vagabond
Everything posted by vagabond
  1. The wheel and shaft should be marked, and if you do not have a puller for the wheel you can loosen the the nut and pull on the wheel it will usually come off that way, make sure you leave the nut on while pulling on the wheel otherwise you might end up with a fat lip or worse and no thats not the voice of experience talking
  2. I think there is a writeup on the starter removal, I know that's the way I pull them
  3. went to unlock her this morning and the damm plastic clip broke on the drivers door the one that connects the door lock to the latch went to unlock the pass side and remembered it broke about a month ago. Ok went to the rear hatch and the damm thing wouldn't open, but the hatch window did. climbed in through the window removed the panel and broke it ah s$%t, got the hatch to open and started loading all the crap in it from our 4 day weekend in the desert, got her home and the hatch opens with no problems, what the hell I screwed with it for 15 minutes before climbing through the window. We put 500 miles on her this trip and she ran great. Now for the clean up, brush marks down both sides, but I think they'll rub out I think I brought half the desert home in her, oh well it was fun :dance:
  4. Adjusted the fast idle on the 88, and changed oil and filter on it all ready for the trip this weekend going out to the desert and doing a little 4wheeling :wiggle:
  5. :Dshouldn't they be on the front. I know they';re hard to come by I'm looking for a rear and a front
  6. Both of mine are high enough I can just slide under and remove the rod without removing the wheels
  7. +1 I'm looking for a wrecked R50 local to do a major swap with my 88, engine, 5speed, & transfer, dash all electrical, and whatever interior parts I can swap out. I've been wanting to swap the auto for a 5speed for a long time and I figured it wouldn't cost that much more if I picked up a complete pathfinder, so far everything is either 2wd or very high mileage
  8. hope this works My linkphotobucket\ Pic #3 shows the valve the vacuum line goes to the other end of the valve has another hose that goes to the air cleaner
  9. said to hell with it and tie wrapped the sections of mast in the up position, yeah I know ghetto :rofl:
  10. it's the cover that goes over the metal dash frame, or it can be an aftermarket piece to cover the top of the dash which are usually glued on
  11. we installed the Warh hubs this morning, passenger side took about 1/2 hour, drivers side about 2 hrs I couldn't get the bolts to break loose and ended up cutting the heads off the bolts then prying the auto hub off then what was left of the bolts screwed out with no problem, oh well its all done and I feel better with the Warn hubs on the 88
  12. Got my Warn hubs today and if it doesn't rain tomorrow they'll be on the 88, even opened up the lego caps
  13. On the 88 I used the 30/40 bosch relays from o'reilly for mine, and then went ghetto with my electric rad fan used a clutch inhibitor relay, only have the low speed on the taurus fan wired in but it seems to cool enough with the A/C. We made a Laughlin run last weekend from Elsinore and running the A/C most the way, never saw the gauge go over half way
  14. Great writeup, it should help out a lot of people maybe it should be pinned, +1 on the heavy duty wiring it makes a hell of a difference in the brightness
  15. installed a Nissan trailer hitch on the 88, another jy pick up
  16. ok I'm in Elsinore I'll be in SD thursday if you still haven't got it straightened out we might be able to drop by on our way back home and give a hand
  17. Not sure but I've always called it burgundy
  18. I'm sitting here with a relay and plugs in my hand, the 2 wires you want to jump are the black with a yellow stripe and the black with a pink strip, the pink may be faded and look white. They will be the heavier gauge wires, also they will be in the larger plug edit to add the relay your jumping is the wrong relay you want the other one, it has 4 wires and 2 plugs. It's in the pic you posted
  19. A couple more pics http://img.geocaching.com/cache/large/ecb592ee-a952-407f-9861-fed1a74107e5.jpg[/img] hope they help, just changed my pump a couple of weeks ago
