221
Everything posted by adamzan
It's definitely not the TC. The rpms don't move at all when it does it and the TC is locked.
I never said it was dark brown...
My original ones are still going strong. Though i don't open the hatch that much anyways.
Just to let everyone know, I have solved the issue finally! The switch that cancels the cruise failed. I removed the plug and tested the switch for continuity...There was none. So I jumped the plug with a piece of wire. Took her for a drive down an empty road and voila, cruise! I feel so dumb for not checking it before...But whatever. Also, when I went to cancel it I hit the brakes out of habit, and it cancelled! According to the wiring diagram, the brake light switch sends a signal to the cruise computer as a failsafe shut off. I'm gonna get a new switch but at least it works for now. But the vacuum hose must have a leak because the speed slooowly creeps down.
Well the tranny fluid and filter were done last weekend by a nissan tech and he said it looked normal in the pan, though the fluid was a little dark. This has been happening for a while before that anyway. My engine doesn't burn any oil and my plugs were a brownish color, apparently what it's supposed to be. Will do that. Will take it to my buddys shop so I don't have to lay in the snow. I'm gonna start with a dizzy cap and rotor, thing is that one of the heads of the screws is stripped so I can't get it off... I know, bad habit
For the last few months I've noticed that my truck will start to jerk almost as if the engine is stopping and starting again, but only when in over drive with the torque converter locked, and under 2k rpm. If your light on the gas it will be ok but as soon as you want to accelerate it will do this unless you make it kick out of the torque coverter lock. On the highway whent it's revving at 2400 to 3000 depending on how fast I go it is perfectly fine. The trans doesn't slip or anything so I'm really confused on what this could be. Gas mileage seems alright as well. But it has felt "down on power" lately. And you guys know what I mean since we only have 153 hp... Drove it to toronto and back last weekend and it didn't do it at all on the highway, only when below 2k rpm it seems. Only starting to do something about it now as I haven't really been driving it that much since the middle of summer.
Lighter steering feel? Man do you have twigs for arms? I've driven chevy, ford, dodge, and nissan trucks and I don't even notice a difference going from one to another, well maybe the ford, as it was leaking PS fluid.
You know you can adjust it. Look in the fsm
The daytime running module is on the left side of the battery, kinda inside the fender. Remove the battery and you'll see it.
Have fun getting the pitman arm off if you need to. Mine has quite a bit of play as well when you're going straight. Like 1.5 inches I'm guessing. Though my truck has 180k, so is that expected or what.
Will A Bull Guard From A 87 Pathfinder
adamzan replied to ac92pathfinder's topic in 90-95 WD21 Pathfinders
It's actually supposed to be black, just faded over the years. -
Wonder if that could be installed on one our NA wd21s
http://lmgtfy.com/?q=how+a+torque+converter+works
My 93 came with a nissan carphone
I would suggest you leave your truck as it is.
I was looking around at coolers last week, and the guy in the shop said to me "I could sell you the biggest cooler I have but to be fair you only really need an 18-24k and that is if you're hauling big loads". I don't know if he's right but he said defintely remove the stock cooler. Which I know is right. I should really do a gauge too but that is a lot of work right now in these frigid temps.
I think I need to change my tstat too. You have to drive around for well over an hour to get really really hot heat. Otherwise you have a choice, defrosted windows, OR warm feet. The mix setting will not warm your feet and the fog starts to encroach around the windshield
If the engine runs well don't fsck with it.
I've had mine at 160 km/h and it felt perfectly fine. This was just after I had my whole steering/suspension replaced and alignment done. Also it was revving just below 4k with the 31's. With 235 75 15 tires the brakes work pretty damn good at highway speeds actually.
I'm pretty sure he's stated around here that he has 31s
I would say check the wiring to your MAF sensor, and clean the sensor itself. Also check the o2 sensor, cylinder head temp sensor. Did you read the sticky in the garage on how to read the codes? Even if the CEL isn't on but it has been before the code will still be there unless you removed it.
Crap. I meant the abs valve. Sorry!
Throttle position sensor maybe?
Yeah this is the "code" for dead alternator. If you have an AT it will be brake, battery, and AT TEMP lights.
Try bleeding the proportioning valve again, if you didn't already do it a couple times. Its a bitch to bleed.
