adamzan
Moderator
Everything posted by adamzan
  1. Looks like you've got an oil leak to fix while that motors out. That's all I have to add here.
  2. LSD is useless with one tire in the air.
  3. If you look in the service manual (available for free links in the garage section here) it will tell you the proper pressure for the ambient temperature of where you are. Under the hood it will say how many lbs of refrigerant it takes. But this is NOT the pressure.
  4. I would replace the radiator. I know you said the other truck ran cool but @!*% happens. Also have you checked the water pump?
  5. I know the percentage that it is off. So I just add that to the mileage on the odometer.
  6. I don't know about where nefarious lives, but here they've banned any weed killer that actually works.
  7. You're right, because when you shift too low, you are making the engine struggle and the ecu will just dump in more fuel. I got 19mpg in mine last tank, and I have 33s. I thought it was a fluke too, but I have been doing the same driving style and I am seeing an increase on the kms per tank so far according to the trip meter.
  8. Drill the arms and add your own zerks. For the idler arm bushings this guy makes replacements: http://bandit4x4.com/4x4-truck-parts/steering-parts/idler-arm-bushing-replacements/
  9. If you look around there is another full size truck that uses the same shock as a lifted pathy, I forget what it was. But it's pretty cheap and has the right bushing on both ends. If you're lazy like me Edit: I used the Rancho RS5112. So anything with the same specs length wise as that will work.
  10. Don't buy the cardone new CV shafts!! They suck! I bought a set for my wd21 (who cares, they're almost the same) and I got an awful vibration that felt like my driveshaft was bent up front. Turns out those cvs are junk for anything but a stock height truck.
  11. This happened on my parents 3.5L. It had 160k km (around there). It was real loud. My dad has a '11 xterra with the 4.0 and I've told him to lookout because his is still under warranty.
  12. If its loud all the time, its bad. But if its only when the trucks real warm, and the a/c is on, its probably fine.
  13. Just go get one of those transfer pumps. Or if you can, attach a long piece of hose to the bottle so you can hold it upside down. Driving to town probably won't hurt the tcase. Its probably been dark for years. Mine was black almost!
  14. My friend has a 70's skidoo citation. Pretty cool.
  15. How is this still being argued? It's a 4 speed automatic, including overdrive. That .5 you're feeling is the torque converter locking. Ever notice how the rpms can fluctuate any other time? When the torque converter locks they stay steady. You can drive as fast as you want in 3rd, and it won't hurt anything. You shouldn't use overdrive if you tow, anyway. If you leave the O/D switch off, and drive faster than a certain speed (it's around 85-90km/h for me) it will lock the torque converter without the overdrive on.
  16. If it sounds like this, it won't go away. If its just a subtle noise it probably will.
  17. If all your vents are still intact, you should have no problems. I do that all the time.
  18. Yep ^. The fluid looked clean on the xterra tranny I bought, they told me it had 140,000km. When I pulled the pan I found the factory nissan filter in there, absolutely nothing on the magnet either! FWIW this is the third transmission put into my truck. The previous owner changed it with a used pathy one and it lasted about 70k km...
  19. To be honest I haven't replaced any, but that is because I haven't really wheeled it much and the stock ones are fine for now. I will at some point though.
  20. Yes, you can pull off the trim in the back and there are some linkage rods that control the lock. Find the one by the lock actuator and see if it will pop open. Does your key not work in the rear lock? It does more than just open the glass.
  21. Why do you need to change all the flex hoses? The rear flex lines for disc don't move at all. I have the same lift and have no issues, been that way for years. If anything the only line you should touch is the one that goes from the cross member to the T on the axle.
  22. Both. I learned all the Cisco IOS stuff, and near the end there was a strong focus on security. There was also a lot of Linux and scripting. I am half tempted to go take some night courses on web stuff, or programming. But I need to find a job first.
