adamzan
Moderator
Everything posted by adamzan
  1. Actually, you're supposed to put it in Neutral. Anyways OSR is right. You can't be moving or in gear when going to 4wd low range. That grinding is the Tcase protesting you forcing it into lower gears while stuff is still turning. If it is the manual shift tcase it's the same as the wd21 as far as shifting to low range goes. The electronic shift I'm pretty sure you still have to stop!
  2. How can people stand the blue? You can't even seen the damn needles.
  3. Did you accidentally get bushings for an r50 tire carrier instead?
  4. Sounds like its the dreaded maf wiring. Try wiggling the wiring at the connector and see if it goes away.
  5. I voted for stock paint. I used semi-gloss on mine which I thought was the OEM finish. I remember one time I was in downtown Toronto and I saw a wd21 with gold painted tire carrier and fender flares. It scared me.
  6. I bought the monroe steering stabilizer from rock auto it fit my factory pin, but didn't come with any hardware. FYI.
  7. You could also go to a heavier weight oil and add some lucas oil treatment.
  8. Looks great. But won't it be a pain if you have to put something big back there?
  9. The VQ35 is well known for oil burning issues. You may not have blue smoke but it can still be burning. How many km's are on it? The 3 or 4 friends of mine with 3.5 powered vehicles started losing oil at 180k kms.
  10. It does matter. If the hole is not repaired then the new bushings will wear out in a short time and if the rod gets thin enough it can snap. I have seen people fill in the rod and grind it smooth. Or just get new ones. For the hole I had someone weld a washer on the back and they filled it in and drilled it out again. Haven't had a problem since. I used new rods though.
  11. They usually do stay lock if they are not worn out. If they are worn out and the brake plates slip they will unlock at random.
  12. Have you tried banging on the glass a few times with your fist to see if it goes off.
  13. I bought one of their upper ball joints. It didn't come with a blue boot but I've had it in there almost 2 years and its still good.
  14. It sounds as if your fan clutch isn't working properly. If you can spin it really easily it is probably done. My dad had a bad overheating issue on his r50 and it turns out his fan clutch was gone and his radiator was clogged up. It started out with just whehn the air was on but then it happened all the time. When its really hot outside it should sound like a bus.
  15. Nice work. One thing though, is there a chance it could hit the sway bar if the suspension really compresses or are my eyes just messed? Xplorx4 beat me too it oops.
  16. Bought an air filter but the laziness took over so I threw it on the back seat.
  17. I bought mine at princess auto for 45 dollars.
  18. You have the stock radio? There should be one amp below the radio and one in the cargo area. It really sounds like you have some blown fuses have you checked all of them to make sure they're not blown. Sometimes you gotta look at them real hard.
  19. I paid 18 dollars on rockauto for a set of "autolite" brand ones about a year ago and haven't had any issues.
  20. According to the FSM minimum brake rotor thickness should be 20 or 24 mm. It specifies 2 different types. I couldn't imagine a 260mm thick rotor Minimum for the rear is 16 mm.
