Alkorahil
Vendors
Everything posted by Alkorahil
  1. Yep always a good way to start if you cant find it.
  2. The year model and engine size combinations make a difference as to which of the many different styles of wheel caps and which coil spring Nissan used on this vehicle in its production run..............
  3. Stabilizer makes a nice difference.
  4. Well if there is some question you can give me the engine serial number and/or the info on the manufacturing stamp in the engine compartment on the right fender near the firewall. Legally someone should not be switching out VIN numbers. Number he gave me seemed to match his descriptions of the vehicle, color, etc.
  5. Yeah he sent me a VIN. Has an XE With AM/FM Cassette!
  6. Here is the lovely Nissan Parts Diagram: http://i181.photobucket.com/albums/x291/alkorahil/sec287.jpg
  7. I can when I get to work Monday
  8. LOL I put a one through the condensor and radiator back around the first of the year! And it was still hot. Thank god for saftey goggles!
  9. looks kinda rusty to me from looking at the intake and outake......
  10. Yep yep yep. common problem with the VG30. Throw a little bit of pooky on the threads once you start threading the sensor back in.
  11. I dont see how it can be the speedometer pinion from what you are describing.
  12. There is a wire that goes to it. I believe it is a green wire. See if it is covered with oil/crud/junk and not making a connection and/or not plugged in. If that doesnt fix it replace the oil pressure sensor. PART NUMBER: 25070-07G12
  13. Sounds like wheel balance, bent wheel or alignment or a combination of the three. Does it do this only when accelerating? Does it more or less go away around 60 mph?
  14. Number of bolts are different..... So I would say no.
  15. I am assuming form your problem description the following: 1) your Pathy has auto air 2) This is a relatively new problem that has come up. Given your symptoms with an AUTO AC system it would be the Auto AC amplifier - most likely a loose or corroded connection. It is less likley to be the in vehicle sensor. (located on the steering column)
  16. 88= "convenience package" CONVENIENCE PACKAGE: coolant + washerfluid reservouir, 235 ties, chrome wheel , tire maker general, rear wiper, fm/am et+cassette, 8 speaker+fender+glass antenna, rear headrest, rear heater duct, power window, power door lock, power heated mirror, ascd, 2-speed+intermittent wiper, map lamp I ran your VIN in the computer and you do have LSD
  17. Alkorahil
    300z ECU
    It will not work.... And I will add to the list of reasons that the injectors are different.
  18. Here are the Maxima engines by model type and production dates U11 Maxima VG30E PD 84-89 J30 Maxima VG30E VE30DE PD 88-94 A32B Maxima VQ30DE PD 94-99 A33B Maxima VQ30DE VQ35DE PD 99-02
  19. I can get you a new one for $35.00 if you want. Part number is 11925-88G00
