320
The outer CV joint is right behind the wheel bearings...in fact, I think it's just separated from the bearings by the grease seal...so it might be tough to tell the noise diff. What you can do is pull the tire and pull the wheel hub cap or manual hubs, if you have them. Doing so will disconnect the wheel hub from the CV. You can do this with hand tools (might need ring pliers...not sure the stock setup). If you can turn the wheel hub without noise/issue at that point, it's the CV.
It actually sounds like the outer CV joint has failed. It consists of large steel balls packed in grease and could very possibly gush grease and have a loose marble sound as you described. The wheel bearings are pretty well housed within the hub, encased by a grease seal and wheel hub cap...if that goes slinging grease, that would be a pretty serious failure.
You know, I think I may need to retract my last comment...I don't think this will work for 4wd guys with manual hubs. Reason being that the center bore is clearly less than 100mm on the wheel-mounting side, so it might not clear manual hubs. Probably fine for 2wd and 4wd with fixed hubs (not sure what they look like); obviously not a problem for the rears.
http://www.nicoclub.com/FSM/Pathfinder/2004_Pathfinder/ See EM-10.
While pulling codes the old fashioned way is helpful, the low costs of OBDII scanners make it ridiculous to not own one, even for the novice mechanic. It's something that used to cost several hundreds, if not thousands of dollars, and now costs a few bucks. Just knowing the trouble code, even if you can't fix it yourself, is already a foot in the right direction. It can even be used for real-time details (temps, speeds, pressures, etc.) My scanner has actually bailed me out a few times. In fact, just the other day as I was turning onto a street, my truck threw a code and immediately put my truck into limp mode...I couldn't accelerate, and was a very bad situation to be in (glad there was no traffic, I probably would've been rear-ended). I keep my adapter in the truck, so I pulled over, hooked it up, read the code, and reset it on the spot. Everything back to normal long enough to get home and check it out. The choice of adapter or scanner is subjective and based on how you want to connect (i.e., your device, phone, etc). Wifi, Bluetooth, stand-alone are the norm. I use a small wifi module so that I can read codes from my iPhone and garage computer.
That might be the case...wasn't sure. FSM is the Factory Service Manual...the Holy Grail of your truck. It's the official Nissan guide that dealerships use, and it's freely available thanks to the folks at NICO. http://www.nicoclub.com/archives/infiniti-qx4-factory-service-manuals.html Click your year (not sure if you're an 01 or 01.5, but they should be nearly identical), then check out the Engine Control or EC chapter. That code appears at EC-472 or EC-483 depending on which FSM is for your MY.
Have you stepped through the diagnostic procedure in the FSM, or swapped the sensors to see if the code travels (if sensor is bad, should throw P1140)?
I sent him some additional bolt details, btw. He's right about the pigtails. But not cutting them and seating them on the perch is actually good for almost 2", too. Free lift! As for the hardware to mount any sort of centering cup for the pigtails, that's all custom. There's an existing hole that's best bored out to at least 1/2" for attaching anything to it.
I wouldn't think so...the only sensors/switches that should contact fluid are ones that measure a characteristic about it. Doesn't look like it could support sealing anything anyway (the backside is quite irregular)... P/N is 31918-43X13
Valve cover gaskets , what else while we're in there ?
hawairish replied to Beatup96's topic in 96-2004 R50 Pathfinders
Ha, yeah those prices are USD. You mean when Canada and Mexico build those border fences? -
Here's the website for Nissan of McKinney, btw: http://www.factorynissanparts.com/ I was in touch with Rob a few months ago when pricing LSD plates and discs. Their pricing is very competitive with Courtesy Parts. -
Ha, yep For your entertainment: VQ35DE vs VQ40DE (If you want me to post those full-size pictures up, let me know.) I don't think the bellhousings will mate, but the angle of the blocks are different, and all the extra holes may be misleading. For sure, the exhaust gaskets are the same; looks like it's just a matter of moving studs around. The valve cover gaskets are also the same. The motor mount bracket attachment points look lower on the 40, but nothing a SFD doesn't help resolve! Wonder if the internals could be used as a stroker kit...
This is actually something I've been thinking about...swapping in the VQ40, that is. Small power gains over the V8, but I think it'd actually be a pretty direct swap (I'd want the transmission and maybe t-case with it). After all, it reads like a stroked VQ35DE. I'd almost be certain just swapping the motor mount brackets and motor mounts over would get it to sit in the truck, and that's a pretty good start.
Pre-installation check-up before getting an SFD
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
LOL, just doing what I do (taking apart the truck endlessly)... -
Sorry, didn't realize I had replied to your post earlier...I was starting to wonder why everyone is needing new tubes and seals all of a sudden...
Who needs limb risers when you could have A-pillar chainsaws? Lookin' good, Virgil!
All the torque info is in the FSM link that Slartibartfast provided. It's an extremely valuable resource. For you valve covers, not only does it give the torque, but also the recommended tightening procedure. See EM-34.
My temps are consistent with yours, almost exactly. Though, my needle never moves, stays just below the 50% mark.
The spark plug tube is serviceable, it's the tube seal on the VC that apparently isn't. Check this out: http://forums.nicoclub.com/vq35-valve-covers-t607238.html
Generally, replace parts when they: 1) Fail visual/functional inspection 2) Are worth doing it "while you're at it"...i.e., the cost of the part, relative to the labor process and cost to install it later, is small enough to justify replacing it now. 3) Are designated with a white X in a black circle in FSM diagrams, indicating "always replace after every disassembly". These are usually nuts in high-torque applications (suspension, engine) and gaskets/seals in fluid/oil applications. The strut mount nuts (p/n 01225-00231) satisfy #3. The strut bearing (54325-5V000) satisfies #2. The bumpstop boot assembly (54050-0W002) is a #1/#2 part in my book...it may look fine now, but if you doubt it will last another 30K+ miles (or whatever you want/expect the strut lifespan to be), just replace it. Some boots are a thin ABS material that will eventually reach a deterioration point and fail uniformly. They end up looking like a stack of shredded plastic rings, which may shorten strut lifespan if they allow dirt and salt into the strut. Parts like the upper seat, the upper insulator, or coil end sleeve tubes usually satisfy #1. You can re-use them if they're in good shape (no rust, tears, frays, crumbling, etc.). This usually depends on the age, location of the vehicle, and manner in which it's driven. Obviously, the costs of parts add up, especially if considering OEM. My personal preference about buying OEM vs. aftermarket is that unless I'm certain an OEM part will last 2x-3x longer (to justify its usual 2x-3x costs), I simply won't buy it. (But this doesn't mean I buy the cheapest parts either.)
^^What they said. Double Platinum NGK is spec'd in the FSM, p/n PLFR5A-11. See MA-20 in the 02 FSM Maintenance chapter.
Coil packs OEM verse aftermarket 02 Nissan Pathfinder
hawairish replied to Petercan1020's topic in 96-2004 R50 Pathfinders
Do you have aluminum or plastic valve covers? From a recent NICO discussion about the VCs, the aluminums appear to use a different coil pack for the #1 cylinder (passenger, front of engine) than #2-#6 because they have a raised boss on them for #1. The plastic covers (2002+) use 6 of the same coils per Nissan (at least for my 04 with plastic covers). Here's the thread: http://forums.nicoclub.com/vq35-valve-covers-t607238.html -
It'll definitely be more expensive. Personally, I'll only go with OEM if I must. I mean, would you buy an OEM shock over an aftermarket one? I think you can get plenty of satisfaction from aftermarket parts, and at a fraction of the costs of OEM. Almost always, a single OEM part number represents a single part without accessories/hardware. There are exceptions where the part number is instead an assembly. In order to know the difference (and to get p/ns in general), I use parts.nissanusa.com and courtesyparts.com.
These would be the best, in my opinion, because they have 100mm center bores and integrated hub rings, effectively making them Nissan Truck/SUV-specific. But they're also almost twice as expensive as those without hub rings, and you can also buy hub rings for the universal spacers (but it doesn't put a hub ring between spacer and wheel, of course). 1.25": http://www.ebay.com/itm/321653315154 2": http://www.ebay.com/itm/321885328466
The OEMs don't come with spacers...but that's because there's two OEM numbers for them depending on production date. Pre-12/98 models don't use a spacer. Post-12/98 models use a mount that has the spacer incorporated. The aftermarket ones will fit all R50s because they include spacers, but it only gets used where needed. 54320-0W000 (strut mount only, for pre-12/98) and after-market (generally include spacer, strut bearing, nuts): 54320-2W100: Note the "spacer" already incorporated in the mount.
