adamzan
Moderator
Everything posted by adamzan
  1. adamzan
    SAS
    Basically you remove the IFS from the truck and install a solid axle, like what many jeeps have, so you can get more lift and flex, and therefore, traverse greater obstacles.
  2. Theres a station around here that does that. Last time we filled up the pathy there, we thought the timing jumped 3 teeth. You wouldn't think you were driving the same truck after we dumped a sh!tload of water remover and premium fuel in.
  3. Basically The gay-ification of the pathy *starts collecting wd21's*
  4. I already voted my other truck but my new one will probably turn to 225,000kms in the next few days. Still runs strong and handles like new. Some rust patches starting on the body though.
  5. And to see how clogged they really are.
  6. Pull harder, after not using it on my truck for a long time, I had to use 2 hands and really reef on it to get it to move. Hope that works.
  7. Thats a great idea, thanks for the tip. I'm getting bored and itching to play with my welder. And I've got lots of materials, and a truck in need of frame repair. Oh, I know someone who learned this the hard way, I hope you covered up your brake flex hose so it didn't get damage by the welding spatter.
  8. At least your frames in one piece! Oh and one problem on my other truck when i was trying to weld my frame was trying to find a place to put that ground clamp
  9. I'm going to do my best to keep mine the way it is, although if it were to go in a few years, i can't complain, I only paid 400 dollars for the rig. I had the mechanic doing the safety inspection check all the known wd21 rust spots, and they fixed the drivers floor and one in behind the brake pedal. Also had them take a ball peen hammer to the frame, the whole rear section. Under the rear seats I'm going to cut it out and rivet in a plate of steel and seal it up.
  10. Simon is yours showing signs of rot already? On my new one its almost mint, just some surface rust, that I'm taking care of in the spring but im spraying oil in and around the frame weekly after I get it washed. He's lucky though, when my crossmember broke off on one side, it took a bigger chunk than that of the frame with it
  11. IIRC if the belt is off three or more teeth, pistons start hitting valves.
  12. ewwwww thats exactly what my frame looked like when my dad gave me my first pathfinder. And I called every shop in the area and none of them would even look at it (told me to go buy a blazer b/c they're cheaper to maintain). Good on you for getting it fixed. Prevent it from happening again, and it will last you a looooooong time. I'm going to work on mine as a "project" of sorts.
  13. Pavelow Leaks??? I think his was a fuel rail problem wasn't it?
  14. I usually do anyways for gas mileage , cause they thew on some roughrider radial AP tires on the back to pass safety, they have lots of tread left, but they suck. The fronts are goodyear wrangler radials and the treads a lot better. I'm gunna switch them up if i can find the time. Tires make a world of difference on these things I think. The r50 sucked in the winter with the bfg long trails, but with the revo's, its like saying to bad winter everytime i drive it. The only time I find that I have a lot of trouble is when the snow is packed down, and it turns really hard, thats where I've gotten stuck. Just a pita to go underneath and pull her into 4x4
  15. I don't think so, its an XE and my other one is an SE. But I didn't think all the SE's had the lsd. The se does have disk brakes though, someone told me that on pathfinders if i have the disk brakes generally you'll have the lsd, but who knows. Its wierd because my friend was watching me, and sometimes in 2wd both rear tires would spin, sometimes only one, and then in 4wd on ice, all 4 spun
  16. Pull the fuse? But I guess then the computer with complain and throw up some kinds of error light. I find my wd21 to be really light in the back, like in snow, i can hardly get anywhere without the 4wd, I think the carrier weighs the rear down, as my old one has more traction in 2wd.
  17. there is usually a lot of clunking with frame failure as well.....
  18. I have a sagging tbar in the front right, and 220,000 kms on my 95, and it seems to be pretty tight, or at least better than I expected a wd21 to handle (my first time driving one on the road in 3 years)
  19. Nice flex man V6, I used to think the r50's were kinda gay looking and were useless for wheeling before I joined this board and saw pezzy's and alex's rigs
  20. Simons right, its all about the driver. My friend took his 97 plymouth breeze (a front wheel drive CAR) through some sh!t that I wouldn't take my pathy through. And we somehow made it out.....
  21. Did you pay this person? Because if you did......small claims court? And chriskaw440, not at the welders house, the welder himself
  22. So a stock first gen X should drive somewhat similiar to a stock first gen pathy except bulkier?
