Alkorahil
Vendors
Everything posted by Alkorahil
  1. Ignition misfire usually leads to need new distributor..... Is it possible that you have been driving though large water puddles or parking over an automatic sprinkler head? Is there some post ignition burning in the exhaust manifolds (loud popping sound) Seen this before almost sounds like water/condensation in the distributor cap....
  2. That is a very expensive mirror.... Never done it, cant think why you couldnt though with enough thought and time put into it.
  3. I think we need a whole thread in the picture section of dogs riding in Pathys!
  4. Your linkage needs adjusting or the gear syncronyzer between 3rd and 2nd is worn out. Either way it will probalby get worse with time.
  5. Yes. IIRC WD21 is 7/8 inch and R50 is 1" stock. I definately know they are completely different parts numbers from Nissan. I should also add that these aftermarket sway bars are only adding like 1/8 inch in diameter over stock. Not sure if it will make a sizable difference for $200 plus new bushings plus time. I can still get the NISMO 1" front sway bar for the WD21 4WD with manufacturing dates up to 7/87.
  6. ADDCO still makes the 1" front sway bar for the WD21 which is the same size as the old Nismo ones. They also have 1 1/8" for the R50
  7. Incidental is correct..... VQ35DE/AT 14010-4W10A MANUFACTURING DATE 06/01-END VQ35DE/MT 14010-4W020 MANUFACTURING DATE 01/00-END Two different parts based on if it is manual or auto. In addition, 14010-4W10A supercedes to 14010-4W10B. I have read about this issue many times on here, yet we have never had a vehicle in here with this issue.
  8. looks like 2 small bolts on each side of the block
  9. It was hot. It was getting dark. After fidgiting with the back door pin for 20 minutes i finally just grabbed the wire and disconnected it. That was 3 months ago. Maybe I will fix it one day, but I dont miss the light as much as I thought I would. If I ever need it, I can just reach up top and turn it on manually.
  10. I would add that it is a direct fit. Took me about 1 1/2 hours to get the old one off and put the new one on. (have a lift though, saves time) Most of the time was taken getting the old one off after being on there for 12-13 years. Has a nice prrr to it (esp on the highway, can put you to sleep) without sounding abnoxiously loud. They also have that million mile warranty, since it is stainless steel. Smaller and lighter too than stock.
  11. I was very pleased with my Borla.
  12. Manual Transmission with manufacturing date of 08/89 to 10/95 use the same TPS. Same for Auto Trans. All auto trans from 08/89 to 10/95 use the same TPS. Auto and manual trans use different part numbers for the TPS so the connectors may be different. So..... find one in the date range and same transmission type as yours and they should use the same connector.
  13. Yep what fleurys said that is a full set for the front
  14. Code P0325 is the knock sensor which is a pain to get to. I would suspect that it may be causing the other two codes to come up. (P0151 and P0131) You have one of two things going on witht he knock sensor, either there is a bad/corroded wire or plug at the sensor, or the knock sensor is bad and needs to be replaced.
  15. thats exactly what I did. I put a 200w Alpine in the back behind the trim. It was the right diminesions so that it fit perfectly.
  16. sounds like they were replaced then with non-adjustable.
  17. Agreed. I did an amp bypass on mine. tool a little time but it ok to take time to do something right!
  18. I would never re-use the old bolts! I am right behind you on the same project. New heads, and putting headers on whicle I have it apart.
  19. It is in the motorsports catalogue. Its a black and white picture, I can try to scan it. 01-03 D22/WD21 F5100-VK5MM hood with duct opening, ready to paint 65852-VK503 hood duct, ready to paint 65840-vk500 hood insulator F5852-DB001 carbon fiber duct insert
  20. I Second that! Any claim to do so is a load of BS. I love the 'chips' on ebay that for ony $5 give you +40 HP and +20 MPG at the same time! What a load of crap!
