Sjackson2
Everything posted by Sjackson2
  1. To remove the rear quarter you just have to remove the little door sill plate on the back where the hatch closes and then the quarter panel is just held on by clips that pop off. Start by swapping in a know good relay to see if that fixes your issue before you start messing with the amp
  2. Do they have the 250 pound spring in a 16 inch height that would just be a direct swap in for the r50 spring....or would it take some modification?
  3. They’re only 13 miles from my house so I can just go pick them up! Lo
  4. Ok I found the 2928s. And desert rat is right here in AZ. Didn’t realize they carried them!!
  5. 4wp has a bunch of different part numbers listed for the ome springs. Which one is the right ones?
  6. Ya they rape you on the shipping. Most people these days stay away from them other than they’re the only place to get ac springs. I’ll probably be going with Ome from rugged rocks when I get my front springs
  7. I should be down if I don’t have another one by then
  8. That does sound like a lot! Aren’t the land river springs only rated at like 225 and that’s quite a bit over stock
  9. Send the old one my way when you’re done with it!! Lol ?
  10. it is...but im kind of a obsessive reader so i follow everything i can.
  11. join the r50 nissan pathfinder and qx4 lift group on facebook. theres at least two guys on there currently manufacturing sfd's for good prices
  12. Manual transmissions have no power valves. Do the iacv gasket while you’re at it. Replace the pcv valve and pcv and breather hoses. And I’d replace the water control valve while you have the plenums off too. And probably the etc sensors that are on that water pipe on the back as cheap maintenance
  13. Scroll down a couple threads and there’s a free pair of 9447 up for grabs. Just gotta pay shipping
  14. No they’re not side specific. And I’d go with the 9447 if you have 2 inch spacers in front. The 9447 is usually good for 2.5 or so inches of lift
  15. I might be wrong here, but i thought the 9446 gave more lift than the 9447? More like 3ish inches?
  16. Not free...but fast. These springs are like 70 bucks shipped and have a much higher spring rate than stock
  17. You’d have to punch a hole in the bumper in order to use them. But you’re already cutting the bumper so why not? Lol
  18. Just wanted to say a huge thanks to bax03SE for these springs and spacers. They’re in pretty much brand new shape and I couldn’t be happier to have them. Especially at this price point!! Lol
  19. with only a two inch lift this shouldnt be an issue. if he wanted the longer shocks though you could go with bilstein or procomp. could always run some f250 shocks also...just have to swap the bushings
