221
Everything posted by adamzan
But i don't think it hurts to do it at a later time other than more drag so worse gas mileage.
Good for procrastinators like me *puts tbelt on top of to do ASAP list*
Yep, the wd21 motors will last a loooong time. When I went to the dealer ship with my dad so they could fix some things on the r50 when we bought, we were telling the mechanic there that we also have a 94 path and he said, well fix that frame because as long as the timing belt doesn't snap and she doesn't rust apart that it'll go up to 800,000km's easy, as he said he's seen them come in for oil changes, and other routine maintenance. A lot of d21 pickups around here are used as work trucks, and when i worked at the gas station, the guys who drive them said they've been to hell and back and that the truck will probably out last them I also see a lot of pathfinders used as work trucks for landscaping companies as well.
I've heard of a mechanics trick is to put iodine into where the plug is and let it sit and the iodine will penetrate and prevent stuff like that from happening. What I should've done when i changed the plugs on my grandmas car.
Don't even think about it, the monroe shocks are horrible, i have them in the front of my truck and they're a year old at the most. The front end is pretty bouncy and nothing is loose or broken underneath. They're just a cheap fix for a few months, don't expect much life out of them. I think there others around here that will agree with me oh ya, all of my driving is on road, so the shocks don't see any full flex or botteming out. These are monroe Sensa-tracs
I'm pretty sure its my exhaust as mines more related to engine rpm's around 3k is raspy and rumbly. *goes out to check other pathy*
Yeah these engines feel a little raspy around 3k rpm i've only ever had mine up to 5k rpm and that was an accident when i was trying to pass some moron and i floored it. its quiet at 5k rpm though
95 V6 poor heat, makes for whiny kids!
adamzan replied to tmoore4512's topic in 90-95 WD21 Pathfinders
Mine goes 1/4 of the way up in city driving but these days it hardly goes over the cold bar on the highway, for obvious reasons. I've heard they give you some leeway on the tbelt by a couple thousand miles, but i wouldn't push it, doing mine this spring. -
im getting anywhere in between 15-20 mpg right now, as when it snows, the mileage goes out the window, because of the idiots on the highway who can't pick a constant speed in bad weather i don't care if its 50kmh or 100kmh just keep it the same. also if you idle a lot at traffic lights, it eats up ALOT of gas. Also, i find that if i start it up let it run for a minute and jump on the highway, the mileage will suck but if i take a non 400 series highway for a bit then jump on to one it gets way better mpg. I think this is because it won't go into the final overdrive stage until its warmed up, i don't know if its normal or not but thats how it is on mine.
What did you guys end up doing with that piece of fine machinery?
pathy swaying at freeway speeds
adamzan replied to nissandoms47's topic in R50 FAQ's & Pinned Topics
i would take it to your usual mechanic, except if its the pep boys. Talk to your friends and see if they know someone good in the area. I would assume a pep boys is like canadian tire auto service up here ??? Dealer is usually more expensive but from my experience they usually do pretty good work. -
I get the same crap from my friends around here, but I usually don't listen to them, because while I drive 90km a day to and from school w/o any problems, they're always having to repair their gmc sierra, or jimmy, or dodge or ford 4x4. My friend has 193k on his 90 gmc sierra (absolutely no rust though ) and he's put more money into it than what i paid to buy and safety my pathy, and he bought it with 170k a year and a half ago. Also the tires make a big difference in the snow, I currently had Goodyear wrangler radials in the front which aren't bad, but in the rear they threw on some roughrider radial AP to pass the inspection. I slide around all the time in 2wd. I still wouldn't trade my pathy's for any american product. ever.
We have a 2000, and I'd assume its an XE unless someone took all the chilkoot markings off. Its a 5 speed manual with the floor shifter. Also has an LSD and the alarm system, tinted windows from factory, the SE wheels (like pezzy's stockers) and the towing package. I think it all depends on what the original owner ordered from nissan. I've never seen another like ours.
Its what Canadian tire up here pushes as their in house brand kinda thing and the guy who had it before me said it was a quick fix b/c the originals were blown. And simon if you read this, i know what the difference between a shock and strut is. -
I agree there, i have the sensatrac shocks on the front of my wd21, and they maybe have 30,000 miles on them and are about a year old and they're already mushy. Edit: oh and I don't wheel my truck, strictly on road daily driving to and from school on the highway. -
But couldn't that also clean out gunk that's holding back leaky seals? Although i'd rather find out i need seals.
sorry to hear about the funeral
I have the same problem and its my exhaust. I know its loose but I haven't had time to find out where yet, but yeah when you hit bumps of certain degree, or when the engine is at a certain idle speed, it does it, well at least for me. I did find a piece of card board stuck between the second cat and the cross member though, probably someones idea of a fix
Handle like a jeep? I'm never sas'ing my pathy. The IFS is just fine for what I do.
Mine does it too and i found out a part of my exhaust is loose, i haven't looked into it much other than that though. Although someone put a piece of cardboard between the cat or whatever and the cross member so it wouldn't rattle i guess
Basically you remove the IFS from the truck and install a solid axle, like what many jeeps have, so you can get more lift and flex, and therefore, traverse greater obstacles.
Here's some more on that issue.
Theres a station around here that does that. Last time we filled up the pathy there, we thought the timing jumped 3 teeth. You wouldn't think you were driving the same truck after we dumped a sh!tload of water remover and premium fuel in.
Basically The gay-ification of the pathy *starts collecting wd21's*
I already voted my other truck but my new one will probably turn to 225,000kms in the next few days. Still runs strong and handles like new. Some rust patches starting on the body though.
