Kingman Posted June 13, 2014 Share Posted June 13, 2014 yelled nasty words at it because my door lock is failing and it kept locking everytime I tried to open the door. I was on the inside and couldn't get out! Lol she just loves you. Is her name Christine? Link to comment Share on other sites More sharing options...
Kingman Posted June 13, 2014 Share Posted June 13, 2014 Installed 6 new injectors, FPR, and rebuilt the fuel rails with new hose. Also re worked the electric fan mounts. Link to comment Share on other sites More sharing options...
89Rotary Posted June 13, 2014 Share Posted June 13, 2014 did a power steering flush here at work using left over fluids. sometimes it really pays off being a Nissan tech lol 1 Link to comment Share on other sites More sharing options...
Kingman Posted June 14, 2014 Share Posted June 14, 2014 Found the CAS might be bad. I get 3 injector/spark pulses on a full distributor rotation. I put the distributor in one tooth off, intentionally, and it started and ran on 3. Kinda sounded like a retarded Harley. Wiring between the CAS and ECU is perfect so I know there's no disconnect on signals. Weird that one tooth incorrect made it fire, but I'm going to try another sensor and see what happens. That's the most I've gotten it to do in a year! Link to comment Share on other sites More sharing options...
lerch641 Posted June 14, 2014 Share Posted June 14, 2014 Oil change and my local shop ran a diagnostic (service engine light came on last week) and they found the knock sensor had set off... Link to comment Share on other sites More sharing options...
lerch641 Posted June 16, 2014 Share Posted June 16, 2014 Finally got to fix my headlight. My passenger side headlight and marker were shattered and the little plastic clips for the headlight were broken off. Finally had some good weather to go to the junkyard today and get some replacements. Link to comment Share on other sites More sharing options...
Kingman Posted June 16, 2014 Share Posted June 16, 2014 Yelled at it. Came out to the contents of brake fluid reservoir on my garage floor. Damnit! Link to comment Share on other sites More sharing options...
Precise1 Posted June 17, 2014 Share Posted June 17, 2014 Washed it... B Link to comment Share on other sites More sharing options...
vagabond Posted June 17, 2014 Share Posted June 17, 2014 charged the battery on the 94, since mama broke her leg it hasn't been driven Link to comment Share on other sites More sharing options...
SkiBumBrian Posted June 19, 2014 Share Posted June 19, 2014 When I got T-boned directly in the RR tire/wheel several weeks ago, I finally found out the hub got slightly bent so I ordered a new axle through Rob but it needed to come directly from Japan. He told me that it could take many weeks for it to come in but he PM'd me today and he shipped it (only 9 days from ordering)! It may make it here by Saturday so depending on the weather I may swap them out this weekend. Awesome! (to be continued....) Link to comment Share on other sites More sharing options...
SpecialWarr Posted June 19, 2014 Share Posted June 19, 2014 Ipulled out the angle grinder and spent three hours last night cutting off a 1/2" flange from the forward end of the cat. to get a solid connection from the headers back. I'm now unsure of whether the truck is idling or not....it's too quiet. sent from under Ernest the Pathfinder Link to comment Share on other sites More sharing options...
PHR Posted June 19, 2014 Share Posted June 19, 2014 When I got T-boned directly in the RR tire/wheel several weeks ago, I finally found out the hub got slightly bent so I ordered a new axle through Rob but it needed to come directly from Japan. He told me that it could take many weeks for it to come in but he PM'd me today and he shipped it (only 9 days from ordering)! It may make it here by Saturday so depending on the weather I may swap them out this weekend. Awesome! (to be continued....) Where I am, without Rob, my terrano would be in a scrapyard today. Rebuilt and re installed my starter yesterday. Philippe. Link to comment Share on other sites More sharing options...
NIssanBoston Posted June 19, 2014 Share Posted June 19, 2014 Changed the old spare on my tire carrier, with a general grabber at2 tire Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 19, 2014 Share Posted June 19, 2014 Discovered a mouse nest in the underhood insulation, mouse lice all over the outside of the truck, and live mice sitting around the battery and the parking lights watching me.It's been parked for less than a week. Anyone got some bull snakes you're not using? 1 Link to comment Share on other sites More sharing options...
txpath4x4 Posted June 20, 2014 Share Posted June 20, 2014 Took the R52 to the dealer for damage assessment of the fender bender the wife had... And to get the fog lights installed Link to comment Share on other sites More sharing options...
k9sar Posted June 20, 2014 Share Posted June 20, 2014 replaced the passenger side brake caliper and mounting bracket cause both slide pins were seized. Truck stopped fine but only the inner pad was worn. Not a mark on the outer LOL Link to comment Share on other sites More sharing options...
Kingman Posted June 20, 2014 Share Posted June 20, 2014 (edited) Today I swapped the standard dome light for 15 LEDs. Stupid bright! Lights up the inside even in broad daylight. Laugh all you want about the white paint, but it even further brightens the light. Edited June 20, 2014 by Kingman 1 Link to comment Share on other sites More sharing options...
Kingman Posted June 20, 2014 Share Posted June 20, 2014 Next is doing the cargo light and adding some under the dash for footwell lightinf and maybe in the doors somewhere. Link to comment Share on other sites More sharing options...
PHR Posted June 21, 2014 Share Posted June 21, 2014 Next is doing the cargo light and adding some under the dash for footwell lightinf and maybe in the doors somewhere. , Last night I washed it. Ph. Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 21, 2014 Share Posted June 21, 2014 If you're looking for places to put LEDs, I put a crazy bright panel under my hood, wired to the alarm switch. It was originally for my dome light, but it just about fried my retinas when I'd open a door at night, so I swapped it for a warm-white panel about half its size. The warm white is about on par with the original bulb, and the bright white panel makes jumpstarting somebody else's car at night really easy. Link to comment Share on other sites More sharing options...
xterra Posted June 21, 2014 Share Posted June 21, 2014 Finished my expedition / cargo box build: http://www.nissanpathfinders.net/forum/topic/38290-wd21-expedition-cargo-box-build/ Link to comment Share on other sites More sharing options...
Precise1 Posted June 21, 2014 Share Posted June 21, 2014 Today I swapped the standard dome light for 15 LEDs. Stupid bright! Lights up the inside even in broad daylight. Laugh all you want about the white paint, but it even further brightens the light. Wow, makes the interior look good too! I put 1.21 gallons in the tank... B Link to comment Share on other sites More sharing options...
Kingman Posted June 21, 2014 Share Posted June 21, 2014 Did the rear cargo light. I thought I had a bunch of under dash light housings from Z31s but I can't find them. Maybe I'll pull a few from Pathfinders and see which ones I can fit the most LEDs in. Link to comment Share on other sites More sharing options...
Terranovation Posted June 22, 2014 Share Posted June 22, 2014 In Australia we have those interior led bulbs that fit into the little clippy bits instead of having to fiddle about soldering wires, I put one in mine that only has 6 leds but yeah it's heaps brighter than standard globes. Link to comment Share on other sites More sharing options...
Kingman Posted June 22, 2014 Share Posted June 22, 2014 Ha. We actually have those here too, can even get retrofit ones that plug in like a standard tail light bulb. However for $8-11 (free shipping usually) for 15 meters of the things in any color you want, the novelty of plug and play goes away. Link to comment Share on other sites More sharing options...
