36
Everything posted by Alkorahil
I switched out the Gabriels on mine (didnt last long) to Bilstein. Much improved difference. They are very very stiff.
I have to ask, you might free up some 300 pounds, but to what end?
There is a hood with scoop for the D22/WD22. There used to be one for the D21 but is is discontinued.
5250 pounds?!?!? that isnt enough????
Rack looks great. Im going to pick me up a radio like yours too. It looks liek it will solve all my room problems!
I cant say for your state, here in TX it should pass if the tires have enough tread regardless of how lifted or lowered it is.
You should have a tap screw and a grommet. The problem people often run into is the grommet is spinning with the screw when you rotate it so you are not loosening anything no matter how much you turn.. If you can...lift the front of the console up, take a flashlight and some long long pliers or (small helper hands) grab the grommet and hold it while rotating the screw.
How deep did you get? Did water get into the vehicle? I dont see the computer being anything to do with it based on what you are describing. For the starter..... check up in the relays up by the passenger side wheel wheel. See if the relays are wet on the inside or if the connections have corroded. Is the beep coming from under the seat? I had this happen to me I would hear beeps and the doors would lock then unlock themselves. The truck will do this when you try to lock the doors if to you from locking the keys in the truck if it isnt in park with the engine off. I fixed this by cleaning the door locks-the tublers inside were not it the correct position fully from 15 years of crud in them. The vehicle will also not let you lock doors if the door is open and the vehicle running. Check the door pins to see if they are wet/muddy, etc.
Here are the pump numbers and supercessiosn for the 300zx, hardbody and Pathfinder. I didnt bother with the Maxima and Quest. Part number might be stamped on the old water pump. Z31 300 ZX V6 MANUFACTURE DATE 07/83 TO 05/87 21010-02P25 21010-02P26 21010-02P27 ALL DEFAULT TO 21010-02P85 Z32 300 ZX V6 MANUFACTURE DATE 02/89-08/96 B1010-22P27 PATHFINDER WD-21 V6 MANUFACTURE DATE 07/86-08/89 21010-12G25 AND 2101012G26 WHICH BOTH DEFAULT TO 21010-12G28 MANUFACTURE DATE 08/89 TO PRODUCTION END 21010-12G28 D21 & D21U HARDBODY 2WD V6 MANUFACTURE DATE 11/85 TO 07/93 21010-02P27 MANUFACTURE DATE 07/93 TO 01/96 21010-02P85 HARDBODY 4WD V6 MANUFACTURE DATE 11/85 TO 01/96 21010-12G28
Knock sensor and speedometer sensor
Alkorahil replied to Nay-Sayer's topic in 96-2004 R50 Pathfinders
Book rates it at 4.2 HOURS for the knock sensor -
You are right, missed that we were talking driver side.... But are not NZ vehicles right hand drive?? But even then if it is driver side it would not matter, the AC drain would be on the passenger (left in this case) side.... so I would still be wrong! LOL
O crap oil light came on need anwser 1994 pathfinder
Alkorahil replied to 4wheeldrivefun's topic in 90-95 WD21 Pathfinders
Yeah, thats what is was! -
The top one looks like the pump on a Z24 4CYL the bottom one is the one for a VG30
HAve you been running the AC or the defroster? If so.....Clogged AC drain
If I recall correctly specs are 45-52 psi @ 2500 RPM. -
I bit the Dust HARD... Please help me
Alkorahil replied to Nytrosfinder's topic in 86.5-89 WD21 Pathfinders
We used to like the Grand Cherokee back in the day.... Everytime one came into the shop for work, it was at least a grand....... ($1000) -
JEEP = Just Empty Every Pocket -
That can be a very hard lesson to learn! Been there, done that.
How many miles do you get from a full tank?
Alkorahil replied to zack1978's topic in 90-95 WD21 Pathfinders
I pull 250 to 288 consitantly. -
It could be bad. Pull it off and see if it has a hard buildup on it. That would be an easy way to tell. It isnt an expensive part.
Funny....I had a guy in first thing this morning with a check valve on his Maxima that he broke. PART NUMBER 17370-89900 VALVE ASSY-FUEL The top hose goes to the top of the fuel tank. Hope that helps.
Agreed.
R50 - question about adjusting rear LSV after lift?
Alkorahil replied to FUELER's topic in 96-2004 R50 Pathfinders
It is part of the anti-lock brake system on a 96-01 R50 in the back brakes. But I am also curious, why does it need to be adjusted? -
Blowing cluster fuse, with no cluster installed
Alkorahil replied to spotfitz's topic in 90-95 WD21 Pathfinders
The one with the fuses behind the panel on the driver's side dash.... That is the 'super multiple junction'. Or so Mr. Nissan calls it.... -
Some of this sounds very similar to another topic going on currently: http://www.nissanpathfinders.net/forum/index.php?showtopic=22015 However I would be inclined to the stalk connetors on the steering column first. Check the connections first for corrosion or loose connections first. Fuse poping comes from a ground making a connection to a hot wire where it should not. That is either a bad exhaust manifold or worn hydralic lifter. Common complaints. Mostly just annoying. Do a forum seach for more on this.
