320
R50 Tire Carrier Mod: Let's settle this!
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
Yep, those will work. I don't recall the length, but I think I went with a bolt 5mm longer than OE, maybe 40mm? The length is dependent on how you want to do the hardware...i.e., the OE bolt has an integrated washer, so you can go with just a bolt and washer and go with OE length; I went with bolt, washer, and lock nut, so I went a little longer. You could also go with a flange bolt at OE length: https://www.boltdepot.com/Metric_flange_bolts_Full_thread_(DIN_6921)_Zinc_plated_class_8.8_steel_yellow_10mm_x_1.5mm.aspx. If you go a little longer than OE, it's not a problem since you'll have some space in the cavity. And don't get the serrated flange bolts...they'll just promote rust as they work through the paint on the bracket. Also, one more note: the metal at the rear of the vehicle, underneath the taillight, has a pinch weld behind it where you'll be drilling into. Definitely start with a smaller drill bit and work up (the steppers are great). You may also want to use a rat-tail file in the hole, because any metal from the pinch weld may interfere with the surface metal that the blind nut needs to compress on. -
Yes, you will need to be mindful on leverage. Probably won't need to weld them, but if you can reduce leverage, that would be best. I don't recall what the area looks like specifically, or how far away from the metal the trim actually sits, so maybe there's another option. Gotcha on the holes. Been there, done that.
Class 8.8 will suffice, and is a Grade 5 equivalent. The quarter panel is the weak link here, as the blind nut could be pulled from the sheet metal under the right conditions. So when bolting the carrier to the quarter panel (after the blind nuts have been set), be sure to properly support it at all times until everything is bolted securely. The easiest way I found was to open the hatch, put the carrier in the closed position, support it with a block of wood on the bumper, and install as many bolts as you can. Then open the carrier and put the remaining bolts in. That all said, you also want to make sure the hole for the blind nuts is as tight as possible, to the point where you need to tap it in gently with something. It's worth doing a practice run on some scrap steel. I also used a silicone adhesive on the blind nut before compressing it for a little waterproofing. The setting tool is pretty good, just don't over-compress it, otherwise the threaded part can go off-center a little. The tool doesn't come with instructions either, but it's easy to figure out: Install the desired die, spread the handles apart, twist the blind nut on so that the handles stay apart, insert the blind nut into the hole (I put silicone on it right before), squeeze handles together. Keep it steady and perpendicular to the mounting surface. After closing the handles together as much as they can, I do tighten things up just a little more and give it one mini-press. Then use the knob to unthread it from the blind nut. Rinse and repeat. Also, the best way I find to determine hole placement is to set the carrier in place as described above, and look for the position where the curved parts of the bracket sit nice and flush. There's a sweet spot where there's an even gap where the bracket meets the quarter panel. Protect the entire area with some painters tape first. I think I actually did one blind nut first before drilling the 7 other holes, got the carrier in place and bolted to just that one blind nut so that it could help support things, then marked the other 7 holes for drilling. You'll notice on the each bracket 2 holes are round, and 2 are elongated. If you trust your drilling, you can mark center on the round hole...but if not, mark center on an elongated hole, since that will give you a little bit of play to set the carrier correctly. Take your time here! -
Xterra transmission mount the same as pathfinder?
hawairish replied to Cuong Nguyen's topic in The Garage
I usually use RockAuto for cross-referencing parts like this, but I don't see suitable match. I think maybe the way in which it mounts to the crossmember might be the same, but it might be a little different on how it mounts to the transmission? -
http://www.nicoclub.com/FSM/Pathfinder/1995_Pathfinder/bf.pdf, page BF-51. Shows a drain hose going towards the driver's side a-pillar, and another towards the rear, but doesn't show where that one goes. I bet if you pull off the rear cargo trim on the driver's side, you might find it easier.
Nice, digging in already! About the grab handle, that might be a project where the rivet tool can come in handy. You can now put a thread insert wherever you want. In your case, if you want to simplify the holes in the a-pillar trim, you can probably use 1/2" aluminum spacers, drill simple holes in the trim, and mount a universal grab handle through the spacers and into the blind nuts. Also, look into some stepper drill bits...these work pretty well on the trim for producing larger holes. I also used these on the steel for the tire carrier install. http://www.harborfreight.com/titanium-nitride-coated-high-speed-steel-step-bit-set-2-pc-69088.html
1999 pathfinder with an annoying alarm! Help please!
hawairish replied to bolbol's topic in 96-2004 R50 Pathfinders
That disconnected harness could be the problem, but it could be empty if you lacked some other feature, like maybe heated mirrors (not sure what was available for your year). The sensor/switch is integrated into the lock cylinder. You should see a wiring pigtail coming from it (seen below). You should be able to put a voltmeter on it and test continuity. Taken from an eBay auction: http://www.ebay.com/itm/271844515699 -
Nah, I never got around to using longer bolts...it's held up well so hasn't seemed necessary. It seems to have held up well for the other truck I did the swap on. Last week in UT, he actually hung the tire up on a rock and didn't notice any damage. Then, just yesterday he got rear-ended. He says the carrier is a little firmer to latch, but I don't think there was any quarter panel damage. The strip of metal under the hatch where the brackets bolt to is pretty thin, so I wouldn't be surprised if it bent inward a little. It's probably also an easy fix. As you've probably already observed, the striker brackets are pretty solid, so I doubt those have bent. In his case, it may also be harder to latch because the latch assembly is designed to move inward/outward for adjustability, and maybe it moved on him. You won't be able to able to re-use the OE bolts that hold the carrier to the quarter panel...they are 10mm x 1.25 bolts, which is uncommon for blind nuts (and is a metric-fine pitch). Instead, 10mm x 1.5 is what you'll have to go with (it's what the McM p/n is for). The latch/striker bolts are 8mm x 1.0, which is common and you'll be able to re-use those. -
Yes, you definitely want a tool. Scroll up a few replies for the one on August 1st...There's a link for the tool and rivet/blind nut p/ns. The 8mm ones were for the strikers IIRC. The tool comes with the dies for setting 5/6/8/10/12mm blind nuts. -
Awesome! You may also want to grab the license plate holder and wiring, just to make thinks nice and simple. I've bought some from various places, but McMaster-Carr was the best option. Avoid Fastenal if you can. http://www.mcmaster.com/#95105a199/=10lgnoe -
Cool. Time to pull the door panel off and checking wires and connections. Might just be a dirty contact. -
Well, welcome. Bummer that's how ownership started... How did you unlock the car without a keyfob? According to the FSM, using the key in any door is supposed to disarm the anti-theft system. http://www.nicoclub.com/FSM/Pathfinder/1999_Pathfinder/el.pdf I suggest looking through the "Theft Warning System" and possibly "NVIS" sections of the FSM. You can't exactly just unplugged the modules to fix things unfortunately. There are multiple modules that control everything you're experiencing. On a side note, how did this not get discovered pre-purchase? And no keyfob? You can buy them on eBay and program them to truck without visiting the dealership (instructions in that link). Of course, you should find out if your model even came with power door locks. -
Well, there's a catch: it may only be beneficial for lifted vehicles. For most trucks/SUV, moving the lower mount up would mean a 4-6" shorter shock and possibly reduced efficiency in the shock. You'd have to consider moving the upper shock mounts, too. For us...the 96-99.5ish (pre-facelifts?) have rear shocks installed at an angle, with the upper mounts behind the axle. Moving the lower mount up decreases the angle of the shock—not good. The 99.5-04, the rear shocks are almost vertical, but you can't move the upper mount higher, otherwise you start entering into the wheel well area where the tire could make contact during articulation. In both cases, you'd also want to consider moving the upper mounts inward, like this custom Tacoma setup: Note the additional crossmember allowing for adjustable upper shock mounting positions. This might be doable, but you'd also need to clear the springs, likely using an extended mount similar to the panhard bar's lower mount.
No reason you couldn't. There are several weld on kits available. This is the direction I would go personally: http://www.offroadsolutions.com/products/rear-axle-lower-shock-mounts/ These (and many like it) exist too: http://jksmfg.com/i-9052781-fab-rear-axle-shock-mount.html
LE accessory intall: heated seat problems.
hawairish replied to MotiganXD's topic in 96-2004 R50 Pathfinders
Sorry, I should have clarified: I don't have power seats or side air bags. I have power everything-else, and then some. Also, I'm quite mechanically and electronically inclined, so I'm not at all worried about getting something. I'm just trying to justify the effort of pulling OE seat heaters for a clean plug-and-play appearance vs. buying universal elements and doing custom wiring to the switches. And if going through with OE stuff, may as well upgrade some more. -
Duplicate post, nothing to see here folks... -
Awesome, glad that info helped. And thanks for the other details...some funny stuff there! I already have leather, but lack all the electronics. I almost wonder if it makes sense to just grab the complete seats (and that harness) and put my leather on them. Not that I couldn't run wires how you did. What did you pay for the elements anyway? -
Also, I'd be curious to know what all was involved removing the heater elements from the QX4 seats. Are they just sandwiched between the leather and padding, stitched in, glued, etc? There's a QX4 that has them at my local JY, and I suppose if the seat cushions were junked enough, I'd just cut into the leather. But I want to leave it as salvageable for the next guy. -
That's pretty awesome that everything is already in place. I also have the switches and have been thinking about adding in seat heat (for the woman, of course!). According to the FSM (http://www.nicoclub.com/FSM/Pathfinder/1999_Pathfinder/el.pdf, page EL-325), the RH heated seat harness (B56) should be loomed in with two other harnesses; one for the power seat (B57), and one for the side airbag (B126). If you have either of those features, you can trace that wire bundle; the airbag harness should be yellow, or have yellow loom or tape on it. That particular set of wires comes from the passenger door jamb/floor. It also looks like you should see 3 harnesses behind or near the kick panel. The lowest one (M70, page EL-318) connects to the harness (B50) which has the wiring for the three aforementioned components. If M70 is empty (and presumably you don't have those two other features), then there's your problem (back to the JY!). But if it's not empty, you can try tracing the wires from there. -
Ready to take the plunge but have a lot of questions
hawairish replied to Dave.Bert's topic in General Forums
The truck in those two links is actually mine, so I can confirm or comment on a few things: I still run mostly OME, and still dig it. I changed out the rear shocks to longer Monroes, and the drop in ride quality was noticeable. Haven't run KYBs, but I think most people have been pleased with them. I still have the rear studs up front and 1/4" spacers. With OE 16" wheels (as shown in the threads) and 245/75/16, no issues with tire clearance near the strut. Clearance is a little tighter with SFD and 265's, necessitating camber bolts. I plan to revert the front studs to OE length and run 1" spacers, possibly with Toyota wheels...but if I go that route, I may change all the studs to 12x1.5 for a few reasons. The RR hubs have held up well. I recently had to pull one to check my wheel bearing, and it's in good shape and has seen some decent use recently. As you'll find out, interior space for accessories and gadgets is at a premium. I installed a CB a few months ago, but instead opted for a handheld unit that has a car adapter so that it didn't need to be permanently mounted anyway. I just ran the antenna lead to the center console, and use the power socket in there. https://midlandusa.com/product/75-822cb-radio/ -
http://www.courtesyparts.com/auto-parts/1994/nissan/pathfinder/xe-trim/3-0l-v6-gas-engine/hvac-cat/blower-motor-and-fan-scat Looks like 27200-86G10 (#4 in link, w/o auto AC). eBay? http://www.ebay.com/itm/221797591511
I wish I would've done a similar recording on my buddy's R50 when we replaced his driver's side mount (was in two pieces when we did his SFD). Do you notice any additional shudder while driving around when it shifts into 2nd? That's what his truck was doing, as if the engine was settling back down onto the mount during the shift. His passenger and transmission mounts seemed okay, but were obviously the only things working. We suspect that the mount has caused a leak on the driver's side near the cat from the engine movement, but we've not been able to take a better look.
I've not heard any bad things about OME. I run them and they've been great. Those lift springs are for an Armada. They won't fit yours. Like I said, your part options are very limited. If you go to any of those parts manufacturers websites, you'll get 1-2 p/n tops. The rear springs will vary because many aren't R50-specific, but the actual p/n will vary by the amount of lift you end up with. The manufacturers websites usually spec all those out, and you'll probably need to determine what size you need. I run shocks for an F-250, about 5" longer than stock. Search for a few Bilstein posts, for sure a few p/ns have been provided by members.
Axle code confusion and questions about a rear differential
hawairish replied to RCWD21's topic in General Forums
Your original post didn't say your 90 had an LSD, nor that you had compared the two. When you did mention an LSD, it was in the context of your 87: But now that we're clear on what has what, the diffs will not act the same. The open diff's tires will spin in opposite direction, and the LSD's tires will spin same direction. Do both tests with the transmission in gear/park and both tires up. Since you have a V6 87, you already have an H233B/R200 per RedPath88. So you just want the LSD? -
Don't sweat it, it happens. We're just pulling legs here. We also know that the search function here is pretty crappy, especially since it ignores words less than 4 letters (like SFD OME AC). But we do get the question a lot, and nothing has changed regarding the setup for years. I just use Google and include "NPORA" in the search. The first result usually has multiple results, with a "More results from www.nissanpathfinders.net" that is far more exhaustive and useful. You have a very finite number of options for lift, SFD, and struts/shocks. It's pretty irrelevant which combo you go with. If you want 6"+ of lift, you need lift springs, an SFD, and some way to raise the rear as much (Jeep springs or lift springs + spacers). It's entirely mix-and-match. To summarize your options... SFD: KRFabs or homebrew Struts: OE, KYB, Monroe, OME, Gabriel Lift springs: AC, OME, Jeep (custom for rear if going >4") Spacers: Fleurys, LiftMaker, NX4, AC (they're NX4 spacers) Shocks: OE, OME, Bilstein, Ranchos, Gabriels, few others (including some for early 2K's F-250)
