adamzan
Moderator
Everything posted by adamzan
  1. Tighten up the screws on the fuel line clamps under the hood. I don't recall exactly which ones cause it but check them all anyways, couldn't hurt.
  2. How did you weld the hole inside and around the coil spring perch on the inside of the frame?
  3. the cell holder was for the factory carphone. Its a 93 SE It says PUSH on the front of the panel
  4. I managed to snap some pics of this thing finally. Also the truck has a factory cell phone holder to the right of the center console. Its not in there now though. There was another thread where someone asked for pics but I forgot.
  5. Yeah our vg33 has 245,000 on it and my dad runs 5w50 in the winter and 20w50 in the summer. Both synthetic.
  6. What I did, since the bolt snapped off anyways, was grind off the welded nut and use a nut/bolt/washer combo. Been working for over a year now.
  7. adamzan
    Brakes...
    Also I have another symptom to report. If you're stopped like in park or something, and you stomp on the brakes a few times the idle starts the fluctuate and the truck sounds like its gonna stall... I didn't have time to look at it this weekend though
  8. You should be able to see some screws holding the grille on between the grille and the bumper.
  9. Did you use the recovery console or w/e its called when it asked for the password? If you did you should just hit enter if there is no password. That is how I've always done it.
  10. All 3 of mine had pre-cats when I got them. I got a whole new exhaust on the gray 95 which included a new cat and there was only one this time. Haven't had it through emissions since I got it (the truck, near the end of the year) but we will see next year. Though I noticed on the emissions test report for my dads r50 that here they tightened up the emissions requirements.
  11. The nissan ATF is the best, but any dexron III will work. I'm using the motomaster ATF from canadian tire... It works...
  12. I don't know if you can get the rods anywhere other than the dealer but don't get them at a junkyard. They are likely to be just as worn as yours was before it broke. You can get the bushings from www.rockauto.com or any parts store.
  13. So there was something wrong with it, and you didn't tell us before we went on the trip??? BAD BRANDON!!!
  14. Throw it in the parts bin and buy something else (maybe groceries? Random @!*% at walmart?) while you are there, they will probably just let you go through if its under 50 bucks worth of stuff. I go through the border to get parts frequently and usually they don't even charge me duty even if I don't buy anything! Maybe I just get lucky though.
  15. When I brought my pathy into the dealer they were all shocked with the kilometers but told me it had many more left in it.
  16. So that is what your spelling is like without using firefox's spell check first.
  17. If you restart the truck and it cures it, that sounds electrical.
  18. That is the same one home hardware cut me and it broke in 2 months. I'm looking for oem nissan key blanks. You'd think they could order something like that. I'm one of those people who likes everything to be original lol.
  19. Wiggle the wire on your MAF sensor. I'm willing to bet that's it. Removing that pipe shouldn't have done that.
  20. You don't have to touch the torsion bars when doing the lower ball joints. Just remove the auto hub and snap ring so you can maneuver the CV around to get the BJ out. It helps to have a second person to lift the wheel hub.
  21. Can you actually see that it's bent? Or are they just refering to how it twists when it's worn out?
  22. Maybe whatever it was holding broke off.
  23. adamzan
    Brakes...
    Gonna try bleeding the brakes, cleaning the slide pins again, and check my calipers and drum adjustment again this weekend. If that doesn't do it I'll have to look into the MC or the booster. It veers to the right when braking...turns the wheel on you! I replaced the brakes last year and I bet that one side is worn down to nothing already. Btw I tried pulling the ABS fuse for my drive home, and there was no difference. At least that is ruled out.
  24. B you can adjust the steering box to tighten it up. I might have to do this to mine in the near future as well.
  25. When you go to the dealer to get a key made do they make you a nissan key or some crappy universal one? I'm picky and keep breaking the cheap copies.
