Everything posted by dududuckling
A/C lift on top, SFD at the bottom
I'm a professional student
What is the brand of the stock oem pads?
dududuckling replied to sonyslave's topic in 96-2004 R50 Pathfinders
I've tried EBC yellow and green pads, and EBC slotted rotors. EBC pads are more expensive and are no better than OEM. Braking distance is still the same, and OEM pads last a whole lot longer than these EBCs. -
Really nice... I need the belly skid
Cheapest Place to get O2 sensors?
dududuckling replied to new4x4r's topic in 96-2004 R50 Pathfinders
No worries. You can also check Consumer auto parts if you're in Toronto. I got my O2 sensor from them last summer. Shady guys, cash only haha... 2562 St Clair Ave W 416-763-5696 -
Rod, if you wanna send it my way, I can bring it over. I'm planning to go up there next weekend for spring break. -
How capable is my R50 without a lift?
dududuckling replied to PrecisionX's topic in 96-2004 R50 Pathfinders
Its pretty capable, just watch out for the air intake during water crossing -
Fits 2000 as well
Front bumpers: OEM or not to OEM?
dududuckling replied to XPLORx4's topic in 96-2004 R50 Pathfinders
Looks good -
32x11.5x15 or 33x10.5x15 with AC lift
dududuckling replied to erathge's topic in 96-2004 R50 Pathfinders
I have 285/75/16 (or 32.8x11") Wrangler MTR on 3.75", 16x8 pro comp wheels. It also has 2" ac lift. When the rear flexes, the tire gets stuffed in and kicks the fender flare out. That's a guarantee. As for the front, during full turn, front tires rub the fender flares. Little trimming is required on the front fender flares around the bottom corner. You won't even notice when looking at it from the side. Since you have the NX spacer, you might not have to trim as much. Regarding tire-to-strut clearance, there's like 0.75-1" distance between them. I'm thinking on going with 305/70/16 (still a 32.8x12") next summer and see if it clears the struts. -
Looks good. Any plan on making the remaining of the skid plates? I got your first two and they've worked tremendously. But the transmission and t-case is still exposed.
But the new Patrol has independent suspension front and rear, no?
As long as your intake is not under water, I think you're good. I was in the same situation, muffler under water, water coming in passenger side, and I turned the engine off. I turned it on no problem. Boat engine starts underwater afterall?
Congrats, Pete! Nice picture!
I have the same exact codes for about a year now. The 0325 is knock sensor, it doesn't affect us - I believe every pathfinder owner has this code? The 1491 is vcv bypass valve. I got a 3.3L with manual transmission. Truck's been fine, no loss of power as long as I'm aware. No hesitation or whatsoever... When I'm in 4th and 5th gear, I do get some "noise" between 3200 and 3500 rpm, then it goes away. It doesn't do that on 1st, 2nd, and 3rd gear. I noticed this around the same time 1491 popped up last year. I'm not sure if its related. I normally shift between 3000 and 4000 rpm when the power kicks in.
285/75/16 - I run 40 psi up front, 35 in the rear. The treads wear out evenly. Not sure if its necessary, but I figure the engine and front bumper made it heavier up front than in the rear...
I followed Rick13. I'm running 285/75/16 Wrangler MTR (1st gen) on 16x8, 3.75" BS Pro Comp Steelies. The pathy has 2" AC lift and no spacer. It clears the struts just fine.
Looks awesome! You're lucky to wheel in such places
Congrats!!! Nice truck!
01Silvapathy is right. 4.25" is the way to go in the rear. I've got 2" AC, 33's on 3.75"BS. The rear fender flares were the first to go when those tires flexed. If u don't live in rust belt area, u can always take those flares off hahaha... They don't do much good anyway except from looking pretty Rick I'm with you on that one, hahaha... If I get a flat, the plan is to move the spare tire to the rear, then swap the rear tire for the flat one up front And I think the Dick Cepek/ Mickey Thompson tires are smaller than the others. Like 31" = 30" BFGs or something
Got my vote for sure!!!
The first one is a 2012 X-trail The second one is 2012 Nissan Patrol The third one is a custom R51 pathy by Ecko
Welcome to the club! Finally someone else in Michigan with an R50. I'm in Rochester Hills, MI. 265/70/16 should fit just fine without the lift. Biggest concern is whether or not the tire, in that stock rim, will clear the strut mount. And the answer is yes. I run 265/70/16 in the winter on the same wheel as yours. Tire-to-strut clearance is about an inch. I've 2" suspension lift, but it doesn't change the distance between tire and strut. Depending on how much it sags, you might rub the fender flares during full turn. But you can always trim the edges. With 2" lift, 3.75" backspace wheels or 1.5" wheel spacer, you can run 33's or 285/75/16.
Here's mine Dududuckling Ontario
