alexrex20
Everything posted by alexrex20
  1. i hope you're planning on a lift if you're getting 275/75 tires
  2. remove the fill plug, stick your finger in there and check the fluid. if it looks like chocolate milk, there's water.
  3. on my R50 i ran the wires for my four roof lights behind the weather stripping for the front driver's door. i just pulled back the seal, routed the wires behind it and replaced the seal. no drilling and no ugly wires. my wires all go to the engine bay. power comes from the battery, but switched power is from the driving lights and the interior switch is wired through the firewall.
  4. the front shafts can't bind/pop if the tcase is not sending power to the front axle.
  5. your boots are torn, and it makes loud popping noises when you turn in 4WD. it IS your CV axle.
  6. did you verify that BOTH front wheels weren't spinning, or did you only look at one of them? if your boot is torn and your front end is popping and clunking in 4WD, then yes it's your CV.
  7. hehehe. if only i didn't have my heart set (for now) on the ARB rear and Lokka front lockers... i got my Bilstein 7100s today. WHOOT (too bad they're not a simple bolt-on for me!)
  8. only when i see your name in the thread.
  9. i'm glad you're here to point that out. otherwise i'd have missed it.
  10. how you got so bent out of shape is also beyond me
  11. that's not what you said last time, on the 1st batch of pre-orders.
  12. hopefully you will get enough pre-orders this time steve. i'm trying to hold off on the HD links so i can get my ARB locker.
  13. and? i never said it wasn't a waste of money. i said it was a simple concept that should be simple to understand. but i guess it's not.
  14. ya, my rear diff breather goes all the way into the frame/body above it, pretty high up. i wouldn't worry about water that deep unless the breather hose is missing.
  15. ium ya? we already decided it only works on TBI, not PFI. that's why it is/was such a common and effective mod on the TBI sbc350. add a spacer and supplement with injectors from a police pkg caprice.
  16. the spacer goes under the throttle body. it's simple, really.
  17. i have the same wheels and yes they fit. the stock center cap will even fit over the hub.
  18. you're welcome. it's rather unnerving when you finally pop it out, right?
