320
Do you have OE or manual hubs?
Looking great, man! Really digging those Toy wheels. IIRC, you went with spacers, but what approach did you take to get around the mag-style lug nuts?
Good luck! That manual is the genuine Nissan shop manual, by the way. Here's something I always keep in mind when it comes to P codes...don't assume it's a faulty sensor or switch or something otherwise "obvious" given the code description. Always check the basics (grounds, connections, voltages, resistance) and work up to the most expensive parts (sensors). And try to think of correlations and events. I mean, when it comes to tracing sensors and stuff like this, ask yourself what the odds of parts X, Y, and Z all failing simultaneously. A loose gas cap, for instance causes the stupidest of codes to trigger. I hate dealing with these myself. I usually just reset them initially then wait and see if they'll resurface, but that's just me.
Agreed, sounds like a leaking seal. The seal is serviceable, but not while the rack is on the truck. It's undoubtedly not a fun job, and one of those jobs where you end up rebuilding the entire rack (and still needing to buy other parts, like the boots) vs. buying a reman'd replacement. Although a replacement costs more, it's less work than rebuilding it (and the part has a warranty).
Sorry, I don't have any direct insight to that code, but have you tried the FSM instead of the Haynes manual? There's a bit more specific troubleshooting steps there. See EC-445: http://www.nicoclub.com/FSM/Pathfinder/2001.5_Pathfinder/ec.pdf
I see 3 different front driveshafts for an 87, apparently to account for configurations between the Z and VG engines, transmissions, and R180/R200 diffs. Perhaps the snout on one diff was longer than the other, effectively moving the driveshaft flange back a little?
Sounds like a motor mount. If it's split, torque will cause the motor to lift, and the thump is probably when it comes back down. Usually it's the driver's side (er...LH/passenger side for you?) that fails because of engine rotation.
Well, drove it around a bit, and there's a little chatter. Not terribly overbearing, but noticeable even on flat roads. It can be drowned out with a little stereo volume. I'm ok with it, I just feel better having the sway bar back on at this point (the difference was noticeable on the first turn.) I think I may revisit a previous idea to use some sort of bungee or spring to compress the link together, essentially keeping the balls seated into the sockets. I think it's just the 180° joint that's making the noise, so I may even just make that end a 90° and fashion an L mount for it.
Front Wheel Bearing assembly and/or bearing - Right part?
hawairish replied to DanF.'s topic in 96-2004 R50 Pathfinders
Go for it, though I doubt they'll give two farts about it. All the application data comes in from various sources, and that data probably lacks all the other/correct values that would normally lump it under the 5.6L subgroup. It's a little surprising to see that not all of the wheels hubs listed for the 3.5L don't also appear under the 5.6L, though, but that's also an error. Bottom line is that the Armada was the only 5.6L "Pathfinder" in 2004, and no R50s used bolt-on style wheel hub assemblies like that. The R50 wheel hub attaches to the spindle using a single wheel bearing lock nut. -
That Timken wheel hub (and all those wheels hubs shown erroneously under the 3.5L) are for the 2004 Pathfinder Armada. The 2004 application listings for the Pathfinder and Armada are screwy across the board...they basically list the Pathfinder has having both 3.5L and 5.6L engines because the Armada was just an edition like SE or LE, despite being a completely different truck. Nissan dropped Pathfinder from the name in 2005, but don't be surprised if your the parts counter rep still asks if your 04 has a V6 or V8. And yes, you just need to replace the bearings. There are two per hub (inner and outer). Some don't come with races, and it's recommended to replace them as sets...check the RA descriptions and pics to see what's included. These are what I installed on my buddy's 02 a couple months ago: WJB WTLM300811, front outer (race only) WJB WTA37, front inner (bearing and race) WJB WTLM300849, front outer (bearing only) There's also a wheel seal (grease seal) to replace. I used SKF 22230, but any labeled as "front" or "front inner"will do. See AX-7 for the component breakdown: http://www.nicoclub.com/FSM/Pathfinder/2004_Pathfinder/ax.pdf -
Can't help with tank placement, but if it's just for filling tires, you could go tankless. I use the same compressor as KovemaN, but mine's mounted and hardwired. The compressor is rather quick, too. The problem with a tankless setup is that you need to control the compressor in some way...it'll obviously keep trying to pump air into a closed line when you remove the tire chuck. I use an adjustable pressure relief valve off a tee. When the line backs up to the set pressure, it just blows it off. This way I can leave the compressor running, drag my hose around the vehicle, attach to tire (this lock-on chuck has been great, btw), disconnect to check pressure, re-attach hose, etc.
04 LE that needs new suspension
hawairish replied to 04Pathfinder's topic in 96-2004 R50 Pathfinders
Specifically for the rear, since you plan to carry/haul loads, I'd recommend either the OME springs or AirLift bags. Rear spacers alone won't improve ride quality or load handling. If you have the 2" spacers and don't need more lift than that, then consider stock components. Or consider just using the individual 1" spacers to dial-in the ride height. The OMEs (springs, shocks, and struts) will do great, but are the pricier option. You may find that 2" front spacers on KYB struts with stock springs and 1" rear spacers with OME springs or 2" rear spacers, AirLift, and stock springs produces something suitable for your DD. (No matter which route you go on the rear, you'll also want to consider longer shocks.) -
R50 Tire Carrier Mod: Let's settle this!
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
Thought I'd give a follow-up on this install. It's been almost a year and the carrier has held up just fine, with a few observations and changes... I did eventually reinforce the area where the latch striker mounts because of the slight bending that was occurring. This area must've also been reinforced from the factory. I didn't take any pics for some reason of the fix (I'll try to remember next time I pull the bumper), but I took a piece of 1.5" x 1.5" angle aluminum, trimmed .5" off one side to get an "L" shape, the riveted the face and bottom to the chassis. I only exposed enough hole for the bolt, effectively sandwiching the blind nuts. This will definitely hold up. I also did mount one of my leftover liftgate struts to the arm. I bought some ball studs from McMaster-Carr, perfect fit for the strut. You probably won't be able to use this if you didn't change the hinge pins to bolts like I did, since this allows me to tension it just by tightening the bolts. Otherwise, the gate will fly open! The leftover strut doesn't hold it open, but a new one would probably do the trick. It does, however, open smoothly and on it's own if I just give it a little nudge. I wore through the paint a little on the plastic trim piece above the license plate area on the liftgate. It rubs on the back of the release handle on the gate, which also has a little wear. I knew it was close, but the plastic has worn down just enough that it's no longer a problem. I think I mentioned it earlier, but the liftgate on older R50 (and also QX4) is different from the later R50. I don't think you'd have the rubbing problem on the older R50. But one thing mentioned from another post is that the QX4 has the reverse lights next to the license plate, so the tire would block them if you did this mod. You'd have to swap taillights and re-wire, or come up with some custom reverse lighting solution (or perhaps the taillight harness already has the backup leads?). -
Suspension "kits" reliability
hawairish replied to pathfinder1990's topic in 96-2004 R50 Pathfinders
There's apparently a new player in the spacers market on eBay. Mine are from "hoepkers", but there's now an "allroads-inc" seller to check out. http://www.ebay.com/itm/282075830080 http://www.ebay.com/itm/272226007774 I do question the 2nd seller a little because they have separate listings for front and rear spacers and have the images incorrect (rear spacers being sold as front spacers). He's also offering 2.5" front spacers too, but that's too much IMO without needing an SFD. The truck in the listing looks familiar...I've seen it around here somewhere. -
Where'd you end up welding to? I feel like the attachment tubes may be too long...if the truck were to rest on the outermost rail, that's a lot of leverage at the mounting point. If it doesn't cause damage there, it seems like it could pin up against the rocker panel, no?
They'll still fit, but you'll lose that 1.5-2 in shock travel (extension). It's recommended that you get longer shocks, but you won't find anything R50-specific. There are Bilstein part numbers floating around, some guys (including self) use shocks for older F250 trucks. I'd recommend the former option if within budget. -
Glad I'm not the only one. My cabin does eventually cool down, but with our summer heat, it's not surprising if my long drives (recently a 2hr drive down to Tucson) require full AC/re-circ the entire drive. Black leather seats probably don't help much either. Conversely, my wife's Sorento cools down within minutes. Middle row pillar vents, more powerful blower, rear AC, and darker tint. The only thing it lacks is crotch AC.
Strut spacers have no impact on the ride quality or strut top out. They don't change the characteristics of anything...it's just a static lift height. You might need longer rear shocks if you use spacers there. You should have no problems running stock rims. The reason they mention it is because when you lift the front, the wheel moves down and inward relative to the chassis, which means your tires may rub somewhere when turning. You can accomplish the same thing with wheel spacers, if desired/necessary. The OME kit does not require new wheels...but if you get larger tires, you may need new wheels or wheel spacers to move the tire away from the lower spring perch on the strut. As for the kits...do you need to replace everything? I would only replace what is really necessary, and if that's the case, you can save money buying less parts. Opinions on Moog here will vary...personally, I have no problem with other brands, and since sites like Rock Auto provide actual parts pictures, it's easy to see when one part might be better than another, or have desired features. -
One year later, here we are again. A few months ago, I had a pucker moment on the freeway that gave me enough reason to just put my sway bar back on (I've had it off for a several months now). I swerved away from a vehicle that was coming into my lane hard and was oblivious that I was already there...swerved, then counter-swerved...I'm lucky I didn't take out another nearby car. I'm confident my sway bar would've made that a safer experience. I've been sitting on these crappy Steinjäger/MCP joints ever since. Their customer service is the suck, and I flat out got tired of dealing with their people, emails, and BS. I'm not fond of the joints (see my posts above, plus a couple more here). But in reality, since I wanted to put my sway bar back on, all I really need wre just some slightly longer end links. Seeing as I had all the materials already, I gave things a shot today. 180° joints on the stock hangers. The studs on the joints are 1/2", and because the hanger seats rubber bushings on the OE end link, the hole is actually larger than 1/2", which means no drilling. However, the hanger also has cupped mounts (the top is cupped, and the bottom has an integrated cupped washer), so I used 1/2" thick washers on both sides to create flat surfaces, which I used serrated flange nuts with. The sway bar ends fit 10mm studs, so they were drilled out to 1/2" and the 90° joints secured with a nylock nut. The flange nut had too wide of a diameter to be useful here. The detachable link is just threaded run and flange nuts. One obvious flaw with the joints here is that they have no way to put a wrench on them when use the flange nut as a jam nut. They're snugged up, but there's really no twisting motion when the sway bar is cycled. There's about 1-1/8" of threaded portion in each joint end. Driver's side installed. Passenger side installed. Removing and installing them is quite quick as you can see. Of course, this requires laying on the ground, reaching around the tire, and fishing one arm up there. The spring on the 90° joint is far stiffer than the spring on the 180°. It's a little tougher getting the 90° joint off without a glove, but I also have some small concerns about pinch points. I've not taken it for a drive yet. When shaking the sway bar, the upper joint did rattle a little. But unless the entire bar is rattling, I don't anticipate enough noise to bother me. I'll follow up when I do take it for a ride. I also had to rotate the 180° joint's opening a specific way because of design/manufacturing shortcomings on the joint. Only under a certain orientation with the ball stay centered in the socket with the slight angle of the link. With the way it's oriented, it has the best chance to stay centered or re-center on travel. When removed, the bar will rotate down and rest on the 3rd member, which isn't desirable. For now, I'm not worrying about it...I don't plan to have it disconnected anytime soon. I just needed longer links, and these are about 3" longer to account for that amount of lift I have. But when I do circle back on it, I'll revisit ideas on how to pin it up or how to let it rest on the 3rd member.
Not that I know of, though there are several N4W'ers in the metro, and an event is coming up. I'm just north of you, Cactus/303. Maybe we resurrect the AZ roll-call thread in the Southwest region section?
I face a similar problem, but I think it's just the nature of the truck (insulation wise) and not any mechanical problem. Weather here this time of year is in the 110°-120°F (43-49°C) and I find that my truck just can't keep up cooling the interior, but it blows nice cold air just fine. When it's closer to 100°, it's more efficient of course. The difference is "hot" vs. "damn hot" in my case. Doesn't look like Dubai is too far off from those numbers.
It's below the pre-tensioner at the bottom of the B-pillar. If you have a 2001, see RS-13: http://www.nicoclub.com/FSM/Pathfinder/2001/rs.pdf If you have a 2001.5, see RS-14: http://www.nicoclub.com/FSM/Pathfinder/2001.5_Pathfinder/rs.pdf They should be very similar or the same systems, but I'm not sure the mfg date cut-off. 07/01 or 09/01?
Sorry for the previous dud post. I originally mentioned you could just punch the tone ring off, but then I realized I was thinking of my wife's car. On the Pathfinder, the ABS tone ring is pressed onto the wheel hub, not the CV. So, you won't find any CVs with tone rings installed...and consequently, when swapping it, you won't even need to deal with it.
Edited: Disregard.
