221
Everything posted by adamzan
hopefully that isn't the problem......
Also rewiring is good if you ever wanted to sell it, you can just throw the stock crap back in. My HU is running through the stock amps into my infinity's and they sound pretty darn good. Although, I get a lot of hissing, but i think its the panasonic deck the PO had installed. Yeah, make sure you keep that liner on the door.
The ones around here are nice to you until they see how old you are on your drivers license......
pics, as promised drivers side: passenger side, don't know why its so fugly like that. Just got the truck.
Yeah when you have the bottom off, push up from the bottom, it should pop off, just be careful. oh and make sure you took off the door lock thing you push on to lock the door, near the window. It unscrews.
sorry i've been busy with school, i keep just getting out of the truck and going into class and forget to take the pic, ill make sure and get it tomorrow. But i did check and there ARE air vents under the front seats!
The one time I heard of this happening, it turned out that the crank pulley (the big one all the belts are attached to) had worn or somehow got messed and it was kinda wobbling, which in turn would tear the belts, but not before they would squeal like old hell. I *think* (not sure on the wd21's, as this happened on an r50) there is a rubber bushing inside the harmonic balancer i think its called, well anyways i think that can deteriorate over time. Maybe there are some nics in the pulleys from people using screwdrivers to pry on belts..... Someone correct me if im wrong, but my shop teacher told me a long time ago, that you can use a strait edge to see if all the pulleys line up, and if they don't, start there. Edit: msavides i didn't see your post but you could be right, as that happened on my 95, makes a lot of noise before it seizes though.
I've read on here that if the timing belt jumps one tooth, that it will have serious power issues, and will have trouble gaining speed up hills and keeping it on the highway. I KNOW if it jumps 3 or more teeth will cause the pistons to hit the valves. The timing belt interval for an 88 is 60k miles, so.....its wayyy over due if it hasn't been done.
ill take some pics of my 95 today while im out and about. I won't bother with the 93 since i dont' feel like digging it out of the snow.
both my 95 and 93 have the vents under the seats....... oh ya the 95 is an xe and the 93 is an se if that matters
not to mention the slushy mess for us up north
If the alt goes, i think you get the AT oil temp, battery and brake lights. All that red is sure to catch your attention!
I had that happen to me on prom night in the r50 even though its stock. When i went into the VIP parking area, the sign slapped against the roof rack, and attracted attention from a bunch of people The truck cleared the roof of the place by like an inch haha If it was at a mall parking garage i'd just go in and park on the highest level which is usually not covered. Thats how it is at a few malls here, as the height guide is before you even hit the ramp. So, if you just keep going around, you'll get to the top and have a crap load of spots to choose from cause nobody parks up there!
sounds like the valve ticking noise that a lot of these trucks have on cold starts. IIRC
Yeah I've been wondering how i'd be able to go into parking garages and malls and stuff if lifted it.
yup. if you want to do body lifts, big tires, sas, a wd21 is great. r50's, although sometimes catch a lot of flack, have proven themselves to be just as good with the right mods. Just look at pezzys in the members rides section. A couple good examples of built wd21s are simons, mookies, and 87pathy's. There are lots there. It all depends on what you want to do with it. Oh yeah, if you want more hp go for the 2001, as they have a 250 3.5 v6 and the 99's only had a 170hp 3.3 good luck!
Does it do it all the time or only when its warm or cold? Do what casey says down below, mine turned out to be all 3 drive belts needing replacing.
Dude be careful when driving it, as i can see you have holes near the upper link cross member. On my 93, when my dad had it, the memeber slowly worked itself loose until it fell off on one side. Just don't do any burn outs and avoid pot holes, that is, until its fixed.
Nope and it would make those cold starts much easier lol. Although we do have a motomaster deep cycle battery.... My wd21 seems to handle the canadian winter starts with ease.
When mine pulled right when braking and was starting to lose fluid, it turned out to be the rear drivers side wheel cylinder. Are you discs or drums in the rear?
would you mind filling us in on where it is? my dad wants to know.
maybe this will help you....
If you pull the radio and audip amp fuses you shouild be good. I think.
I wonder if you can adjust the back ones so they go down all the way instead of stopping at the safety point. I don't have kids and would like my back windows to go down all the way!
ok i think he means like THIS
