lint Posted January 31, 2011 Share Posted January 31, 2011 While in the fender, I installed a cut-off switch between the antenna motor timer and the motor itself so I can leave the antenna up or down in the winter rather than fight with the ice and frozen mechanism. That is so damn clever! Thanks for sharing!! Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 31, 2011 Share Posted January 31, 2011 we worked on the gf's truck...found out that the previous owner clipped all the radio harnesses and messed up all the stock speaker wiring so we gave up on that until i can map out a check list...she cleaned the insides out including taking out the center console...i readjusted the rear drums so they won't catch fire...we removed the shady lift springs that were in it and threw them away along with a bunch of other scrap stuff...next we need to drop the front end about 2" to get her sitting back level...oh and i tie banded the turn signals on until we get the new bumper brkts welded up since we put the BL on last weekend Link to comment Share on other sites More sharing options...
RedRider3141 Posted January 31, 2011 Author Share Posted January 31, 2011 Took the Pathfinder and my bike for a ride: 1 Link to comment Share on other sites More sharing options...
SilverPath Posted January 31, 2011 Share Posted January 31, 2011 Started it up and let it run for abit! Link to comment Share on other sites More sharing options...
JamesRich Posted January 31, 2011 Share Posted January 31, 2011 I started it up and listened to the glorious lifter tick of a VG after sitting for a week, backed it up to where it's normally parked, and shut it off. I bet your not rolling the pathfinder much since you got that Z! James Link to comment Share on other sites More sharing options...
Kingman Posted January 31, 2011 Share Posted January 31, 2011 I bet your not rolling the pathfinder much since you got that Z! James I would if I could get it to run right. I should just fix it and sell it. Link to comment Share on other sites More sharing options...
Qx4donald Posted January 31, 2011 Share Posted January 31, 2011 rewired the Fog Light relay to trigger off of the parking-light power wire Link to comment Share on other sites More sharing options...
nunya Posted February 1, 2011 Share Posted February 1, 2011 I bet your not rolling the pathfinder much since you got that Z! James He didn't before the Z... Link to comment Share on other sites More sharing options...
lint Posted February 1, 2011 Share Posted February 1, 2011 Removed the dulled polycarbonate factory headlight protectors and stuck on some "Ricochet" clear headlight protection on them and on the fogs. Need to polish out the scratches on the poly covers and reinstall. Around here, they use freakin' shale or something like that for gravelling the roads and I end up replacing a windshield every year. I can't afford to replace headlights at that rate. Maybe I should tell the Ministry of Highways that there is a product out there called "sand".... Link to comment Share on other sites More sharing options...
crazyhayseed Posted February 1, 2011 Share Posted February 1, 2011 I called my Pathfinder (and my wife) when the Porsche left me stranded today. I was so happy to be rescued, I kissed her. Then I said hello to my wife and drive home. Link to comment Share on other sites More sharing options...
Precise1 Posted February 1, 2011 Share Posted February 1, 2011 Hit red line. B Link to comment Share on other sites More sharing options...
adamzan Posted February 1, 2011 Share Posted February 1, 2011 Removed the dulled polycarbonate factory headlight protectors and stuck on some "Ricochet" clear headlight protection on them and on the fogs. Need to polish out the scratches on the poly covers and reinstall. Around here, they use freakin' shale or something like that for gravelling the roads and I end up replacing a windshield every year. I can't afford to replace headlights at that rate. Maybe I should tell the Ministry of Highways that there is a product out there called "sand".... Factory headlight protectors? I have never seen these before. Link to comment Share on other sites More sharing options...
JamesRich Posted February 1, 2011 Share Posted February 1, 2011 I finally took mine back to the alignment shop to replace the missing shims and fought the clutch the whole way there. This butthead made me wait 3 hours while he supposedly was working on the truck the whole time. It took him 30 minutes to align it the first time. I raided the pick a part and brought him a stack of alignment washers so he wouldn't use the U style shims. He pulled one of the rubber stopper that the upper control arm sits on out and the shim arraignment is completely different than it was before. The side the shims fell out now has only a couple and the passenger side has more than it had before. If it was right before he should have just had to put shims back where they were. I guess I had better take it to another shop to make sure my tires last. While I was there I tagged him on facebook as "the place to get screwed for anything on your car!" Hopefully that will help other people determine what type of place he runs. James Link to comment Share on other sites More sharing options...
k9sar Posted February 1, 2011 Share Posted February 1, 2011 I took apart my power antenna to figure out why it wasn't working. While in the fender, I installed a cut-off switch between the antenna motor timer and the motor itself so I can leave the antenna up or down in the winter rather than fight with the ice and frozen mechanism. That is so damn clever! Thanks for sharing!! If you don't feel like removing the fender, there is a cutout near the battery that has a small wrapped wire pair coming out of the main harness and running back to the power antenna. THose are the wires that you would need to cut and splice in a switch. Link to comment Share on other sites More sharing options...
lint Posted February 2, 2011 Share Posted February 2, 2011 If you don't feel like removing the fender, there is a cutout near the battery that has a small wrapped wire pair coming out of the main harness and running back to the power antenna. THose are the wires that you would need to cut and splice in a switch. Stop it! stop the cleverness - you're killing me here!!!!!!! Link to comment Share on other sites More sharing options...
nunya Posted February 2, 2011 Share Posted February 2, 2011 Let him sit in my yard all day, my 1 acessable vechile I didn't drive Link to comment Share on other sites More sharing options...
Precise1 Posted February 2, 2011 Share Posted February 2, 2011 Didn't hit redline today. B Link to comment Share on other sites More sharing options...
ahardb0dy Posted February 2, 2011 Share Posted February 2, 2011 finished installing head unit and EQ and wiring it, I started a thread in the picture section. Link to comment Share on other sites More sharing options...
adamzan Posted February 4, 2011 Share Posted February 4, 2011 Bought an air filter but the laziness took over so I threw it on the back seat. Link to comment Share on other sites More sharing options...
Precise1 Posted February 4, 2011 Share Posted February 4, 2011 Is that your new cabin filter Adam?? B Link to comment Share on other sites More sharing options...
adamzan Posted February 4, 2011 Share Posted February 4, 2011 Link to comment Share on other sites More sharing options...
nunya Posted February 5, 2011 Share Posted February 5, 2011 Bought an air filter but the laziness took over so I threw it on the back seat. good going nunya... Link to comment Share on other sites More sharing options...
crazyhayseed Posted February 5, 2011 Share Posted February 5, 2011 I called Energy Suspension about my mis-shipped bushings. The retailer blames ES; ES blames the retailer. I'm in the middle. They conceded to send me my swaybar kit straight from the factory though, so I'm happy. So happy in fact, that I'm not going to push the fact that it really was Energy Suspension's fault. They put the wrong part in the box. Double plus - Now I have a spare set of compression rod bushings! Yay! Link to comment Share on other sites More sharing options...
Towncivilian Posted February 5, 2011 Share Posted February 5, 2011 New spark plugs @ 120,997 miles. No idea if they were changed before, but the old ones looked serviceable and would prolly last another 50k miles. Oh well! Threadlocker on power valve screws, engine coolant, rear differential fluid, and some small rust spots left to do... Link to comment Share on other sites More sharing options...
flyinwall Posted February 5, 2011 Share Posted February 5, 2011 wasn't today but a couple of days ago i installed my UHF today was spent making some custom mounts for the missus's surf as she wanted a fan put in there so the kids get some breeze in the back with the windows up so we got a small fan from supercheap auto and i made a mount that fits under the interia light and it holds the fan and i ran the wires up front to the rear vision mirror and installed the switch on another custom mount that bolts up under the mirror mount and hooked the wires up to the accessory and its good to go (the kids were in the car checking out the fan and the 4yo daughter (with here long hair) puts her head up behind the fan and gets her hair sucked into the fan and caught around the shaft and it pulled the hair out of her head Link to comment Share on other sites More sharing options...
