adamzan
Moderator
Everything posted by adamzan
  1. You noticed that too? I'm on my oem starter and it has sounded the same since I bought it but I know a few people who've replaced theirs and now it sounds like a VG33 r50, much quieter and softer sounding lol.
  2. Yes it could come apart. When my dad first bought his r50, not long after he picked it up at the dealer it was making a funny noise under the hood. He brought it back a couple times and they finally found the harmonic balancer rubber insert was worn. The mechanic said he's seen it happen once and it came off, something punctured the rad, snapped almost every blade off the fan, a nasty mess!
  3. I was just using the stuff that is in the washer fluid...
  4. RainX also makes me furious at night. If the wiper blades aren't brand new it will leave a film every time you wipe.
  5. This looks awesome. I want an r50 now! Btw for the rear discs could you not steal a set off a WD21 pathfinder maybe? Since the rear axles are the same (pretty sure) it should fit, right?
  6. Look at the strut and you will probably be able to see where the oil has come out it will be wet on it.
  7. adamzan
    Radio Help
    May as well just get a new one, unless you like tapes.
  8. Try spraying around the windshield with the hose, I heard it can leak from around there down under the carpet.
  9. No he means ECU coolant temp sensor. They are both a coolant temp sensor (in a parts list) but one is for the gauge on the dash and the other goes to the ECU.
  10. Do you have a pic? I would definitely do this to mine.
  11. Ask for one for a 94 pathfinder. I had the same problem apparently the 95+ nissan/infinity style plugs were not in the 95 wd21, they are like 94 and prior.
  12. I need the two door ones too as i got a hatch one out of the parts truck but the other 2 were seized like mine are.
  13. How much mileage on this thing? It may just be time for a new starter... The fusible links are short pieces of wire that burn out instead of something big blowing up. You can see them on the positive side of the battery on the cable.
  14. Well mine kept coming loose, even with new tie rods on it. So I spent the 15 bucks and got new sleeves
  15. Yeah it's easy to do. Even living in the "Rust belt" my idler arm mounting bolts came off with ease and they looked to have never been removed before. Count the threads on the old tie rods and adjusters and make it as close as possible on the new ones, so the alignment will be somewhat correct. Also you should get new sleeves if you get new tie rods. One of mine was stripped
  16. Don't get a rebuilt one from autozone. Apparently they are crap.
  17. Someone get a parts truck with a rotted frame and try it lol...
  18. I think you can use gm synchromesh
  19. 152k miles...was the timing belt ever changed?
  20. The woodruff key sheered didn't it.
  21. Looks like you'll be getting a sweet new engine before you expected!
  22. Well first off. Running straight pipes is not what you want to do on one of these engines. It's not a barbaric 50's chevy, it needs back pressure to run right.
