Alkorahil
Vendors
Everything posted by Alkorahil
  1. Pulleys do wear out over time. It is not very difficult to replace it at all.
  2. sounds like you are missing a screw here or there maybe this will help:
  3. isnt code 45 for california emissions vehicles only? is yours cali?
  4. part is highlighted in blue. here is the diagram for the manual ac system on a 2002 R50:
  5. yeah, thats something to look at as well. The oil pressure sensors are prone to leak oil onto the starter and kill it over time. check to make sure yours isnt covered in oil, it is is, replace the oil pressure switch as well as the starter.
  6. If the battery is truly fine and the cables to the starter are fine, this most likely leaves you with the starter solenoid is going out and about to be KO'd.
  7. Under the passenger side dash, where the passangers feet would be, on the firewall, pull back the top of the carpet just a little and there is a rubber plug in the firewall. pull the plug out and you now have a passage way through the firewall. Its a small plug for a small hole, maybe 1/4"
  8. HEH! that would be a small air cleaner now that I think about it, even if it was at an angle
  9. No harm, i was wondering why the other pics were included withteh air cleaner
  10. HEHE It was the 'transmission fluid' that threw me off. Should have paid more attention to the GL-4
  11. I believe the backspacing is 5.5 in and the offset is 30mm.
  12. Well, that part highlighted in red is the AIV - Air Induction Valve, and we were looking at pics of the air cleaner. Here is the PAIR assembly (Pulsed Air) , what you are acutally wanting then:
  13. ummm.....that doesnt sound good to me IIRC that was connected to the trim valve..... however the IAVC is not mounted on the throttle body.... Ill look at the one on the self tomorrow, but I think the screw is attached...
  14. If you replace your belt, replace the water pump as well. You have to take it off anyways.....
  15. Just remember, on the dipsticks that 1 1/2 inch or so from the bottom of the stick to the top of the fill line is one quart.....
  16. the die used to detect freon leaks is purple and wil make a purple liquid where there is a leak.....it could be leaking down from the condensor to the bottom.
  17. The IACV regulates idle speed, raising and lowering it as needed. It does this by opening and closing a "trim" valve to allow more or less airflow into the intake manifold when the throttle is closed. The adjustment we make on the IACV is for setting the "base idle". By unplugging the TPS we tell the ECU to completely close the trim valve in the IACV. When this happens, the idle airflow comes completely from a needle valve - the one you can adjust when you turn the screw on the IACV body. If everything in the fuel and intake system is operating properly, the idle speed will not be able to drop below this setting. A few things can cause the base idle speed to go out of adjustment. First, the needle valve can become clogged with dirt or carbon, reducing or completely blocking off airflow through the needle valve. This would reduce the airflow through the needle valve and cause the ECU to rely partially or fully on the opening of the trim valve in the IACV to maintain target idle. This would mean that the idle could possibly fall below 750 before the ECU could intervene. Second, the trim valve within the IACV could be rendered partially or totally inoperable, either through blockage or failure. If this valve is blocked open, idle speed would be high unless the needle valve's opening was reduced to compensate. The result of this may be the inability for the ECU to compensate for all idle conditions - base idle would be set for Y percent trim valve opening, leaving only X-Y percent of the operating range of the trim valve for ECU adjustment. If the trim valve is not blocked open but the passage to this valve is partially clogged, it would require the ECU to open the valve farther than normal to allow a given amount of airflow to pass. This would also reduce the amount of compensation the ECU can apply to idle speed. To sum it up, there are two idle speed adjustments to control idle on our cars. First is the manually adjusted base idle setting, which determines the minimum airflow through the IACV (and minimum warm-idle speed). Second is the ECU's control over the "trim" valve within the IACV, which compensates for hot and cold idle and engine loading (power steering and A/C operation). Now, there is one other factor in this equation, the IACV-Air Regulator. This valve is in parallel with the IACV-AAC valve. This valve is what supposedly makes the car idle fast when the it's cold. The FSM gives the following description of the IACV-Air Regulator. "The IACV-air regulator provides an air by-pass when the engine is cold for a fast idle during warm up. A bimetal, heater and rotary shutter are built into the IACV-air regulator. When the bimetal temperature is low, the air by-pass port opens. As the engine starts and electric current flows through the heater, the bimetal begins to turn the shutter to close the by-pass port. The air passage remains closed until the engine stops and the bimetal temperature drops." Here is the diagram: Note the IACV-AAC valve is under the intake plenum, back by the fire wall. you have to remove the intake plenum to get to it.
  18. could be many things. Try checking all of your vaccum lines first to see if they are cracked, frayed on the ends or loose. up and down engine can also be caused by: air filter filthy MAF sensor EGR valve stuck/bad clogged PCV clogged fuel filter engine temp sensor IACV-ACC valve O2 sensors also check the wires and connectors on these parts for loose/corroded where applicable. As to the odometer, does the speedometer work? If it does still work then mot likely you are looking at needing a new cluster meter.
  19. Here is the parts diagram. This one is for the Z24. Teh VG30 is nearly similar. Couldnt tell exaclty if you had a 2.4 or 3.0 from the photos. Looked like a 2.4.
  20. 650-700 750 i believe is spec
  21. Yes. right next to the wiper motor.
  22. In the US wheels are still done and discussed in inches. If you have an 05 pathy, the wheels should be 16x7 or 17x7.5. There were 5 and 6 spoke versions made by Alcoa and Enkei for Nissan. All the R51 Pathfinders are 6 lug wheels and hubs. The lug pattern is 6 x 5.5. This means there are 6 lugs on the hub and there is a 5.5 inch space in the middle for the spindle.
