Sjackson2
Everything posted by Sjackson2
  1. I did see a write up where a guy swapped in an rb26dett into a r50 https://docs.google.com/file/d/0B1bGnTCIBeAMVEd6OVlIdjh6UXc/preview?pli=1 strike that. This is a wd21
  2. It’s been talked about lots but I don’t think anyone’s ever successfully done it. It would be a lot of work http://www.pcoa.org.au/forum/viewtopic.php?f=19&t=8315
  3. Nope. Plenty of people fit them with 2 inches of lift and some trimming
  4. I could be wrong. The pcv valve is on the passenger side valve cover. It runs along to the drivers side....but I don’t remember if it connects to the drivers side...or goes over to the intake
  5. Yep. You’ll have to manufacture an sfd or wait for hawaiirish and towndogr50 to release theirs
  6. 1/4 inch hose fitting to bypass that. And I believe the hose from the pcv plumbs right into the air intake elbow before the throttle body
  7. I’d probably do it with the wheels off the ground first and see if it still makes noise
  8. This kind of adapter? https://www.amazon.com/Pipe-Female-M12X1-25-Metric-Adapter/dp/B078Z98GF2/ref=asc_df_B078Z98GF2/?tag=hyprod-20&linkCode=df0&hvadid=312430092407&hvpos=1o5&hvnetw=g&hvrand=16644118257186902106&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9030156&hvtargid=pla-570041607106&psc=1
  9. That looks nice. What’d you fill the holes in with?
  10. Man I love your rig. The stance on this thing is awesome
  11. I actually meant the stock housings. Those look crazy bright and bluish.
  12. On my 01 Q the number I coil pack plugs in from the top instead of the side like the other coil packs due to there being a space issue right there
  13. It depends on the code. The light can come on and off on its own. It doesn’t always require a reset. And 208 degrees is definitely too hot for normal. Mine never goes above 196 in AZ at 105 plus temps. That combined with the white smoke has me thinking you have a bad head gasket
  14. Pics got too much shadow to see them well. What wheels are they?
  15. Hmmm....my understanding was their a direct swap other than needing to change the cylinder 1 coil pack due to the design. I’ll have to look into it
  16. Shoulda tried to score some of the aluminum covers to replace with so you can service the spark plug seals in the future
