hawairish
  1. I don't think it'd be too tough to grind out. When guys have been doing the Titan wheel swap (or similar), where they have to bore out the hole, they use a router with guide roller on the bit. A Dremel probably wouldn't be terrible. Just be mindful of heat in both scenarios, as it may damage the finish on outside of the center cap hole. For the center cap, you could probably just put a thick o-ring around the recessed part and just wedge it in. I know you got a good deal on the hubs, but couldn't you also return them (or resell them) and go with the other hub style and save all the trouble?
  2. Yeah, an aftermarket radio—even an inexpensive basic one—offers more features than OE these days. It might be the only place where I struggle to keep things OE. But, that said, I still have my OE Bose unit sitting around if you're interested.
  3. Sorry Mojo, I meant that for tdurb1327 to get numbers for the AC springs. But, are you running stock springs? 100 lbs/in sounds about right for stock springs if they're worn a little...though if he just sat at the rear of the truck and not directly over the axle, that number would be a little lower than actual.
  4. Bummer about fitment on those. That was my concern, just that little lip. Does the back of the hub not recess further into the wheel because it hits that lip? I tend to like the OE look, so not sure I could grind that lip if it meant not using the center caps. It seems like such a trivial detail, but I'm also the guy who bought an extra cap just to put it on spare tire. As for your other questions... The rear wheel bearings are well-protected, and that's not even factoring in the drum. I wouldn't worry about debris getting in. Most 6x5.5 wheel spacers you'll find are universal in that they'll have a large (108mm) wheel bore to fit anything with that wheel pattern. If you find some that are specifically for Toyota, then it just means they have 12mmx1.5 wheel studs, and possibly use mag-style lug nuts. If you can find some labelled for Nissan, they'll have 12mmx1.25 wheel studs. Anything for GM may have some standard thread. The ones you linked have Toyota threads, and depending on your preference you'd need to replace at least one set of lug nuts to use them...so I'd pass on those. Also, though because we have 100mm wheel bores, you may want some hub-centric rings to center them up. With the thicker spacers (say, >1") you shouldn't need new wheel studs. You may notice a little more resistance at the steering wheel. And because the wheels push out that much more, there's a little more work involved to move things, so more stress on ball joints and TREs. But, it wouldn't feel any different than if you just change the wheels to an offset with the same amount. However, a wheel spacer does introduce more points of failure.
  5. Just curious, how are the rear springs when unloaded? Not too bad? I always hear about the front springs, but not the rears. You know, one way you could ballpark the spring rate for us is to maybe have 1-2 people sit in the cargo area between the wheel wells, then measure how much the rear lowers. Presuming the springs are constant rate, then it's simply lbs per in. So if two 200-lb guys make it 1" lower, then that's 400 lbs/in, or 200 lbs/in per spring. I wouldn't mind knowing if you have the means.
  6. Nah, don't worry about the half oil change. Keeping the oil clean is the filter's job, and replacing it during your scheduled oil change is just fine. No tools should be needed for the filter. When it's replaced, you should only tighten it by hand anyway, so removing it shouldn't require much more than that. However, if it does feel too tight, let the truck run for a minute or so just to warm things up a little, then it should loosen up a little. Not sure if yours has the little "oil channel", but mine has a metal bracket that catches excess oil coming out from the filter port and channels it over the steering rack. I don't think the older trucks have this, but it's brilliant since it's the only part that gets oil on it (and it wipes clean easily). They do have wrenches and special oil filter sockets of course, but I've never needed them. Except one time. Some dipsh## changed the oil on my buddy's truck and deliberately over-tightened it. I had to destroy the filter (basically punched a large screwdriver through the filter) to remove it. How do I know it was deliberate? They wrote f#ckface on the filter for whatever reason. It wasn't even my truck and I was ready to burn their shop down.
  7. Well, nothing prevents you from removing the oil filter without draining it. But no, you normally would not do this. You will drain some of it when you remove the filter, and there would be an unknown amount of oil remaining in the pan...you'd have to guess how much oil to replace. Why do you ask?
  8. Was that for the front spring though? Front OE is 150 and OME is 200, so AC at 220 seems reasonable there. You'll like them. They've done well for me. Though, right now they appear to sag but it's because my truck doesn't rake unloaded. Working on that...
  9. ...but yes, the OMEs are in the middle in terms of lift height and presumably spring rate.
  10. Nope...the ones you linked are the OME ones. The $180 springs are the AC ones.
  11. Stock springs are 120 lbs/in, while the OMEs are 140 lbs/in. Not sure about ACs, but likely higher.
  12. Don't be fooled by the AC listing...those are the OME MD springs (rear HD don't exist). They don't give much lift, but the load handling is good. AirLift bags are also an option to help with load, but they are not for lifting. The only R50-specific option that would be firmer would be the actual AC springs, which have a higher spring rate that provides lift. I'd consider that your HD option. If you're going to explore WJ spring options, get a taller lift spring and ditch the spacers...too many parts to deal with.
  13. They're just a breather ports between the covers, so tapping it out and using aftermarket fittings is likely viable, as long as it can withstand the heat, not fall part under the covers, and resist oil/leaking.
  14. I bought a pleather one off eBay, worked just fine.
  15. Like Slartibartfast hinted at, try checking the brakes or other components in case there are other components needing replacement or giving a false noise...wheel bearings, u-joints, brakes, etc. If you're just wanting to rebuild the LSD, you can find the part numbers in the FSM or pretty much any of the several Nissan parts websites out there (nissanpartsdeal.com has become my new favorite reference, but I still tend to buy from courtesyparts.com...but pretty much the same prices). The FSM also provides all of the setup instructions, many of which you won't have to do if you're just changing carrier internals. However, be sure to check that everything is in-spec before fully disassembling the carrier...that way you have some sort of reference point, or can identify any other parts needing replacement. Specifically for the LSD internals, that catch about rebuilding it is that it helps to know in advance what parts are worn...which basically means having it apart while you wait for parts. New friction plates and discs run about $30-$35 each, and your diff has a lot of them. It's not practical to replace them all, and FSM specs wear and warp limits. If you just want to freshen it up, you can just buy a couple of new discs and plates. If you want to increase the break away torque, you can swap out any thinner discs/plates with thicker ones (nominal size is 1.5mm, but 1.4mm and 1.6mm are available for adjustment pieces). Again, see the FSM for measuring the clutch pack thicknesses. Also consider these parts: carrier bearings inner oil seals (for axle shaft; these install in the axle tube at the ends) LSD-safe gear oil u-joints (since you'll have the driveshaft down) You'll also need to rig up a tool for side-bearing adjustment. Rugged Rocks sells one, but I just made my own. You'll also need a dial indicator and magnetic base to check backlash and run-out...hit up your local Harbor Freight.
  16. The Owner's Manual should have all the instructions and available settings.
  17. Following up... Left to right: 31-spline WD21 w/ discs 31-spline D22 33-spline R50 D22 shaft is the same height and only 1mm less in shaft diameter. Same bearing cages for all three, which means using it on the R50 only requires swapping the brake backing plates due to differences in the parking brakes. Test fit of Spartan locker for Y60/Y61 Patrol in R50 open carrier. Just needs thinner thrust washers. Lokka is on it's way. Stay tuned for the write-up, which will also include details about the WD21 disc brake swap.
  18. Yikes! What was the truck doing when it caught fire? And any oil/grease build-up on the engine, or does it look like it came from the fuel rail? What doesn't work now? At minimum, you'll likely need new coil packs, injectors, hoses, and probably a new engine wiring harness (or at least enough to splice in on that side). That AC line may be compromised, which also means AC work. If it turns over, I imagine it would be salvageable, but probably best to see what the insurance company has to say about it to know the financial burden.
  19. The 50/50 stuff is convenient, but not worth buying unless it's less than half the cost of straight antifreeze (because the rest is just water). The 3.5L takes a little less than 2.5gal of 50/50 mix. When I do it, I buy 1gal of straight stuff, 1gal of distilled water, and 1gal of 50/50. I'll use up the antifreeze and water first, then top off with the 50/50. That way, when done, you've got the remainder in a single container, ready to go (I carry it on road trips, just in case).
  20. Ha! Hope that's it. I was just wondering the same thing when looking at the pics, before reading your comments.
  21. Yeah, if there's some play between CV spline and drive flange, that's probably not good. When you check the wheel bearings, pull them out and clean completely. Races, too (they can stay in the wheel hub). The ungreased bearings should spin freely in the races. You'll notice any binding or hesitation. When putting everything back together, don't forget to torque the ring nut to spec, then back it off a little. About the aftermarket wheels, just be sure the lug nuts aren't topping out, preventing them from being fully seated. I've seen the case where steel wheels, with thinner flanges than aluminum, needed longer or open lug nuts. Also check if the lug nuts are the right type for the wheels. Tires can be noisy at certain speeds. My front left tire on my other SUV does that. Drives me nuts because I've rotated it around and the noise just travels. May want to try swapping sides on things to see what noises carry, including wheel hub.
  22. I see, thanks for the explanation. I wouldn't have expected so much movement considering how the diff is mounted, but with worn bushings I can see that. But really it boils down to a manufacturing defect? I mean, how different is the cross-over point on these pipes vs. stock? Or is it same bends but with larger OD tube? Slight workaround, but could you use spacers and longer bolts on the snout's mounting points to increase the driveline angle enough to clear? Or are there offset bushings for the cross member by chance?
  23. Isn't the diff basically in a fixed position though? Even during flexing, the diff stays relatively stationary to the engine, trans, and t-case, minus small adjustments in mounts and bushings under torque. Both diffs were low-pinion, but if one snout was shorter than the other (a difference between R180 and R200?), the shorter snout would decrease the driveshaft angle and increase the gap, right? Sucks to have come this far, though. Hope you find a solution soon.
  24. I was thinking it'd be unlikely because a damaged flange would be pretty noticeable when removed (damaged splines, metal dust, etc.). But, I also want to be sure we're talking about the same hubs (drive flange vs. wheel hub) and axles (R200A vs. CV axles). Drive flange below. There should be very little tolerance when it slides on the CV shaft. If you slide this on the CV but not bolt it to the wheel hub, is there rotational play?
  25. The OE hub (aka drive flange) is a very simple piece. Not likely the point of failure here, but easy to tell. When you say, "the play is all between the axle itself and the hub, so not coming from the cv", are you talking the axle as in differential? The connection between the CV shaft and the wheel hub, joined by the drive flange should have no play. If it's not that, then it's either a) the outer CV joint, the inner CV joint, or c) the differential (and small play here isn't abnormal to me). Though, I can't see how any of the above rotating parts would only make a noise at low speed, including bad wheel bearings. Do you have OE wheels? Short lug nuts?...anything that might prevent the wheels from coming into full contact with the wheel mounting surface? Any noticeable wear on the wheel studs? Thinking outside the box for a moment.
