ORCGuide Posted December 7, 2012 Share Posted December 7, 2012 Changed the Power steering and alternator belts. Figured out which one was squealing and why. . . tensioner bolt on the alternator was broken. . . Link to comment Share on other sites More sharing options...
BBB Posted December 9, 2012 Share Posted December 9, 2012 Fixed a hole in the carpet. Before: I already removed the vinyl heelpad, which was cracked, and vacuumed the carpet. I took some carpet padding from under the back seat to stuff in the hole. Glue, lots of it. This stuff, good stuff After: Link to comment Share on other sites More sharing options...
Nefarious Posted December 10, 2012 Share Posted December 10, 2012 hell, that doesn't look too bad there for a diy carpet patch! might have to do that to mine....got a similar hole there albeit not quite so big... on a side not, got my gfs pathfinder purring like a kitten today! finally fixed all running issues it had....400$ MINT rust free pathfinder is now a go!! just need to unstick the e brake cable on it now since it was sitting for like 2 years with the e brake up....hoping i dont need to pull off the rear rotors to unstick the inside...brakes don't seem to be sticking i think the cable itself is just stuck a bit... e brake pulls itself about 2 loose clicks up on its own. gunna try to wd40 the hell out of the cable and let it sit for a while. almost ready for emissions inspection and then we will have 2 pathys to rip around in!! stoked! Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 10, 2012 Share Posted December 10, 2012 Threw a new fire extinguisher in the back... never know when that might come in handy. Link to comment Share on other sites More sharing options...
k9sar Posted December 10, 2012 Share Posted December 10, 2012 I ripped it's f***ing heads off Link to comment Share on other sites More sharing options...
andreus009 Posted December 10, 2012 Share Posted December 10, 2012 Made the clutch go bang! Link to comment Share on other sites More sharing options...
Darek Posted December 10, 2012 Share Posted December 10, 2012 Greased drive shaft and replaced factory instrument cluster bulbs with 3xSMD LEDs. Now it is much brighter. Link to comment Share on other sites More sharing options...
ORCGuide Posted December 11, 2012 Share Posted December 11, 2012 Ordered a new coil and power transistor (aka ignition control module). Got my nipples crossed that the code 21 and (poopy) performance on the highway will be a thing of the past. Feels like a fuel starvation issue but OBD1 insists its an ignition issue. . . Link to comment Share on other sites More sharing options...
WxChaser Posted December 11, 2012 Share Posted December 11, 2012 Replaced the cruise control switch.. second switch on the dash to break on me. But at least I'm able to relax while on long hauls! Planned: Replace Driver headlight, Clean MAF, seal air leak in intake, find skidplate to replace the one I lost playing in the snow, and pressure wash the engine bay. Once I get the brush guard, I'll add that and some floods. Link to comment Share on other sites More sharing options...
JamesRich Posted December 11, 2012 Share Posted December 11, 2012 After beating the hell out of it in the woods for a week and a half I gave it some much needed rest. It has been sitting for the last week, but back to work today! James Link to comment Share on other sites More sharing options...
ORCGuide Posted December 11, 2012 Share Posted December 11, 2012 Swapped in a new Intermotor coil and BDW Ignition Control Module. Hasn't thrown a 21 since and runs much better on the highway. Now to see if the problem is solved when the temperature drops tonight. . . Link to comment Share on other sites More sharing options...
bearindabush Posted December 19, 2012 Share Posted December 19, 2012 Started the transmission revoval Link to comment Share on other sites More sharing options...
Nefarious Posted December 19, 2012 Share Posted December 19, 2012 installed the taller rear springs (about 3.5 inches of suspension lift in the rear) finished swapping in my new axle (LSD, disc brakes), fabricated some drop down brackets for my e-brake cable so it's sitting in the middle of its travel again and won't snap like the last one when i flex out. tomorrow is fixing my drivers side exhaust header and taking the headers in to be planed for trueness on the mating surfaces, then weld in the new magnaflow hi-flow catalytic converter and finish welding up and painting the exhaust. Link to comment Share on other sites More sharing options...
JamesRich Posted December 19, 2012 Share Posted December 19, 2012 Washed it! Took all day! The down side playing in the mud, the clean up! Had to get it up so I could get underneath with the pressure washer. There was a 1 inch thick layer of mud inside each wheel. I even had to spray the mud out of the brake rotor fins! I don't have any clean pics because it was dark by the time I finished. James 2 Link to comment Share on other sites More sharing options...
k9sar Posted December 19, 2012 Share Posted December 19, 2012 You did it all wrong. When mine was that muddy, I just wait for the next good rain and look for the puddles... that or drive into the creek. 1 Link to comment Share on other sites More sharing options...
Nefarious Posted December 20, 2012 Share Posted December 20, 2012 Put throttle body back together and intake runner, vac lines and plugs....then i heated and bent a warp in my headers. They are all ready to be machined true, then just some exhaust and frame welding and the pathy is back on the road! So stoked for all the snow. Link to comment Share on other sites More sharing options...
nunya Posted December 20, 2012 Share Posted December 20, 2012 Hosed the frame out today (not 1 clogged drain and instantly clear water ) and pulled te reverse light switch and cleaned er up good. Was starting (ok had and ive been ignoring) to get an intermittent flicker issue with them. See if this helps (used to breath new life into them on some HBs of the past...) Might check my codes tomorrow... Just because Link to comment Share on other sites More sharing options...
k9sar Posted December 20, 2012 Share Posted December 20, 2012 finished putting the engine back together then drained the water out of my headlights. Link to comment Share on other sites More sharing options...
SilverPath Posted December 20, 2012 Share Posted December 20, 2012 Charged the battery. Haven't driven it in a few months Link to comment Share on other sites More sharing options...
k9sar Posted December 20, 2012 Share Posted December 20, 2012 left it in the driveway while I taunted it by driving a borrowed minivan in plain view of the pathy Link to comment Share on other sites More sharing options...
sroeser01 Posted December 22, 2012 Share Posted December 22, 2012 took it out in the mud!! then washed the old girl and installed the tail light gaurds Link to comment Share on other sites More sharing options...
Leo94 Posted December 22, 2012 Share Posted December 22, 2012 Cut rust out from the rocker panel and battery tray and got it welded. Link to comment Share on other sites More sharing options...
theexbrit Posted December 23, 2012 Share Posted December 23, 2012 Fitted HID headlights, LED dome lights & a new tire carrier warning switch. Link to comment Share on other sites More sharing options...
Trogdor636 Posted December 23, 2012 Share Posted December 23, 2012 (edited) left it in the driveway while I taunted it by driving a borrowed minivan in plain view of the pathy Its hard to taunt anything in a minivan. Replaced 6 ball joints and 2 CV axles over he last 2 Saturdays. I'm starting to hate Rockauto due to broken/mislabeled/wrong parts. Edited December 23, 2012 by Trogdor636 Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 1, 2013 Share Posted January 1, 2013 Topped up the brake fluid, thought about flushing it, and fixed my leaky washer fluid reservoir with some rubber cement on the rubber fittings. Link to comment Share on other sites More sharing options...
