Sjackson2
Everything posted by Sjackson2
Lower plenum off
upper plenum removed
Ok so I decided to tackle both front o2 sensors today as well as doing the loctite on the powervalves and replacing the etc sensor.
Spray it down with on blaster and clamp a vice grip on it and spin it out
I believe those are basically just resistors that like you said, make the ecu believe it is receiving colder air
I’d be pretty skeptical about putting something like that on when there’s no shop you can go back to if it causes you issues. You have no idea who performed the tune or what they tuned it to
Exactly...and John jackson from jackson motors ports who built the original prototype said that the conduit was just as good as his. The only reason he built his is so it could be a mounting point for a skid plate
Cleaned MAF sensor tripped code
Sjackson2 replied to JackFletcher's topic in 96-2004 R50 Pathfinders
Go with this one. Cheap on amazon, free shipping with prime. And links up great. Use the torque pro or car gauge pro app with it. If you go with the car gauge app you can do the self learn and idle volume learn with it as well as adjusting base timing by plus or minus two degrees https://www.amazon.com/EDIAG-Diagnostic-Scanner-Adapter-Android/dp/B06Y5YFQ63/ref=mp_s_a_1_16?crid=U1PZKWTGF6Z2&keywords=elm327+bluetooth+obd2&qid=1550515792&s=gateway&sprefix=elm32&sr=8-16 -
Water pump went... early! what else todo.
Sjackson2 replied to Mattmill91's topic in 96-2004 R50 Pathfinders
If I was gonna pull the pump off a truck this old, is probably replace the fan clutch too. -
I used permatex rtv per the fsm
The bar should be 23 3/4 long. Holes are about 22.5 inches apart
Tricking your engine to idle up and electric radiator fans
Sjackson2 replied to colinnwn's topic in 96-2004 R50 Pathfinders
I just think the capacitor is a band aid for a larger overall problem. There’s no reason that the factory alternator shouldn’t be able to handle the draw from an electric fan. Something else is going on and a capacitor will just mask it -
I know it’s unlikely to cause problems. Unless you live somewhere very cold maybe. Tons of owners have done it, myself included. The only time the coolant does you any good is on startup anyways. And yes....I don’t like the idea of splicing into the wiring -
and I’d look into testing and getting a new alternator before I put caps iine to the fan -
I would not use the fuse. Just bypass the coolant line to the throttle body and you’ll never have to worry about coolant leaking into your iacv. And definitely clean it out. -
Failing to start the car, and still having sufficient voltage are two different things. Get it checked. No it does not require a consult scanner. Depending on the year of your vehicle there are two different methods -
Hawairish and TowndawgR50 are teaming up!
Sjackson2 replied to hawairish's topic in 96-2004 R50 Pathfinders
I’m by no means a master fabricator....but I love tinkering and I’m super pumped to see some cool things come out for our pathys. If you guys ever need help with anything at all, I literally live a block from hawairish and would be happy to assist. Do you guys plan to do mostly frame and suspension related parts...or are any other items in the works? It’d be great to see some things like cold air boxes, snorkels and snorkel mounts, pre dabbed trans cooler brackets. I’m hoping to get some cardboard and some plastic or aluminum sheeting pretty soon here to mock up a cold air box and I’d like to do a trans cooler soon too.- 155 replies
- 2
- sfd
- trailing arms
(and 3 more)
Tagged with:
Is your battery up to snuff? Have you done the idle volume relearn? Cleaned out the iacv? I would do all these before I started trying to mess with the idle -
What tranny cooler is everyone running? I’ve seen a lot of wools like the b&m. What about Hayden? Anybody using this one? https://www.amazon.com/gp/aw/d/B0714MSVWH/ref=ox_sc_act_image_1?smid=A3B850ZGIPDG3A&psc=1
Will al LR springs need milled to install, or was it just the 9448 for some reason? *edit* nevermind. Saw that they fit without milling
9447 is the lowest amount of lift
Perfect!! Thanks a ton.
Is that what that little resister is on the side of the actual mag sensor on the maxima?
So I know you can use a 2001 maxima maf on our pathys, but how does that work with them being a 5 pin versus the pathy 4 pin connector? The factory connector still snaps on just fine?
Very nice! I couldn’t be more pumped to have somebody making cool r50 parts that lived right around the corner from me!!!- 155 replies
- sfd
- trailing arms
(and 3 more)
Tagged with:
