maf
  5. Also....replace the iacv gasket while you’re at it
  6. Oil in the throttle body and intake is pretty common due to the pcv system. It doesn’t necessarily indicate a problem. However....a failed pcv valve can cause all kinds of problems. Clean the throttle body and intake plenums thoroughly with throttle body cleaner and replace the pcv valve. Check for vacuum line cracks and leaks as well
  7. just do the resistor and tape it up good with electrical tape and put wire loom back around it. youll never be able to tell
  8. Looks nice! Why not bring the black down onto the front bumper a bit to finish off that fender flare look? What wheel are those? I really like them!!!
  9. I personally hats those stock pathy wheels!! Lol. I think they look better in black
  10. you have to reset the window limiter. here you go https://www.google.com/search?q=reset+window+limiter+2001+pathfinder&rlz=1C1GCEA_enUS806US806&oq=reset+window+limiter+2001+pathfinder&aqs=chrome..69i57.8367j0j7&sourceid=chrome&ie=UTF-8
  11. yep.you can spray it with some silicone lube and work it back and forth a bit.. sometimes the spring gets overly compressed too and doesnt contact all the way and you can fix that by making a shim. ive heard of people gluing pennies to the door frame so it pushes the spring in farther
  12. Open doors one at a time a push the plunger in and see if you can get the light to go off. If it does....that’s your door.
  13. Lr direct has the landover springs for 70 bucks shipped
  14. Is one of your door switches not getting fully depressed.
  15. I plan on going with ac springs in the front and Lr nrc9447 in the rear with kyb excel struts and 2001 f250 shocks our back
  16. If I remember right....I think I remember someone saying you could use a passenger seat and attach the drivers side seat mount to it and it works fine
  17. https://www.amazon.com/Genuine-Nissan-Positive-Terminal-Connector/dp/B01F9MV9YE
  18. you talking about this part? https://www.ebay.com/itm/OEM-Nissan-Fusible-Link-Battery-Fuse-24380-89914-Pathfinder-Armada-Frontier-Xt/273760562921?hash=item3fbd66aee9:g:GcIAAOSwA~1bpPa1
  19. probably have to snag a fusible link from a JY
  20. https://www.autozone.com/batteries-starting-and-charging/battery-cable/duralast-battery-cable/570486_309932_0
  21. just pop that ammeter out of there and put in a bosch water or oil temp gauge, or something
