adamzan
Moderator
Everything posted by adamzan
  1. Yeah they're on the steering wheel, I've tryed pushing hard on them but nothing happens. And the plugs, well one of the wires is yellow as you can see in the pic. But I have an XE and theres no switch for fogs, also The place where the fogs would go looks like this [---] instead of having a hole there. Another wierd thing, my DRL are my highbeams, and when i turn the headlights on they go to low beams and i can select them again.
  2. Better than a gmc jimmy/blazer like my grandpas neighbour had, it was a 96 and he had the motor replaced 3 times for the drivers power window because he tapped the button and poof there goes the motor because it was a little cold out. He sold it a couple weeks ago and bought a 2008 pathfinder
  3. couldn't be foglights, those are too high up, they're sitting on top of the rad and aren't very long What did the morons do to this poor pathy.
  4. Ok I figured out that the wire in the back there was for my brake light. Wow, I didn't know it wasn't working untill that cop told me the other day. Thats all fixed up. Now I want to figure out why my cruise isn't working, I checked the vacuum like and it looks ok, the light on the button comes on but it just won't set. I also checked the brake switch and its fine too. Is there a relay or fuse for the cruise? Next step im going to swap modules. I also checked the connections they were tight. I snapped a pic of the area, do you see anything out of the norm? Also What are those 2 connectors in front of the radiator and behind the grille in the second pic?
  5. don't be so hard on your truck then I try my hardest to not let it shift over 3k rpm. You'll get better mileage too.
  6. Yeah I don't have a job either, and its hard to work and go to school at the same time. Just make sure you support the truck well, that'd really suck if it came down on you.
  7. I know how it feels to have no cash, Im going to algonquin college in ottawa and for the first semester i had no pathy so i had to suck it up and drive a car Maybe a friend would have some?
  8. I'd offer them 500 dollars for it, I got my 95 for 400 dollars and it needed 1500 worth of work to safety but she sure runs great.
  9. Jackstands aren't that expensive dude, unless money is real tight. And you'll be glad you bought them too. I see you live in BC, go check out canadian tire, they usually have them. Good luck though heres a good deal: Motomaster 3-Ton Jack KitSale: $79.99 Reg: $119.99 Product #09-1055-6 3-ton jack kit is made of high-strength steel Includes one 3-ton heavy-duty service jack and one pair of 3-ton axle stands Maximum capacity of jack and axle stands: 3 tons/ 2721kg (6,000 lbs) each Dimensions: jack, 25 x 13-7/16 x 6-7/16" (63.5 x 35 x 17cm); axle stand, 8-3/16 x 7-1/8 x 11-3/16" (22 x 19 x 29cm) Weight: jack, 84 lbs. (38kg); axle stands, 14 lbs, 11 oz. (6.7kg) Assembly required Instock at kamloops crappy tire.
  10. adamzan
    Broken...
    Check the battery cables, the positive one can corrode and break. IIRC
  11. I honestly think that the rears get less power than the fronts on mine, as the panasonic deck is wired through the factory amps and i have infinity 5x7's all the way around and the fronts sound SO much better while the rears distort earlier. The stock speakers that were in there were different in the front and back, the fronts had a higher wattage, but they were the factory speaker.
  12. Timing belt, cut out the rust under the rear seat and rivet in new steel and por15 it. Also check your frame at the rear wheels for rust, its really common to rot out in that area. You'll probably get bored of it long before it dies
  13. Just skimming through this and didn't see posted what I thought made removing the bottom screw A LOT easier. Unhook the maf and open the air filter box, you can use a regular screwdriver that way and get way better leverage. Feel free to me if this has already been posted.
  14. So I guess if I don't have to add any oil in between changes and it stays full the whole time I'm in good shape? Someone told me that its supposed to use a little oil, although I'd rather it not. Better peace of mind.
  15. I know that on my 93, its full of oil in there, thats was my dad preventing rust.
  16. Yeah the light on the cruise button comes on, the spedometer works, and my horn works fine. I checked the vaccum line under the hood and its fine, it doesn't even try to set. Is there a fuse for the cruise somewhere? @denisb, I checked and there isn't any rust under there, I've been told that the grommet that can be used for trailer wiring can fall out and cause that to happen. I guess i should probably clean it out in there.....
  17. I just switched my truck over to mobil 1 5w50 synthetic, yes, 5w50. And there is no puddle in my driveway or cloud of blue smoke when i start it and drive. I never have to add oil between changes either.
  18. I don't have the remote for the auto starter, and the PO told me that he found the antenna for it (the one thats usually on the winshield near the mirror) in the glovebox, the wire is still there though. It only caused issues when i unplugged the wires, so i turned the switch off and am leaving well enough alone. I was only under there because my cruise control isn't working. I wouldn't be surprised if someone did do a wiring job, as my rear wiper doesn't work ( you can hear the relay clicking though) and the hatch glass won't open at all, for one because the key in the hatch won't turn, and secondly the switch on the center console has been unhooked and i can't see the wires for it when i pulled the switch out of its socket. I'll definitly check for what could be letting the crapola in. Its an XE but it has the power windows, locks, abs, cruise control, a/c. The only thing that doesn't work is the rear wiper AND cruise control, but I couldn't find the fuse for the cruise . No I don't have a trailer plug or trailer hitch, and from when i was underneath before it doesn't look like it ever had one. (i'd have seen the marks on the frame). I think it might be the wires for the brake lights, but im probably wrong. The key only fought me in the lock when i unplugged the remote starter, so now that its working, im not going to play with it unless it has something to do with my cruise control which i doubt. definitly a job on this truck I'm going to look at that history sheet we got when the ownership was transfered.
  19. I'm dead serious, I know nothing of wiring, and have no clue how to decipher the diagrams I just need some people to tell me whats going on here. First of all what is this connector for, and that little wire hanging there, I assume it must be important. Also, why is it so sandy and corroded in there, I thought it was somewhat sealed Now on to the more serious one. What the hell is this? Plain and simple I know that box is for a remote starter, but when I unplug the cables to it, my locks don't work, and my cruise control doesn't work regardless of whether its plugged in or not. Like if i unplug it, and try to lock the door with the key, it will fight with me and not lock, it just pops back up, you can feel it in the key. Maybe some of you guys know whats going on down there I posted them all up anyway. Thank you for any assistance.
  20. It was -20 C today here and -30 with the windchill, the truck started up fine, do you get any lifter tack in this cold? I don't anymore with the synthetic. Oh good, so my tranny isn't effed, they all do it It was sure as hell cold inside though *wishes he still had heated seats* Wouldn't it be nice if you had a remote start, you leave the heat seat on when you go in for the night and when you started the truck the next morning with the remote, you come out to a nice toasty seat
  21. I use fluid film, its great stuff. I sanded down the frame of my old path and had to leave for a week and couldn't finish what i was doing so i gave it a coating, that was 6 months ago now and its still shiny, oil coated metal I also have been spraying it generously on my new one and the surface rust hasn't gotten any worse. Just make sure you give another coat after you go through the car wash
  22. My odometer stopped for like 10km then started working again Not like i really care anyways.
  23. And watch out they might try to make you pay even if your truck IS covered , like the dealer here
  24. I know that the passenger wheel was ripped off on my pathy when something failed with the previous owner, my shop just put a new axle shaft, brake setup/line and all that on and its fine now. It cost like 500 dollars canadian to have that fixed. Anything is fixable.......
