Alkorahil
Vendors
Everything posted by Alkorahil
  1. I love mine. It is shiney and pretty.
  2. Is this the one on the glass? If so it is part number 90454-AD010 Part is still available.
  3. This problem gives me two initial thoughts. 1) there is an open connection somewhere, something is staying 'on' and draining the battery over night. Do you you have an aftermarket stereo amplifier or something like this? Maybe an interior courtesy light or something? 2) the door slam thing makes me think there is a connection issue, possibly in or near the wiring harness located behind the drivers side kick plate. Take it off and you will see several connectors. make sure they havent come loose.
  4. Hmmm... this is a most interesting problem. Did they maybe miss a vacuum hose when putting the intake collector back on?
  5. Yep yep its buried right in the middle.
  6. Check the wires for the alarm going up into the column as well. I messed with mine awhile back and had the same problem with the gages not working.
  7. that part number circled in brown is PART NUMBER 14828-16E01. VALVE-EAI Nissan List is $38.65. I can get it for you for $23.78 + ship It is still available.
  8. 1) The rapid flashing indicates some sort of error. Check the connectors under the drivers seat. You may also try disconnecting the negative battery terminal to see if it clears the error. I also believe the insert on the alarm that would be with the owners manual talks about the errors. (if you still have it) 2) Your pathy did come with keyless entry. Part number is 999U7-6D001
  9. Given that this is a 87 and the strong smell of gas from the engine makes me think to look at the throttle chamber or venturi. Some spring, valve or lever may be out of adjustment or become stuck or covered with grime and not opening or closing correctly untill it get warmed up or wet with fuel. It may be as simple as popping the air cleaner off and spraying it down with a can of carb cleaner while the engine is cold.
  10. This part sends the temperature of the coolant to the ECU so that the ECU can make the proper adjustments. part number: 22630-01P01
  11. Been there and it is frustrating!
  12. Sounds like on of the three highlighted here, let me know. I have one of them in stock, cant check availability till Monday on the rest.
  13. maybe this? http://www.4x4wire.com/toyota/reviews/snorkel/
  14. They are power folding mirrors!
  15. Didnt even know they made these...too bad they are chrome or I would be all over them! dying to know what the part numbers are! http://cgi.ebay.com/ebaymotors/JDM-Nissan-...id=p3911.c0.m14
  16. I was surprised myself..... at least its guaranteed to fit right!
