adamzan
Moderator
Everything posted by adamzan
  1. adamzan
    My Heater!
    try hitting the blower motor, its under the dash on the passenger side, you'll see it. just give it a few hits with your hand. If it does come on then something is keeping it from turning or the motor is dying. I managed to fix mine by cleaning the brushes though.
  2. I wonder if the Quebec version says LE Pathfinder
  3. The LE pathfinders have that. I like it. And the avatar is awesome. To hell with the gray area.
  4. adamzan
    Drl Fix
    It happens on wd21s often as well, mine included.
  5. What brand of filter do you use. I have a purolator premium plus on right now but I usually use motomaster (Canadian tire house brand)
  6. Yes and it is recommended to reduce buildup which can lead to oil burn off in the vq motor.
  7. A kit to plate the common parts of the frame easily? Especially the more rust prone areas. Like a pre made frame cap.
  8. Ok so have you taken it for a drive and disengaged the OD at 40-50mph yet?
  9. Mine was doing that and then it stopped working all together but after removing and cleaning up the brushes it works fine and is silent again.
  10. Wow...Its not that hard to get at, at all. I've gotten so used to doing oil changes on the pathy that I can do it in 5 minutes and know how much to pour out of the 4.4L jug just by eying it... Also if you don't want your starter to take a bath make sure you don't tilt the filter down when you remove it...easy.
  11. I was just being sarcastic. If your spark plug wires look pretty old I would just change them anyways. Wouldn't be surprised if they were original.
  12. Yeah, go for a drive and turn the OD off at 50mph and see if it jumps up. Its possible that your torque converter isn't locking up because the truck doesn't have enough power to turn the tires under load in such a high gear.
  13. When the OD light is on that means the OD is OFF. Also replace the filter don't bother cleaning it. It's only 20 dollars or so for a new one.
  14. What happens if you put it in gear and then give it gas will it still die?
  15. On my original exhaust I noticed that it was cut and welded on both sides of the tranny pan, I guess whoever was in there last got lazy.
  16. If you can get the broken part of the key out of the ignition the locksmith can make you a new key from it.
  17. adamzan
    Brakes...
    Ok, here is an update. I replaced the front brake calipers, rear brake drums (chunks of mine kept coming off and the parts truck had 2 like new ones, so I machined them) and bled the entire system. I can stop pretty damn good now! But I do have one concern. The pain on the booster right below the master cylinder is all peeled off and there is rust under there. I'm not concerned about the rust but the fact that this area was wet. I am not losing any more fluid so far. Also I noticed that there is a hole in the MC right in between 2 of the lines that was wet, and bubbles were coming out of it while I did the bleeding, what is that for?
  18. Shocks, tension rod bushings, swaybar links, steering components. I've found on these trucks if one little thing is loose the whole front end feels loosey goosey.
  19. If it were me I'd buy it. I'd love to have a 2 door.
  20. No, you will be fine. I try to avoid the highways here because when I have to pass someone I usually have to take out OD and have it rev at like 3700rpms! I drove down to toronto once going 130km/h the whole way, with 4.6 gears and 235 75 15 tires i was revving about 3100. Actually got better mileage than when I do 100km/h at 2500rpms. With the 31's now it revs at like 2200ish at 100km/h. I can do almost 140km/h while keeping it under three grand.
  21. There is a filter, it looks like this: It's only around 20 dollars, may as well replace it.
  22. Try wiggling the maf sensor wires then rev it.
  23. Not to go off topic but where did you find a "new" alternator in ontario? All I could ever find was rebuilt @!*%.
  24. I believe Simon has the same issue as you. Saw him post about it somewhere.
