adamzan
Moderator
Everything posted by adamzan
  1. I think my alternator is new, but I might have already killed it I can hear noise when i put the defrost on in the -20 temps, or is this normal? Don't mean to threadjack.
  2. If i push the drivers lock down with the door open all the locks will lock and stay locked, but if the keys are in the ignition it won't stay locked. (on my 93 and 95). I think there's a thread around here that deals with the power lock actuator.
  3. holy crap that sucks man, hope you were ok.
  4. Have you tried checking to see if when you pull the key out of the ignition that you hear the click of that thing that senses whether the key is in the ignition or not. Not sure what its called, but that happend to my friend once. It got stuck and it kept thinking the keys were in the ignition.
  5. for a quick and temporary fix you could just grease up the cv and duct tape the boot together. Although, if your not in 4wd the cv's don't spin on these trucks.
  6. Strangely enough, since I've driven a wd21 with disk brakes, and one with drums, and an r50, I'd have to say the stopping power is only marginally better with the disk brakes. Unfortunatly, in all three trucks I've had come into brake slamming situations , but the rear drums last longer and since I'm lazy, its a good combo. Although I do like the simplicity of replacing the 4 wheel discs on my 93. But to answer the original question, I don't think it'd be too hard, like grimgreg said, to rig something up with an r50 cover, as the dimensions are probably nearly the same. (width)
  7. Actually when you're trying to load stuff in the back of the r50 that stupid thing can be annoying.
  8. Like he said, cheapest, most stupidly designed.
  9. IMHO i think you should've done the t-belt and water pump and all that crap before you put it in, or at least do it before you put the radiator and everything back in. The interval is 105k miles or for us canadians 168k kilometres. But I plan to do mine on my spring break, and I'll take some pics to help the wd21 owners out, because the pics in the how to are for an r50, although its almost exactly the same.
  10. Your an inspiration for me, if you can do that, I surely can do my timing belt. By the way, was that all done on this new engine?
  11. Yeah mine gets warm too, but when its -25 like it was today, I'm not complaining about having a nice leg warmer!
  12. adamzan
    Broken...
    Pull the fuse? I think there is one. If not I'm sure you could disconnect the wire from the stereo going to it.
  13. lmfao @ wife. I carry spare fluids and my CAA card and cell phone/charger
  14. Well its not doing it anymore so i figured it to be the belt. I'll replace it when I do the tbelt next week, or i'll just wait till spring.
  15. I'm sorry I made a stupid assumption, I do that from time to time.
  16. The timing belt needs to be changed every 168,000 kilometers. I'm not really sure about the exhaust manifold recall i think it went up to 100k miles I'm not sure though. When you put the truck in 4x4 you should be able to feel it engage, and if its slippery out, get someone to watch you give it some gas (enough to spin all 4 tires) and see if the front tires spin. It depends on the model but i think most of the SE ones have an LSD rear, there would be an orange sticker on the diff if it was. They're great in the snow, I should know, im from ottawa. The adjustable suspension, if it works, great, if it doesn't and the shocks ride like crap, you can only get the replacement ones from the dealer. Or just buy aftermarket shocks and not use the switch.
  17. Check the rear frame for rust, check the floor under the gas pedal for rust. If you don't know when the timing belt was last changed, change it anyways. Its cheap insurance. The only recall I ever heard of on the wd21's was for the exhaust manifold studs. If you drive your 5 speeds for mileage rather than constantly shifting at like 4k rpm, you'll probably see anywhere from 15-20mpg, thats what I'm getting with my auto right now. where are you located, that plays a BIG roll in the frame rust factor. The 95's seem to have trouble with the gauges in general from what i've seen here. But my 95 and 93 both have fully functional clusters. If you keep up on that maintenance it should last you a very long time with no problems.
  18. I think i discovered what the noise was, when i was on my way to school this morning i kept smelling burning, so i pulled over and saw that the a/c belt had partially failed and some of it was wrapped around the fan shaft. I drove to the nearest gas station and borrowed a knife ( i knew i shouldn't have taken it out of the truck!) and cut the belt off. Its SO much quieter now, and i think its more peppy too.
  19. It did it a little while ago(probably never stopped), but I didn't think it was serious and forgot about it, now that i noticed it again, im thinking it might not be so good. The only thing that i could say is strange is that once warmed up, on light acceleration the engine does accelerate consistantly, but if i give it a little more gas it works fine. I was told that for that it could be the Throttle position sensor going, but there were no codes, but i probably didn't read them right, i'm going to take them tomorrow and see. Other than that, she drives great, the engine doesn't knock, or burn a drop of oil (like i don't add any between changes, and it stays full the whole time) I know i have an exhaust leak, but that is not the sound im talking about.
  20. Thanks, i'll check it tomorrow. I wouldn't be surprised if it was loose, with the idiot who owned it before me
  21. Yeah thats it, and when i rev the engine it gets faster. It runs and drives fine though My friend was listening to it, and he thought it was the a/c idler pulley or the power steering pump...or one of those belts. But I have no idea. I'm really not good with mechanic trouble shooting, but if i knew what it was i could fix it. Ignore all the other...bad noises....
  22. I have no idea what it is, but I'd REALLY appreciate anyone giving me any ideas, my friend thinks its the a/c idler pully, because it has a little bit'o'play in it but i don't know. Normally I'd find out what the problem is but I have a midterm tomorrow and can't have the pathy all apart tonight. video:
  23. On my dads r50 the rotors are still the original oem ones and it has 125k miles on it. I'd go with the oem ones again. I know I will when it comes time to change mine on my 95
  24. My 95 doesn't even have a block heater, and it starts fine in -30 degree weather. I use synthetic oil. My 93 has one though, although where is parked currently it can't be plugged in, but it starts fine too. The battery heater is a good idea though.
  25. Well I can see no visible difference between them. like if you try and pull the lever back to flash someone to let them go at an intersection, the lights don't change. Unless you turn the headlights on. Some schmuck has rewired them, just like the rear lights i assume. 88 i took apart the cruise buttons just now, the contacts are nice and shiny clean. I read that the cruise brain is behind the panel on the drivers side in the back, how do i remove the panel? Also when i turn the cruise master switch on, I can hear a click, but can't tell if its coming from under the hood or the back.
