36
Everything posted by Alkorahil
Not on tight enough most likely.
I can do $177 plus shipping.
I agree with Fueler
Why not get a new remote???
I can get you a new Genuine Nissan Pump Assembly for less than that.
168K miles and going strong
I like this part the best: "For over 50 years International Institutions, Universities, Engineering Associations & Independent Testing Labs have compiled documentation and test results proving that small amounts of hydrogen added to the Internal Combustion Engine significantly reduces toxic emissions, increase engine performance & provides a more complete burn of the fuel. " IF that was true the government woudl require them to be on vehicles to reduce emissions! "The added hydrogen gas from simple homemade hydro-boosters enhances the flame properties of the air-fuel mix & catalyzes the combustion of the hydrocarbon fuel. WHAT?!?!? "Improving the conversion efficiency of the world's motor vehicles by one percent would reduce fuel consumption by one billion gallons per year! " well...............So would removing air conditioning compressors OR catalytic converters and mufflers!
Sounds like what I had starting on mine periodically. I too diagnosed it as the IAC valve, so last Saturday I replaced the IAC valve on the truck and the regulator. To get to the IAC valve you have to take the intake collector off. Since I already was taking the collector off I went ahead and replaced the EGR valve, which you have to take off to get the collector off, I also replaced the PCV valve and properly cleaned the intake and the intake collector. The biggest surprise was the air tube assembly under the intake I found was seriously clogged with crap from all these years. It took 3 cans of intake cleaner to get all the crap out of those pipes. I thought my truck ran great before, now it is like I took 100K miles off of it!
Dead Sexy IMHO!
bad miss fire and hesitation
Alkorahil replied to bitemedoughboy.com's topic in 86.5-89 WD21 Pathfinders
Bad plug or plugs? ignition coil? Fuel filter? distributor cap? distributor rotor? any or a combo of those could also cause it. -
Well I looked in the computer at work and they were not available in North America.... But there must have been one somewhere since there are notes of a 'van' body type.
So I saw that PIAA now has wipers and blades out there. I read though the literature/propaganda and am wondering if anyone ahs used them on their Pathy and what they thought...
HAHA I hadnt been in a Walmart in over a year. I actually decided to compare prices and went in to their lube and tire area lat thrusday. The girl at Wally World told me that a 31 10.50 15 was a low profile tire! I turned around and walked out. Guess I wont be going back for another year, or more.
Yep yep yep. Did mine a few weeks ago. CaseyT is right.
OEM from a deal are not really that expensive and you get a one year warranty..........
VERY interested to se how this progresses. I almost took a replaced VG33 home from work a few weeks ago thinking along these lines.....but talked myself out of 'another project'
$100 for a wire set???? Ill pass! You sould too! Pathys like NGK IMHO
94 Pathy - oil on bottom of engine - problem or ok? (pics)
Alkorahil replied to AceO's topic in 90-95 WD21 Pathfinders
RMS is a lot of work, esp if it is 4x4. thats the penalty for being able to have fun....if you do not have a lift andor experience I would have someone else do it. It is not fun. Oil pressure is a piece of cake. You need a 24mm deep socket for it if I recall correctly. Disconect the negative battery terminal too, since it is very near the starter. right side valve cover is easy, the left side is not so easy.........the intake manifold partially covers it. -
Air pocket in the heater core?
Doug Thorley Headers Group Deal
Alkorahil replied to VegasPathfinder's topic in 90-95 WD21 Pathfinders
When do you need to know by? -
RMS is rated at 8.5 hours on a 4x4 pathfinder......... -
Rear Main Oil Seal repair vs Engine Rebuild
Alkorahil replied to Smithk's topic in 90-95 WD21 Pathfinders
Rear main seal on a 4x4 pathy is rated at 8.5 hours. -
Lamp assembly doest change from year to year, you are correct. It will work. Just because he is selling it doenst mean he knows what it is.....
Assuming he sends you the same thing he sent me..... One phillips head screwdriver and about 15-20 minutes. very, very easy. One problem witht he kit I got was it had 4 screws in the bag not 6. (comes with longer ones to replace the ones already in there) , there are 6 back there, 3 on each light. so I had to go rummage thorugh the shop to find two more.
They are westin. At leas thats what the instructions said at the top in big WESTIN logs, etc.
