Alkorahil
Vendors
Everything posted by Alkorahil
  1. Yeah shoot me a msg with your VIN and I can tell you.
  2. 1) exactly which hoses were you wanting? 2) agreed on the engineers! 3) agreed, stil love my truck. 4) try replacing the rear spark plugs on a Murano!! (step 1: drop engine)
  3. NISSAN FUN FACT Back in the WD21 day, interior code K was the Nissan color code for Black. (even though the WD21 was dark grey) Believe it or not! It is now the code for 'Charcoal' a more accurate description and 'G' is the code for black
  4. sounds like you are looking for: PART NUMBER 82330-3W410 Rear door - Glass and hardware - Run channel Run channel Right 1996 - 2004 LIST: $130.20 MY PRICE: $93.74
  5. Agreed. I would start with the MAF. Check the connector and wires. wiggle the wire when it does this and see if it goes away.
  6. Getting it off is the hardest part. Putting it back on took me about half the time.
  7. Well it doesnt happen too often and they are quite expensive.....not something you want to ever replace if you can avoid it.
  8. Only California emission WD21 had an EGR temp sensor
  9. Possible? Yes Easy? Probably not Expensive to make work: Probably
  10. Well that is basically true, but doesnt mention at all that drum brakes are better for breaking when you are hauling or pulling a load. IMHO Disc are much less of a PITA to replace, thats the most important consideration to me!
  11. What are you going to use for the discs? Meaning off what kind of vehicle?
  12. Just about every year there were very small internal changes to the T-Cases andTransmissions even though they are they same Models.
  13. I paid $20 for my stock one from a yard. Still nice and glossy finish too!
  14. Most likely culprit is the distributor itself. This is what usually caused this error code with this vehicle. Other culprits: bad plug(s) bad wire(s) bad Distributor cap bad distributor rotor weak fuel pressure
  15. Yep, VIN is a north america thing. Other places go by chassis number or even engine number.
  16. Part highlighted in red perhaps? Revolution Sensor Assy
  17. I would go to a wrecking yard and get a used one, swap it out, and see if it makes a difference to start.
  18. Also, make sure your high beams are not on
  19. Have you checked the relay? Is is a small black box, about 1" by 1" mounted on the passenger side firewall near the wiper motor. Should say 'Bosch' on it.
  20. Furthest back my suppliers go is for 99
  21. Nissan Part number is: 11925-88G00 PULLEY ASSY My online price is: $35.14 It is the complete assembly. here is the diagram of the part, it is highlighted in red:
  22. part number is: 33294-41G00
  23. I would suggest in addition: place a strip of medical gauze over and/or around over the JB weld or epoxy before it sets.
