crazyhayseed Posted February 5, 2011 Share Posted February 5, 2011 Yikes! Link to comment Share on other sites More sharing options...
vagabond Posted February 6, 2011 Share Posted February 6, 2011 Well last week the OL smoked the clutch in the 94, I knew it was going to have to be replaced but I was hoping for another month or so. Anyway I had already ordered a clutch kit from Rock auto and it was sitting waiting to be installed, luckly I have a friend who is in the used car business and he called a shop that he uses. Labor $200.00 turn the flywheel $50.00. Picked it up yesterday with a new main seal pilot bushing disc PP and TO bearing 185.000 miles and the old parts were factory just hoping they were original one happy camper Link to comment Share on other sites More sharing options...
Daves94XE Posted February 7, 2011 Share Posted February 7, 2011 Installed my awesome pull-a-part find of rear disk axles (axles backing plates everything for 100 bux) wired my headlights through a relay and hooked up my cb. The rear disk conversion and headlight relay are the best 2 mods you can do. you don't realize how bad rear drums suck till you get properly working rear disk lol Link to comment Share on other sites More sharing options...
teixeira Posted February 7, 2011 Share Posted February 7, 2011 I replaced my rear hatch glass weatherstrip for a new one. 1 Link to comment Share on other sites More sharing options...
Towncivilian Posted February 7, 2011 Share Posted February 7, 2011 (edited) Fixed all the tiny rust spots I could find. Hooray Florida, nothing gigantic. Also pried off my old rusty towing ball (I can't find the key for the receiver's lock ) to replace after I either find the key or somehow remove the lock on the receiver. Also cleaned some dirt/dust out of the engine bay with compressed air and a wet rag. Gonna try to call 1-800-NISSAN1 tomorrow to ask about seat belts barely or not at all retracting without being manually fed back, since my local dealer said "nope gotta try cleaning for $90 first". Edited February 7, 2011 by Towncivilian Link to comment Share on other sites More sharing options...
SilverPath Posted February 7, 2011 Share Posted February 7, 2011 Finally started it up, thanks to the optima battery there was no delay. Drove it around the block to get its once a month leg stretching and parked it back in the back yard. Link to comment Share on other sites More sharing options...
Kingman Posted February 7, 2011 Share Posted February 7, 2011 I kicked it. Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted February 7, 2011 Share Posted February 7, 2011 (edited) I took apart my power antenna to figure out why it wasn't working. While in the fender, I installed a cut-off switch between the antenna motor timer and the motor itself so I can leave the antenna up or down in the winter rather than fight with the ice and frozen mechanism. Wow! Great idea! I have an issue with the power antenna being in the up position when listening to the iPod (connected to the radio). It would easily break off in a wheeling situation. Is the switch inside the cab or under the hood? Got a pics of the install? Also, would it be possible to do this at the radio end, can you put a switch at the ant. wire lead from the radio? Not sure? Edited February 7, 2011 by OfftourRoadie96 Link to comment Share on other sites More sharing options...
Qx4donald Posted February 8, 2011 Share Posted February 8, 2011 My Warn manual hubs came in today! weekend warrior status is in the works! here's to 2-3mpg savings and I hope I don't get the dreaded 4wd blinking light after install. Link to comment Share on other sites More sharing options...
fusion Posted February 8, 2011 Share Posted February 8, 2011 Oil/Filter change.... check. cleaned MAF.... check. aim head and fog lights.... fail. (the adjustment screws did nothing... Link to comment Share on other sites More sharing options...
87pathy Posted February 8, 2011 Share Posted February 8, 2011 got randies Ring and pinion to upgrade my D44 alloy shafts to the new hardcore shafts. FREEEEEEE of charge.. those guys rock. Link to comment Share on other sites More sharing options...
180sx Posted February 9, 2011 Share Posted February 9, 2011 Reverted from my 15x10's back to my stock 15x7 SE wheels. Put some Brigestone Dueler AT's on them in the 265/75R15 variety. Not new, but better than the steel belts my 31's were showing. Waiting on taxes to get my OME setup and get some genuine 32's for the 10 wides. yay me! Also changed oil, clean filter, straightened fins in radiator, removed bent fog lights, and found a blown GR-2 strut. Link to comment Share on other sites More sharing options...
Daves94XE Posted February 9, 2011 Share Posted February 9, 2011 recovered my dome light overhead panels with marine grade light grey vinyl! Link to comment Share on other sites More sharing options...
nismothunder Posted February 9, 2011 Share Posted February 9, 2011 Hit red line. B Was that in the three blocks you drove too work? I shut the door on mine all the way, was bugging me that I didnt notice for 3 months. Link to comment Share on other sites More sharing options...
Zibi Posted February 11, 2011 Share Posted February 11, 2011 Today I seafoamed it, oil change, cleaned the MAF, and changed the fuel filter. Great to get out and work with my hands again... Link to comment Share on other sites More sharing options...
zelix Posted February 11, 2011 Share Posted February 11, 2011 Today, i finally started mine up after being in the shop for 5 months.... yes i'm a 16 yr old noob. I was expecting catastrophic failure from the new starter and new clutch, because i changed these solo for the first time. but no! All went well! Link to comment Share on other sites More sharing options...
Kyle94 Posted February 11, 2011 Share Posted February 11, 2011 that is always good. i remember last june when we did MY trans swap. i was scared to start it... lol just me and a bud did that one in a couple weekends. today i folded up the rear seat bottoms and folded the back of the seats down to( for the first time ever) utilize my cargo space... (one measy chair) Link to comment Share on other sites More sharing options...
NavyP503 Posted February 11, 2011 Share Posted February 11, 2011 I finally got a lot done today! Gotta love junkyard runs. FR window switch, Rear glass switch, door jamb switch, A/C idler pulley assembly, rear dome light, hatch latch, some misc. plastic parts, front door stops, New clutch master cylinder and lower hose. Only thing that keeps me from going for a ride is I need to get a new idler pulley tensioner bolt, the one I had turned out to be broken. Link to comment Share on other sites More sharing options...
Kingman Posted February 11, 2011 Share Posted February 11, 2011 I took the Z31 ECU out and took it apart. Inside I found a burned out resistor which would explain why it runs like a bag of ass. Got a new computer coming which should fix the problem. Then I'm going to repair the original one and keep it as a spare. Finally made some headway with the stupid thing. Link to comment Share on other sites More sharing options...
87pathy Posted February 11, 2011 Share Posted February 11, 2011 Hit red line. B which one. I have recently discoverd that a first gen pahtyfinder with a 3.0 TBI, will run at 8K rpms without blowing up... Link to comment Share on other sites More sharing options...
Pezzy Posted February 11, 2011 Share Posted February 11, 2011 Drove the frozen salty beast to work. Link to comment Share on other sites More sharing options...
Kingman Posted February 11, 2011 Share Posted February 11, 2011 which one. I have recently discoverd that a first gen pahtyfinder with a 3.0 TBI, will run at 8K rpms without blowing up... VG510 guys run 7-8K all day on the track and the engines love it. Link to comment Share on other sites More sharing options...
beastpath Posted February 11, 2011 Share Posted February 11, 2011 installed my 99 pathfinder console - muhahaha cupholders! Link to comment Share on other sites More sharing options...
DavefromOZ Posted February 12, 2011 Share Posted February 12, 2011 I drove mine to work,same as I do every day. Might finally install my new aerial this arvo if time allows, it is currently sitting on top of my dash plugged in. Also will check fluid levels. Link to comment Share on other sites More sharing options...
teixeira Posted February 12, 2011 Share Posted February 12, 2011 installed my 99 pathfinder console - muhahaha cupholders! Nice, I would like to see that. Link to comment Share on other sites More sharing options...
