adamzan
Moderator
Everything posted by adamzan
  1. You can still drive it without abs. If the brakes still feel good with the fuse pulled I wouldn't worry about it until you have the time to deal with it.
  2. If you hook it into the signal lights will it screw up the rate that they blink?
  3. Did you make sure to put the new copper crush washers on and tighten the line properly?
  4. I picked mine up from Crappy tire and it's been fine for a year so far.
  5. Yeah it works better with the tube. I couldn't find mine but the nozzle shot perfectly straight so I just had good aim lol.
  6. Yeah that stud missing will definitely cause a tick. My gas mileage sucks not too because it's winter. They changeover to the "winter gas". If you smell gas in the exhaust maybe you're running rich, like a bad o2 sensor or something.
  7. Here are the pics. Step 1. Roll down window Step 2. Follow the pictures Step 3. If it didn't help much and if you can move your window back and forth while its partially rolled down then your window regulators are worn. Mine are.
  8. You shouldn't have to take the timing belt covers off to do the thermostat. I was able to get to it with just taking the AC belt idler pulley/bracket thing off and the fan shroud. Taking the fan off would make it even easier. I would try wiggling your MAF sensor wires while the truck is idling weird. Very common problem. It is the one in the tube near the air filter.
  9. Front main seal is easy, you can do that one while you do the timing belt job. The rear you gotta pull the tranny. I would try some lucas oil additive and see if that quiets it down a bit and slows/stops the leak. At 170,000 miles the engine is just broken in!
  10. It does run off a different pump. You should be able to hear it running if it's working. It's in the passenger wheel well area behind the splash guard IIRC.
  11. I used the ngk G-power plugs and it runs great and gets decent mileage. That is what came out of the truck so that is what I put in. The set that was in there lasted 80,000kms (of my driving, who knows how old they were) before I had any issues. I remember when Brandon and I did our plugs on the same day and he had the basic ngks. He noticed a big difference. http://www.ngksparkplugs.com/products/spark_plugs/gpower.asp
  12. Could be O2 sensors starting to go out.
  13. Anything from 96-2000 should work. In 2001 the pathfinder got the vq motor and the tranny will not bolt up to a vg engine.
  14. And I mean 94-95 style dash. I saw it on an SE 94 and an LE 95. They also had the digital trip meters.
  15. I've seen a couple pathfinders with the dash shift indicator.
  16. Oh I did it. Just give me a chance to put the pics up.
  17. This should help you out. http://www.the12volt.com/installbay/alarmdetail/1636.html
  18. I don't know how many amps the cig lighter circuit pops the fuse at but I have my cb, cig lighter with gps, cell phone and power inverter all running off of it and it hasn't blown the fuse and the wiring doesn't seem to get hot.
  19. I used the center console to mount my switches. I just drilled holes in the blanks and the switches fit perfect.
  20. Sorry I've been busy and I forgot. I'll do it tomorrow I promise!
